Question about Canon iPF700 InkJet Printer
Printhead cleaning the printer says to clean the printhead. in the manu i chose to clean it, but the warning won't go away. Does the printhead need to be replaced?
    Brigadier General:
  • 10,406 Answers
Turn the printer off.
Turn the printer on.
Restart your computer.
Try to print -- has the message vanished?
Posted on Nov 18, 2009
    Problem Solver:
  • 9 Answers
Before you spend $5-600 on a new printhead that could also dry out or clog .... replace the last new ink tank you installed with a new one from a reliable source to insure this problem is not actually a bad ink tank. After repeated tank changes, call Canon Tech Support.
Posted on Dec 06, 2009
Why am i getting blank copies from my printer
The chances are good that what U need to do is a printhead cleaning. On the printer if it has a LCD screen scroll through the menus and look for Maintenance or tools and then look for printhead cleaning . It can also be done through the software by going to the top left hand corner of the page U are trying to print and click on the button or File scroll down to print and click on that and that brings up a box with your printer name in it and beside that is a box called properties and look for maintenance or tools there. After the printhead cleaning it will ask if U want to print a test page - say yes if that page looks good -problem solved but it will probably take a few cleanings if U R getting blank pages now. Warning repeated cleanings use a lot of ink so only do what you need to. If after several cleanings U are still getting blank pages U might need to replace the printhead
Aug 03, 2014 | HP Business InkJet 2800 Printer
HP Photosmart B210a error message
Simple. Remove the ink and printhead. You can remove printhead by pulling gray latch up and sliding printhead up and out. Clean printhead gunk off using warm running water. Remove any ink gunk on the right side of printer if you see any. Turn printer off and on. See if problem went away. If it did, try putting the cleaned printhead inside printer again. If problem comes back, seems like the issue is with a bad printhead. Below are video instructions on cleaning head manually. The printheads are not same. B210 printhead is not the same with HP 6500, but instructions are same.
Jun 07, 2017 | HP DeskJet F4280 All In One Printer InkJet
Hp7580 printhead can I clean ink nozzle?
if you cane access the nozzle no problem then gentlly rub it with a toothpick soacked in alcohol to get off the pieces or a soaked qtip in alcohol and daub the nozzle
Nov 16, 2013 | Office Equipment & Supplies
After cleaning printhead printer says printhead needs cleaning
If that's the case, the printhead will need to be replaced. If your printer is still under warranty, you can contact our technical support team to have the printhead replaced. If not, you can purchase a printhead online at http://bit.ly/IZYhWo.
Also, make sure that you're using genuine Lexmark cartridges. Refilled/remanufactured cartridges might damage your printhead.
Oct 28, 2012 | Lexmark Pinnacle Pro901 All-in-one Inkjet...
Officejet K5400 Won't print yellow
Hi David,
Turn Off Your Printer Remove K&Y Printhead from your printer. Put the Printhead in the bowl in the same Position As in the Printer And Pour Little hot water in the bowl till the printhead is half dipped in the Water. Leave in for 15-20 Min. after that Clean the Printhead with clean clothes.. Must Ensure that no Water is in the Circuit of Printhead. leave the printhead for 30 min. After that put Back in the Printer. You will Get the Better result than ever BUT PLease Donnot use clean Printhead Utility immediately after this process use after the Day. If it Doesnot Work Then Clean the Printhead in Hot Water Several Times.. Do not Remove Printheads Regularly From Your Printer..
I Have the Same Printer And Suffered Same Problem A Month Ago with Yellow Colour...
Regards,
Sean
Aug 10, 2012 | HP Officejet Pro K5400 All-In-One InkJet...
When instaling new ink carchage it won't print clearly. Is there any printing Mantainace software that can downloaded.
Clean the printhead
If your printed output is streaked or has any incorrect or missing colors, the printhead
might need to be cleaned.
This process uses ink to attempt to unclog and clean the nozzles in the printhead.
This might take a few minutes and will use one or more sheets of paper.
To clean the printhead from the control panel
1. Load letter, A4, or legal unused plain white paper into the main input tray.
2. Press Setup.
3. Press the down arrow button to highlight Tools, and then press OK.
4. Press the down arrow button to highlight Clean Printhead, and then press OK.
The product cleans the printhead.
5. Press any button to return to the Tools menu.
To clean the printhead from the Printer Toolbox
2. In the HP Solution Center, click Settings.
Work with ink cartridges 1513. In the Print Settings area, click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Features tab, and then click
Printer Services.
The Printer Toolbox appears.
4. Click the Device Services tab.
5. Click Clean Printhead.
6. Follow the prompts until you are satisfied with the quality of the output, and then click
Done.
There are two stages of cleaning. Each stage lasts about two minutes, uses one sheet
of paper, and uses an increasing amount of ink. After each stage, review the quality
of the printed page. You should only initiate the next phase of cleaning if the print
quality is poor.
If print quality still seems poor after you complete both stages of cleaning, try aligning
the printer. If print quality problems persist after cleaning and aligning, contact HP
support.
To clean the printhead from the embedded Web server
2. Click the Device Settings tab, click Device Services in the left pane, select Clean
Printheads from the drop-down list in the Print Quality section, and then click Run
Diagnostic
Good luck................Pete
Jul 15, 2011 | HP Officejet 6500 Wireless All-in-One...
Blue and yellow will not print have replaced ink cartridges
Manually cleaning the printhead isnt difficult and could solve your problem. You need distilled or de-ionized water, tap water might work but i dont recomend it. You need a lint free cloth, dont use paper towels or anything that will leave material behind that will clogg the nozzls (a clean soft tshit should work tex Wipe lint free cloths work the best) . Heating the water will help. Remove the printhead look at the nozzles on the buttom. you should see 6 lines in a yellow area. you want to wipe with these lines not accross them. do not scrub or use circular motion. Wet the cloth area your going to wipe with well. put some pressure but dont break it and wipe a few times slowly. you can also soak the nozzles in warm or hot distilled water just only in very shallow water just enough to touch the nozzles do not submerge the whole printhead. you can also google manually cleaning inkjet printheads just use your best judgement some things people do to clean a printhead might damage them. If after manual cleaning and using the built in cleaning the prints1.gif still dont come out right call kodak and request a new printhead. I hope this helps! Don't Let this road bump turn you away from these printers they print nice prints and have low cost ink. Kodak and or I am not responsible for any data loss or any damage to any equipment that occurs as a direct or indirect result of following the procedures described above.
Dec 15, 2009 | Kodak 5300 All-in-One InkJet Printer
No colour
Hi!
Mostly it's a problem with the printhead in those case.
Try 4-5 printhead cleaning via the main menu of your printer. Press Menu. Choose 'Clean Printhead', press OK and chose the 'Intensive Cleaning' and press then OK again.
After doing this 4-5 times make a test print. When the problem persists, you can order a new PH from Kodak directly.
Aug 09, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Canon ip4300 service error b200 green and orange light keep flashing ink toner won`t move
Try this:
Pull the power cord out of the back of the printer.
Then move the printhead to the center and pull out the ink and the printhead. Clean the printhead and examine the bottom for burned areas.
With the printhead still out, close the cover and plug the power in and turn the power on. If your printer isn't damaged, it should go through all diagnostics and give you a solic green light. This means you probably need a new printhead.
Apr 17, 2009 | Office Equipment & Supplies
Prints faded
Hello mvjv,
To solve the faded prints you need to clean the printhead twice by going to the software and click the "?" mark icon on the upper right corner of the software window and then under General Links select Maintenance then choose Clean Printhead - do it at least thrice to unclog the printhead system. Then try making prints... If still cannot solve call Kodak Technical Support.
I hope I have been some of help.
Nov 07, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Canon iPF700 InkJet Printer Logo
568 people viewed this question
old marine
old marine
