Question about Sony SDM S71W (White) 17 in. Flat Panel LCD Monitor
I have a Sony SDM-S71 that has developed very small vertical lines in the video. It seems only dark colors are affected. It comes and goes. Monitor is still usable, but playing video is out of the question. Ideas??
  • Dan Eidson
    Dan Eidson Nov 18, 2009
    Let me get deeper...Im a qualified component level replacement/repair technician.. unfortunately I have no schematics on this monitor... was wondering if anyone else had the problem and could steer me in the right direction..
  • Dan Eidson
    Dan Eidson Nov 19, 2009
    Update!! Found a chat that recommended opening up back cover... removing the large shield. CAREFULLY removing the clip that holds down the small connector on the large board. WARNING:::SMALL PARTS MAY BREAK IF NOT CAREFUL::: Take a sewing needle and CREFULLY bend small pins ( may need a magnifying glass) just a small touch....on both connectors. DO NOT BEND TOO MUCH... PINS MAY BREAK!! carefully replace connector and clip. Reassemble chassis and power up.
    This fix works great for this problem!! Good luck!!
  • 65 Answers
My advice would be to replace the monitor. The problem isn't going to go away unfortunaly
Posted on Nov 18, 2009
My SOny SDM-S204 has no green in the computer display however, the monitor menu window is the correct color
Hello amellows, hi, check the video cable for loose connection, tighten the vga plug screw, try to wiggle the vga plug and see if there are changes on the display. As for the monitor menu, this is usually not affected, the colors are built in its onboard memory.
Mar 31, 2010 | Sony SDM-S204 (Black) 20.1" LCD Monitor
Sony SDM-HS75 tft lcd monitor
Sounds like you need a new backlight. Check lcdparts.net
May 26, 2009 | Sony SDM-HS75 17" LCD Monitor
When first turned on there are colored lines running vertically
sell it on ebay...
only joking. :-)
it sounds to me that the power supply is affecting the refresh rate, and will lead to the first section of pixels being affected, but it will then eventually cause perminantly flickering and may then lead onto the 2nd rows being affected.
theres nothing really that you can do about it though im affraid.
im sorry.
hope this helps
kev
Dec 01, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Vertical line top to bottom rightside of screen
hardware problem. please call manufacturer for warranty service
Nov 03, 2008 | Sony SDM-HS53/HT 15" Flat Panel LCD...
I HAVE ONE SONY MONITOR MODEL SDM HS75.
IT IS SHOWING LED BLINKING FAST NO DISPLAY IF CAN ANY BODY HELP ME TO SOLVED MY PROBLUME.
ASHOK MY CELL NO.09322133048
email.ashoksharma4@gmail.com
Mar 02, 2008 | Sony SDM-HS75 17" LCD Monitor
Intermittent vertical lines
PANASONIC PV-C2540 Intermittant PROBLEM, picure is reduced to left to right vertical line. SEEMS TO WORK FINE WHEN SET HEATS UP?
Dec 22, 2007 | Televison & Video
What do i do
This is due to the defective lcd panel. It will be expensive to replace .
Dec 04, 2007 | Sony Personal Entertainment SDM-V72W (Dark...
Monitor goes Black off and on .....
I had the same problem for about a week and solved it yesterday by downloading the latest driver by NVDIA who makes my video card (NVDIA GeForce 6200).
I had previously updated the latest Sony driver for the monitor. It did not solve the problem but could be part of the solution in conjunction with the new video card driver.
Oct 31, 2007 | Sony SDM-HS75P/S 17" LCD Monitor
LCD Monitor Goes Black during Use
I had the problem sometimes, but then I connected a second computer to the analog input and found out, that the screen didnt turn black but switches between the inputs on an on.
I found out that the "input" button seems to be short or damaged, as the behaviour was invertable by pressing the button. I blew into the button some times (a very naive solution, yeah) but it worked, the switching stoppped.
Oct 17, 2007 | Sony SDM-HS75P/S 17" LCD Monitor
Monitor goes blank
Well, I do not think that there is an actual solution for that problem. I had that exact problem and I had to throw mine away. Turn it in to where you bought it and see if they can repair it. Otherwise they will have to replace it.
Apr 09, 2007 | Sony STYLEPRO SDM-S71 (Gray) 17" LCD...
Computers & Internet Logo
128 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
