Question about HP LaserJet 4300 Printer
How do i change the ip address on an hp laserjet 430?
    Brigadier General:
  • 10,406 Answers
Use the buttons and the LCD on the printer, to navigate through the main-menu and the sub-menus, to change the IP-address.
Also, via the manufacturer's web-site: http://support.hp.com
select & download the "Quick Setup Guide" for your specific model of printer, and follow its instructions.
Posted on Nov 18, 2009
I changed the IP address range of my LAN and need
Click on the link to download the drivers for your laserjet printer.
Download Drivers
Regards,
Sean
May 28, 2013 | HP LaserJet P2015dn Printer
How to assign a ip address in hp laserjet 2420dn manually. as it is changing always
Go to menu > IO menu > automatic-manual, select manual > ip address > enter IP adress..
Sep 09, 2011 | HP LaserJet 2420 Printer
4300 laserjet wont print docs. IP address is same as a network computer, cannot change IP address? Configuration page prints and I check ports etc but will not print. cannot change IP address. Help....
Have you tried changing the IP address from within the driver's properties? Go into the print driver properties, and under the Ports tab, edit the 4300's port and change the IP address that it is associated with. You may need to reboot the printer once you make the change and save it, but that should allow you to change its IP address.
Jun 13, 2011 | HP LaserJet 4300 Printer
How to i configure the ip address on hp laserjet p3005dn so i can set up a network printer. I donot want the ip that the printer came with.
Hello, When you first install the printer onto the Network it will automatically find an IP Address, this is called "DHCP". In order to change the IP Address the printer needs to be setup as what is known as "STATIC". You can do this in in a couple of ways 1) Type the IP Adrees into an internet explorer Browser, this should open up the printers EWS (embedded Web Browser) if it opens click on the networking tab - Chnge the IP Address , set DHCP to "OFF"and click Apply. 2) From the printers control panel - push the "MENU" button and scroll down to the "CONFIGURE DEVICE" to "I/O" to "EMBEDDED JETDIRECT" Withi the TCIP setting you are able to change the printers IP Address
Jan 12, 2011 | HP LaserJet P3005n Printer
What is the default ip address of the printer hp laserjet 4250n?
There is no default IP address on HP printers with Jetdirect print server card.
You set the IP address in the printer's network settings. The IP address need to be set to match your network's address range.
To configure the HP network printer to work on your network, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559242-setting_up_hp_jetdirect_print_server_p
Dec 14, 2010 | HP LaserJet 4250n Printer
How can i assign IP address and other require parameters on HP LaserJet 2420dn printer ? I want to run this printer as print server using Ethernet (network) cable. Please reply me. My email :...
First install the printer driver on your computer and then change the printer port to IP port with the printer's IP address.
The printer's IP address is assigned from the printer's menu Network setup.
Please click on this link and follow my instructions.
Aug 11, 2010 | HP LaserJet 2420 Printer
How to change ip for hp printer 2015?
easiest way is to connect with internet explorer to its current IP address and in menu network change IP to desired values. You can get current IP by holding green button, until flashes orange button (triangle), then release green btn and printer will print 3 pages. in third page on top right is current IP address.
Feb 07, 2010 | HP LaserJet P2015dn Printer
HP LaserJet P2015n Printer IP adress
To Me it looks like your printer is set to automatically select an available IP address. If there is no IP available you get the 0:0:0:0 You need a static IP set up for the printer, this will make sure that no one can use the IP. If this is a company printer, get IT to set it up for you. If its your home network you can set this by yourself by either connecting your printer via usb and using the software from HP or if you have an IP you can log into your PC by entering the IP address in the address bar of your browser. You should get the HP page up for your printer. Set the IP from there in the networking section. I hope this helps a little
Aug 18, 2008 | HP LaserJet P2015n Printer
HP LaserJet 3055 unable to save IP setting
i can solved this problem please give me one chance
Jul 05, 2008 | HP LaserJet 3055 All-In-One Printer
HP JetDirect IP Address
how to assign the IP address to Hp color laserjet 2550Ln printer?
May 10, 2008 | HP LaserJet 2550Ln Printer
HP LaserJet 4300 Printer Logo
717 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
