Hello - Interior cleaning after convection, mix or broil cooking:
Spatters may occur because of moisture and grease. Wash immediately after use with hot, soapy water. Rinse and polish dry. Harder to remove spatters may occur if oven is not thoroughly cleaned or if there is long time/high temperature cooking. If so, you may wish to purchase an oven cleaner pad with liquid cleaner within it-not a soap filled steel pad-for use on stainlessor porcelain surfaces. Follow manufacturer's directions carefully and be especially cautious not to get any of the liquid cleaner in the perforations on the wall or ceiling or any door surfaces. Rinse thoroughly and polish dry. After cleaning the interior thoroughly, residual grease may be removed from the interior ducts and heater by simply operating the oven on 450 F for 20 minutes without food. Ventilate the room if necessary.
Interior cleaning after microwave cooking:
Cleaning is easy because no heat is generated to the interior surfaces; therefore, there is no baking and setting of spills or spattering. To clean the interior surfaces, wipe with a soft cloth and warm water. DO NOT USE ABRASIVE OR HARSH CLEANERS OR SCOURING PADS. For heavier soil, use baking soda or a mild soap; rinse thoroughly with hot water. NEVER SPRAY OVEN CLEANERS DIRECTLY ONTO ANY PART OF THE CONVECTION MICROWAVE OVEN.
HOW
TO CLEAN MAYTAG STAINLESS STEEL REFRIGERATOR:
Do
not use abrasive or harsh cleaners such as window sprays, scouring
cleansers, flammable fluids, cleaning waxes, concentrated detergents,
bleaches or cleansers containing petroleum products on plastic parts,
interior and door liners, or gaskets. Do not use paper towels,
scouring pads, or other harsh cleaning tools.
How
do I clean and care my stainless steel surfaces such as refrigerator
or any other stainless steel made appliance?
NOTE: Just
because a cleaner is a liquid does not mean that it is nonabrasive.
Many liquid cleaners designed to be gentle on tile and smooth
surfaces still damage stainless steel.
Avoid Citric acid
-it
can discolors stainless steel. To avoid damage to the finish of
your stainless steel appliance, do not allow these substances to
remain on the steel finish:MUSTARD,TOMATO JUICE,MARINARA SAUCE,CITRUS-BASED SAUCES,CITRUS-BASED PRODUCTS.
If
you want to clean safe and keep the sparkling steel you can purchase STAINLESS
STEEL WIPES this wipes is ideal for cleaning food spills,grime and
stains leaving surfaces shining like new. This wipes is for stainless
parts only make it sure this stainless steel wipes to come into
contact with any plastic parts.BUT
THE SAFEST WAY TO CLEAN STAINLESS STEEL SURFACES IS TAP WATER WITH
CLEAN WHITE CLOTH.
