Question about NetGear FS605 (FS605SE) Networking Switch
Is my FS605 broken
Moved the computer and everything to a different room while redecoration a room, and then back to the original place. Now the switch does not seem to work. All the lights are on constantly - regardless of what i try.
What I try is to connect the swith to my internet plug in the wall, then I connect my computer which has a fixed IP-adr.
Both cables work fine when I connect the computer directly to the wall.
I am pretty sure that the switch used to blink when there was network activity on it. What order should I plug everythin in with? and is there any reset button on the switch?
  • robhed Jan 11, 2008
    PRoblem was I was trying to give it power with a nokia mobile charger :) When I figured that out, everything then worled like a charm again.
    Novelist:
  • 139 Answers
The FS06 switch is probably defective and needs to be replaced...especially if the status of the lights does not change after you cycle the power on and off with no network cables plugged in. These switches are sensitive to overheating and can easily be damaged if used next to other warm network equipment or with air vents blocked by papers, etc.
Turn-on order is not critical in this scenario, but ideally you should plug in all network cables, turn on the switch first, then turn on the computer.
Posted on Jan 10, 2008
6ya staff
SOURCE:
Need tips to redecorate my home.
The doors and windows can play a big role while redecorating home. You can install UPVC sliding or casement windows to give a more attractive and inviting look to your home. For more details, visit: http://www.fenesta.com
Feb 25, 2014 | Exercise & Fitness
Moved my computer to a different room and now it won't turn on
1) Make sure the plug is inserted fully
2) Make sure the power switch on the case is in the on position
Apr 13, 2011 | ASUS Essentio Desktop / AMD Athlon II X2...
My Netgear FS605 stopped working. All lights flashing about 1x/sec. No change in cabling or configuration in past year. Upstream Linksys N wireless router working fine. Tried disconnectring ethernet...
Are you able to ping between systems connected to the same Netgear FS605 switch and in same VLAN.
I suspect either switch port or Uplink cable issue.
Please try changing a new cable and if no improvement then please try with a different switch port.
Jan 08, 2011 | NetGear FS605 (FS605SE) Networking Switch
Unplugged computer and moved into another room. Plugged back in and won't turn on.
First you bring back the PC in the original place - check whether you may run the PC here. If it runs that means there is a problem with the switch board (2nd one) or there is power source problem. If it does not run in the original position that means you are not connecting the PC correctly - please carefully connect and plug the all.
Jun 18, 2010 | Dell Dimension 4600 PC Desktop
I moved my wifes computer and PLE200 adapter to a
Maybe too far away. You can buy booster antenas at wmart, etc.
Oct 27, 2009 | Linksys PLE200 Wireless Adapter
We moved the washer to a different room. When we
Was the place where it was the original laundry room. If so outlet was probably a dedicated line not hook to any other outlets. Now you moved and plugged into outlet that is not dedicated other items are probably being used on same circuit or breaker is to small, should be 20amp.
Jul 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Will not load.
my old computer had a problem like this, i think the only way to fix a problem like this would be to reformat your hard drive and reinstall your operating system, which would delete everything on your hard drive...if you do not want to lose the files on your hard drive, you can hook up the hard drive to a different computer as a secondary drive and take the files you need off of it...then put the drive back in the original computer and reformat...after that just put back the files back on the original computer with a flash drive or an external hard drive...
cant think of another way to solve this
May 25, 2008 | Acer Aspire E380-UD420A (ASE380-UD420A)...
NO POWER AT ALL!
Does the power supply have its own power switch?
It is located next to where the power wire plugs into the back of the PC.
Jan 10, 2008 | E-Machines eMachines Desktop PC
JBL encounter
HI! Red14 happy holidays
Well, may be a lot things, from bad cable, welding inside , or bad resistor is burn. but check the cable, and if you can open the panel on inside speakers, try to figure out if the cable is not loose, or bad.
Nov 27, 2007 | JBL Encounter 2.1 Computer Speakers
NetGear FS605 (FS605SE) Networking Switch Logo
423 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
