Question about Thermos Stainless Steel Gas Grill
I need a replacement for (model #461262006 (4 burners item no.80005703) and item (800003362 regulator flame).
meBNme
  • 334 Answers
SOURCE: BBQ Galore Capt'n Cook 4 burner gas grill won't get hot.
You can buy a gas pressure guage from any HVAC supply house, and possibly at a gas utility office or the retailer that sold the grill.
It taps into the manifold, or gas valve.
For most LP systems you are looking for 11 to 14 PSI but double check with your system. You may can find it on the owners manual or on the data sticker.
Be shure to shut off the gas before you remove the plug and hook up the guage. Most plugs are either allen wrench or square head plugs.
Posted on Dec 06, 2008
jumptrout51
  • 3361 Answers
SOURCE: Replaced gas safety valve, burner flame now too hot
Take a 1/2 inch open end wrench and tighten the orifice on top of the safety valve.Probably about 2 turns. Then adjust the air shutter to mostly open.
Posted on Mar 26, 2009
SOURCE: 1st burner goes out when 2nd burner is turned on
I had the same problem. They original regulator and hose were poorly designed for this model. There isn't enough room underneath without crimping the hose. I bought a standard regulator and shorter hose combination a Home Depot for about $20. It makes a 90 degree turn coming out of the tank and does not kink the hose.
It was worth the $20.
Posted on Jun 03, 2009
SOURCE: My grill does not exceed 300 degrees
Bypass valve need reset. All grills made after 1996 have this valve.
  • Close the LP tank valve
  • Turn all burner control knobs to the OFF position
  • Open the grill lid
  • Turn the LP tank valve until it is completely open
  • Wait 90 seconds
  • Turn the front burner to the HI/Start position
  • Press the igniter until the burner is lit.
  • Turn remaining burners to High
  • Close the lid.
  • The grill should preheat to 500-550 degrees in 10-15 minutes
I called Weber and a rep walk me through it.
Posted on Aug 31, 2009
SOURCE: cannot get good flame on the burner of my baby weber grill. I've tried cleaning it checked hose, tank, regulator, seems to have good flow, but low flame only, even when set in high????????
I had this problem with a brand new grill so it wasn't grease in the hose. Due to the new propane regulators you have to turn the propane tank on for at least a minute before turning the grill to light. Let the tank sit in the light position for five seconds and then you light the grill. This will keep air from getting into the intake hose and will keep your gas flame roaring high.
I was only able to get the grill up to 250 degrees before I found this fix posted on the Weber site. It is listed as the number one solution in the FAQ section.
Posted on Oct 13, 2009
Glow plug glows flame lights up after 30 sec flame goes out
If the burner assembly lights, then the problem is usually not with the igniter or regulator. More than likely the gas valve safety coils need to be replaced. There are two of them on the burner assembly. You need to replace BOTH of them at the same time.
If the model number is correct, you can view and illustration of your burner assembly here:
http://pcappliancerepair.com/model-display.php
The coils are listed as items 729 and 731. Part numbers WE4X692 and WE4X693, respectively.
If you have any questions, or if your model number differs from the one you listed this question under, please post back and let me know. I hope you find this information helpful.
May 26, 2010 | GE DBXR463GB Gas Dryer
Dual fuel thermos m#461262006 swicth back to propane
You can get the manual on the link below. Make sure you have the right regulator for the propane and not one for Natural Gas.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0807110.pdf
Apr 28, 2010 | Thermos Stainless Steel Gas Grill
Jenn Air gas grill model 720-0163 will not get above 180 degrees?
Try turning on just one burner to start, once it is on, turn on the next burner, if the flame gets lower on the first burner, you need to replace your regulator.
Dec 20, 2009 | Jenn-Air Grilling
Whirlpool stove top- two problems. 1) burner is not burning hot, low flame 2) igniter on different burner doesnt work, no spark at that burner.
Hi
If the burner is not burning hot, and there is a low flame then this is often a pressure regulator problem. Most often the regulator is found where the gas line enters the gas range. I have a picture of what the flame characteristics should look like. If the igniter on different burner doesn’t work, and there is no spark at that burner then you will have to check the same items as mentioned above. This is a typical spark module wire diagram.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 08, 2009 | Whirlpool GLT3615 Gas Cooktop
Low flame on burners
Check the following items:
The propane regulator - and make sure the valve on the propane cylinder is all the way open
The fuel jets (the holes at the end where the propane comes out, usually brass)
The manifolds - they can become obstructed with insect nests
The gas burner valves
The burners themselves, again for obstructions
Apr 19, 2009 | Kitchen Ranges
Mar 29, 2009 | Grilling
Low flame
this is a problem with the regulator. It is not allowing enough pressure to maintain the burners when all are lit on hi. You can get these regulators at most major retailers or directly from th emanufacturer.
Hope this helps you out.
Jun 15, 2008 | Brinkmann 810-2300-B Grill
Sideburner for Thermos Stainless Steel Gas Grill (Mod # 461262006)
It sounds like the orifice is bad. An orifice is a small metal part that has a small hole in it. This regulates the gas coming out to the burner. It is at the tip of the pipe that brings gas to the burners, before the flame. I don't know what the hell the garggley noise is. Unless the bottle is upside down, and you are getting liquid, I don't know.
Mar 02, 2008 | Thermos Stainless Steel Gas Grill
Low gas Flame
check the vent plug on the regulator.
Dec 24, 2007 | Rangemaster 110 (Gas) Kitchen Range
Thermos Stainless Steel Gas Grill Logo
103 people viewed this question
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
jdthefixer
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
