Question about Bosch Exxcel KGV35421 Bottom Freezer Refrigerator
Where do I find the model number? I have broken the bottle holder and need to get a replacement..
  • 71 Answers
Look inside the refrigerator for a tag with model & serial number.
Posted on Nov 18, 2009
Howe do i fix ricoh 2060 code sc342?
there are more possible solutions and cause of this error. First of all the sc code and the sign for no toner are connected. The sc code mean that is there is no toner in the developer hopper. First of all if this code appeared after you replaced the developer, you will need did you connected the two connectors that connect the developer unit with the machine, and also check do the developer unit is properly inserted into the machine. But if this problem ocured before you replaced the developer, than the problem is with the toner holder. Open the front door and check the white hook that pulls out the toner bottle cap when the bottle is home position. This white hook is located on the back of the toner bottle holder. you will notice it when you pull the bottle from 90 degrees angle into home position how it slides on the metal rail located next to the toner bottle holder on the right corner of the machine. If it is broken or out of position than that is the problem. If this part is ok that open the front door and put something like a screwdriver in the upper taster that detects do the front door is closed its located above the red main switch, you will notice a hole with a bronze colored plate inside. The other switch is located on the front right bottom corner next to the third paper tray, you will notice a hole in the olive-brown color plastic. When you will insert something into this two holes the machine will think that the front door is closed and it start the toner loading process. While the machine run, with the door open notice do the toner bottle rotates.If does not rotate than the motor that rotate the bottle is not working. If non of this help than tell me and i will tell you other possible solutions.
Mar 06, 2015 | Ricoh Toner for Aficio 1060, 1075, 2051,...
Replacment parts
perhaps from the mfg not here
Aug 26, 2014 | Nextar Q4-01 Car GPS Receiver
I have a hansgrohe shower. And the hook that holds the hand held shower is broken. How do I replace the hook ?
In order to give accurate instructions on replacement of a slider or holder we will need to identify the model in question. If you know the model number of the unit or need help identifying it feel free to contact me at Hansgrohe Tech. 1-800-334-0455. Press 2 for Tech and ask for David Scarborough. I'll be happy to help.
Apr 11, 2013 | Home
I dont know how to put my water bottel on my magna bike
Many bikes are sold without a water-bottle holder, but have a place to install one. You will likely have to purchase a water bottle holder, and install the water bottle holder yourself.
Most bikes have a spot for one on the Down Tube. (The Down Tube is the part of the frame that runs from the handlebars to the pedals.) Look on the top of the Down Tube, and see if there are two screws. Likely you will need an allen wrench to remove them and install the holder.
Feb 25, 2011 | Schwinn Cycling
Toner light and message won't go out
Hello sir; You have to replace toner senser, it located at the bottom of developer unit. have any problem please contact us, good luck!
Jul 15, 2010 | Savin Office Equipment & Supplies
The paper roll holder is broken on one side. Can
For most models, the holders can be replaced. You can try Universal Paper Arm Holders if you can't find one for your specific model.
Mar 25, 2010 | Office Equipment & Supplies
Error code E000019-0000
Hi this is only indicating a dirty waste toner bottle neck.
It is easy to solve.
Take a star screwdriver,remove the one screw of the left lower panel.You will find the panel at the left-lower side of the machine,the side were you have to open to remove paper jams on the fixing side of the machine.
After removing that panel,remove the bottle remove the toner inside the bottle clean the NECK of the bottle inside and outside and put the bottle back in it's place.Put the panel back and switch machine on and off.
THIS WORKS ALWAYS
Jan 05, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Print Cartridge Holder Failure
I had the same problem and just ordered one directly from HP. I called 800-474-6836 gave them my model number and serial number and they set me right up. Give them a try. Hiram896
Oct 04, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Bosch Exxcel KGV35421 Bottom Freezer Refrigerator Logo
316 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
