Frigidaire dryer sometime work and sometime doesn't . But I can't find the model no. Motor ok heater ok start button not sure. Once it start everything alright but a few days later it can not start. please help,thank you!
  • 95 Answers
Bi-metal strip units are faulty
Posted on Nov 18, 2009
I have a stackable frigadare w/dryer. Washer works great but the button to start the dryer just hums. Belt is ok.
It seems like this dryer need new dryer motor
In order to be sure ,take belt off and try to start dryer ,if dryer still humms it is motor problem for sure,
Jun 04, 2014 | Frigidaire Washing Machines
Dryer does not stay running. Press the start button and sometimes it starts and sometimes not. Won't stay running. Seems to heat ok. Sometimes displays E9E on the display.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Oct 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire dryer model FDE336RES2 won't run when you push the button. How to troubleshoot? I check power to unit and its OK. could it be the thermal limit part?
There can be many reasons why your dryer will not start orturn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 21, 2010 | Frigidaire FDE336RE Dryer
My frigidaire dryer model NMER336FSO just out of the blue quit working. When I hit the start button i can hear a loan buzz, but it wont turn on.
It sounds like your Frigidaire may have one or more problems. If your push to start switch is defective then it will have to be replaced. You can test the switch itself by FIRST disconnecting power. Then taking the switch out and setting a voltmeter to test for continuity, then pushing the start button to see if there is on and off contact being made. Part number for the start switch is 131469000. If this is okay and you are hearing a buzz or low grumble noise coming from the motor area. this could indicate a bad motor winding and would probably have to be replaced. part number for the motor is 131560100. Sometimes however the motor can become seized or dirty connections to the motor can occur due to debris or dust bunnies. so make sure the dryer is CLEAN. If you give the drum a turn yourself manually, while trying to start the dryer this can sometimes give the motor the kick it needs. however this is only a quick fix, and not permanent. You have a well built simple dryer, and there isn't a whole lot that can go wrong with it. Hope this helps
Thnaks.
Nov 05, 2009 | Frigidaire Dryers
Frigidaire dryer hums when button is pushed in but won't start
ok can u turn the tumbler freely,
if no well there is something stuck in you blower like a sock or something
if the tumbler turns freely
keep the door open and hold the door switch
try pushing the start button
and tuning the tumbler, yes all three at the same time lol you may need a hand
try tuning the tumbler when you hear a hum
if it takes off bad news your start winding on the motor is bad or the capacitor depending on your model
if it does not turn, but the hum continues longer than 1-2 minutes it could be just a belt
Oct 19, 2009 | Frigidaire Electric Dryer
For Kenmore model 110 62942100 dryer, i push the start button and the dryer turns on, but then shuts off when I release the button. I checked to make sure door is closed.
greetings,
Its possible you have a defective relay. this dryer has a start relay for motor and one for heater. they are the same. if you can find them and know someone who is ok around electric. you can have them find which one is which and switch wiring. if it starts, buy a relay..if not, the motor is defective..i'll bet its the relay..Bruce
Jul 12, 2009 | Washing Machines
Kenmore dryer stopped running
Hi, I can determine a motor bad by the noise. Does it hum while holding the start button or is it a grinding deep sound? It can sound like the motor starts slow but once it gets going, it is ok. Sometimes the house lights will dim when the motor statrs going bad.
Let me know if I can help you further.
Vic
Jul 02, 2009 | Dryers
Dryer will not run
dryer starts sometimes if you hold in button. frigidaire gallery series model # GLEQ942CSO. serial # XD350164472. flat panel control board.
Mar 31, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Kenmore electric dryer won't start
The first thing I would check would be the door switch. Dryers operate on 220 volts. Many brands split the 220v into 110v for controls and motor and 110v to the heater. There are also safety systems on many brands that won't allow the heater to come on if the fan motor is not running and blowing air throught he element to prevent overheating and dryer fires. If the door switch is ok, check the belt. If the belt is ok, it could be a problem with the motor start switch. The motor start swith is complicated fix and should be done by a professional. ALWAYS BE SURE TO DICONNECT THE POWER BEFORE ATTEMPTING ANY REPAIRS.
Mar 24, 2008 | Estate TEDX640JQ Electric Dryer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
