Question about Dryers
When the dryer starts up it makes a banging noise, like the drum is not balanced. Also when it stops it make the noise
  • 95 Answers
Sounds like one of the large drum sprins have broken or come of ther should be 3 of them making the concrete wheight un balanced
Posted on Nov 18, 2009
Wk447 tumble dryer makes banging noises when working
could be the drum is out of balance turn the drum by hand if you can and see if is loose or a wight has come off
May 14, 2015 | Dryers
Drum makes loud banging noise.
Maybe the heat in your dryer over time has melted weak glue and loose components are hitting against the drum
Jan 16, 2012 | Frigidaire Electric Dryer
Dryer suddenly started making a loud banging sound like a washer out of balance. The drum still turns. I have disassembled the dryer and the belt looks ok and the rollers seem ok. It was very sudden onset....
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 24, 2011 | Dryers
Dryer is making a loud banging noise.
there are bushings or rollers at the front of the drum that do wear out this will cause the thumping as it turns. A local appliance repair place may be able to source out new guides for you.
Feb 22, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Repeat banging noise in dryer
Sounds as if the drum supports are bad. Replace the rollers that the drum glides on and should be good to go.
Feb 01, 2010 | Kenmore Dryers
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Maytag Neptune MDE9700AYW Elec. Dryer. Drum Not Turning
the problem is with its motherboard .. i too had the same problem.. ask the repairing persons to change the motherboard if it is warranted. ( but there is no other way)..
Apr 21, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Dryer has a banging noise
It Is fixable.All you need to is try to balance the load or a perfect concrete flat surface for the machine.
If the problem still persists, then during the previous vibrations, the shocks or the drum bearings might have been damaged, you might have well replace them to avoid further problems.good luck.and please post your comments.
Apr 11, 2009 | Whirlpool Dryers
Banging noise
You may have had a foreign object slip under a loose drum baffle. Manually rotate the drum to locate wwhich baffle it is in.
Apr 06, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
122 people viewed this question
Top Dryers Experts
