Question about Samsung SyncMaster 914V 19" Flat Panel LCD Monitor
My Syncmaster 914v has a green tint, and menus are in German!
My Syncmaster 914v monitor has 2 problems: 1) when I try to adjust it, all the screen help is in German or similar. How do I get it to be in English? 2) when I plugged in my new Logitech digital USB speakers, my monitor background turned an annoying aqua/green tint, and photos are coming up in kind of a "film negative" texture. The usual Graphics properties and theme changes don't seem to help me. What can I do?
  • 859 Answers
SOURCE: samsung syncmaster 720 n
Is the auto adjust button stuck?
Posted on May 10, 2008
SOURCE: Whitewashed screen
bring it to the service center for a check up
Posted on Sep 30, 2008
  • 3 Answers
SOURCE: samsung syncmaster 206bw turning on and of, light
If you have soldering iron and can place an order at (and are willing to get your hands down on this), this is a rather easy fix with some direction. You basically will be replacing some failing capacitors inside the unit.
Posted on Jun 18, 2009
SOURCE: Auto adjust doesnt work
try to push the menu button for 5sec, maybe it will be solve the problem..
Posted on Aug 11, 2009
  • 53 Answers
SOURCE: auto adjastment locked
Samsung implements protection into their monitors, which allows to block all settings except brightness and contrast. This "Locked" mode turns on by pressing and holding 'Menu' button for 5 seconds, and turns off by pressing and holding 'Enter' button for 5 sec.
Posted on Sep 09, 2009
Screen has a green tint all of a sudden. 2 years old
First thing is try refitting / replacing the signal cable and connecting to another known working computer. Samir
Feb 07, 2011 | Samsung SyncMaster P2450H 24" Wide TFT...
Green power light is on....flashes screen
It is a hardware problem so pls checked it from service center.
Oct 14, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
Is there a new windows 7 driver for the Samsung Syncmaster T240 monitor? The problem I'm having is green flickering, where a green tint intermittantly comes over the monitor.
try reducing the refresh rate of the screen. I Hope the Driver for the moinotor is installed !!
But if it is intermittant..
Then Monitor may be going through normal ageing.
Rate this solution, Write a comment to keep in touch.
Sep 16, 2010 | Samsung SyncMaster T240 Monitor
Increasing my screen resolution without imediate reinstall. I need faster ajd smaller pixels to hopfully get into my Registry for changes so I can log in with the problems of not logging in because of...
  • Hi, I've read your "Post" I will try to assist you in sloving the problem. "First you want to change' the visual effects of the "Display." 1. Right click on "Desktop,
Jul 07, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
Samsung syncmaster 914v monitor problem. Right side of display is darker image. Can see dots like a newspaper print or looking through a screen. When display is black it almost appears like an image is...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
May 15, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
Samsung syncmaster 914v monitor problem. right side of display is darker image. can see dots like a newspaper print or looking through a screen. when display is black it almost appears like an image is...
This is likely the LCD panel itself - you are describing a left/right image error that can be only created by the left/right division by the LCD driver wrapped around the outside of the LCD panel.
If your monitor uses a separate circuit board to drive the LCD, it could be this driver board.
Either way, it will require an LCD panel - $$$
Mar 29, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
My samsung syncmaster 914v isnt working when i plug it in and turn it on all it does is flicker every like 10 seconds
Ok, a few basic things to check/try.
  1. What colour is the power LED, does it change when the screen flickers?
  2. Is the power cable firmly seated.
  3. Is the monitor cable firmly seated.
  4. Try another power lead.
  5. Take a look at the plugs on the monitor lead, does it look like there are any bent/broken pins.
  6. Again, try another monitor lead.
  7. Try connecting the monitor to another pc.
If none of these have any effect, you'll need to take it in somewhere to get it looked at.
Feb 25, 2010 | Samsung SyncMaster 914V 19" Flat Panel LCD...
Samsung 914v 19" LCD pixels went out
your lcd micron tube in the panel had already worn out.
got to replace the panel
Jan 31, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
A green hue from my samsung syncmaster 720n
Check the video cable connection at both ends. If it is secure, then move the cable in circles at both ends.
If the cable breaks a single wire, it will still be close enough to make contact under this test.
The red is almost always the one that will break first and cause the green and blue signals to be the only ones to be active resulting in a blue/green tint.
If you have another cable just try that instead.
Apr 28, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung SyncMaster 914V 19" Flat Panel LCD Monitor Logo
56 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
