Question about Acomdata HybridDrive E5 Hard Drive
My acomdata 500gb harddrive will not connect to any PC. I can hear the indication that somthing has connected, and then about one minute later the tone for something disconecting can be heard. Any ideas in what might be happening? it was working properly for the past 6 months.
  • 449 Answers
Power supply failure. Check the voltage on the 12V and 5V rails of the power supply (a DM-5127?) Make sure that the AC voltage is ZERO. If there is AC ripple current, the enclosure will seem like it should work, but will fail. Best to transfer the drive to a new enclosure if the unit is still under warranty.
Posted on Dec 20, 2009
  • 358 Answers
From what I can deduce here, it seems that you the hard drive probably has a bad sector on it.
Or there is a problem with the read/write head inside the hard drive.
In this case, what I would advise you to do is, unscrew the hard drive case and remove the Hard disk from the case, connect it directly to a system, not externally or through USB this time around, then get a software called NTFS DOS Professional. It is a software that works like magic when it comes to hard drive repairs.
If you know any other hard drive utility, apart from this, you can also use it. I just recommend this personally because that is what I use.
Insert it into your PC, start up your CD-ROM and let your system boot from CD-ROM.
It works through DOS, and it should be able to help you with it.
If this does not solve the problem, then I'm afraid you might need to replace the hard drive.
And if it repairs it, I would suggest that you just retrieve all your valuable files from it and don't fully rely on the hard drive again because of the hardware error it has developed. Just keep using it as a second.
If you cannot do this by yourself, just get a very good technician to do it for you instead.
Kindly keep me posted about the problem.
Hope it helps.
Goodluck.
Posted on Nov 23, 2009
My LaCie 500GB External Hard Drive stopped working. Before when I turned it on, I could hear it spinning but now all I hear is a clicking sound. When connected to my computer the computer no longer...
Sorry nothing to do your harddrive is dead. you might be able to open the case and replace the harddrive with a new one. Try searching google or youtube on how to do that.
Regards.
Mar 19, 2011 | LaCie Design by F. A. Porsche 160 GB Hard...
My mini max 500gb has just stopped working. i cannot hear the fan at all and all my other daisy chained mini max hard drives still work and register on my desktop
Your Imega external enclosure has malfunctioned. If you can, you need to take the enclosure apart and take the harddrive out and test it with a computer desktop that has sata connectable, if your computer is able to read, then your iomega harddrive enclose suffer malfuction, if the computer isn't able to read the harddrive through the sata connection, then your harddrive is bad.
Jan 30, 2011 | Iomega MiniMax (33464) 250 GB Hard Drive
My computer doesn't recognize my Acomdata 250 Gb Hard drive (HD). The computer pops a balloon saying that it could run faster with a hi-speed 2.0 port. I own a dell Xps m1210, the installation cd that...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Nov 27, 2010 | Acomdata 250GB External Firewire HD 250 GB...
My acomdata 250 GB Hard drive will show it has power but will not connect to my computer any ideas? I have tried a new USB cable but still nothing.
Nov 17, 2010 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Acomdata Hard Drive clicking noise
Sorry to tell you, but looks to me your Hard Drive is dead :S
As I think it's on warranty, better go to assistant, but tell them you need the info on your hard drive (if needed) or else they probably replace the HD with a remanufactured one.
Good luck.
Oct 12, 2009 | Computers & Internet
Acomdata HD500uhe5-72 cant be seen . on XP
Put it in the freezer overnight in a bag. For some reason it might be stuck in a read mode. Just because you did not tell windows to stop the drive does not mean you hurt it. When you go to use it again,
plug it in and turn it on, you should hear the drive start to spin, if not
you could shake it and see if it starts. Then after it is plunged in
and plugged into the pc, start the pc and wait till after windows is up and running, after 3mins, if not seen unplug, firewire and plug it back in and wait a few mins. If nothing, contact the company and see if it is still under warranty. I hope this helps you. Any other questions,please post back,everyone is more then happy to help you.
Feb 11, 2009 | Acomdata 500GB External Firewire HD 500 GB...
My external won't mount, the light works but it won't mount to my power book G4. help!
I opened up the harddrive and noticed that the copper magnetic film strip right above the USB port entry was lifted from the metal. I pressed it down and plugged the drive back in and it worked.
you just have to unscrew the drive on the 4 front side and two small ones on the side using two different phillips. then make sure and register the Western Digital drive inside because it has a seprate warantee. my acomdata is already out of warantee but if the drive ever fails again, I can have it replaced by Western Digital until 2011.
Dec 25, 2008 | Acomdata 500GB External Firewire HD 500 GB...
Acomdata external harddrive is not recognize on vista
I had a similar issue with windows 2008 and windows 7. the drive lost all its info and had to be reinitialized under both of those O.S.'s..
You can try that as long as it doesn't have any data you need.. Once you do that the drive will work and you can start using it. The file system under vista and above is slightly different than xp.
Sep 12, 2008 | Acomdata 500GB External Firewire HD 500 GB...
Hard drive goes out in the middle of copying
Most of the time the problem can be solved by using a cable that is really short and of good quality.
or try another usb slot and see whether the problem repeats.
Now if the external drive is FAT (most of them come from factory as FAT formatted) and u are trying to copy files grater than 4GB, it will fail as FAT cannot recognize files larger than 4GB. SO you may try to format the external drives into NTFS, if thats the case.
Jun 10, 2008 | Acomdata 500GB External Firewire HD 500 GB...
No recognized by any PC I try to plug in
I was just having the same problem... but someone I connected it to my computer, forgot it was connected, and when i got back everything was back again (needless to say i got another 500GB HD from another company and back up the first 500gb).
But if that didn't work, i was going to take the drive out and connect it as a slave to my computers MB, back it up, reformat it, and then put it back in the enclosure to see if it works again (at least i have my data).
$500 bucks?!?!? Shoot, send it to me and i'll do it for $299 (that includes a Western Digital 500gb External =)
Hopes this helps.
Dec 06, 2007 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Acomdata HybridDrive E5 Hard Drive Logo
476 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
