Question about Refrigerators
Cannot locate the water filter - Refrigerators
  • 71 Answers
Look at the bottom, if not obvious, perhaps behind a grill. Ours just has a cap, turns & slides out. (Kenmore/Whirlpool)
Compare filter prices: Whirlpool filters - the same PUR filter as the Kenmore - was half the price from a parts store rather than from Sears. Either a parts store or appliance dealer can also tell you what kind of filter you need & how to access it.
Posted on Nov 18, 2009
Why my refrigerator is leaking water from the top where the water filter is located?
Shut off water supply valve. Relieve water pressure by dispensing water. Unscrew water filter. Examine to see if the gasket is damaged or if filter was loose and just needed tightening. Or simply replace water filter with the correct water filter that your GE refrigerator calls for.
Jul 19, 2014 | GE Refrigerators
Where is the water filter on a 1997 side by side Roper
Do you have a manual for the refrigerator to check he same
Sep 08, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
We are trying to replace the ice maker filter on a Maytag mf2557hes. Where is it located? Does this Maytag Refrigerator have a filter?
Maytag brand water filter removal and replacement:
refrigerator_maytag-filter.jpg Removing and replacing a water filter
There are two different types of Maytag brand water filters. Each one is removed in a different manner, depending entirely on where it is located in your refrigerator. There are two main locations. Select your filter location from the options below for specific removal and replacement directions.
  1. The upper right corner of the refrigerator compartment.
  2. In the center of the ceiling of the refrigerator compartment.
Jun 12, 2011 | Maytag MFF2557HES Stainless Steel French...
I have a GD22DQ model side by side whirlpool gold refrigerator. we have looked through the manual and we cannot find were to put the water filter. the manual shows a dial at the bottom of the fridge but...
Hello Dollar1392,
I understand that you can not locate the water filter for your unit. If you have a water filter in your unit it will be located in one of two locations at the bottom of the unit in the grille or in the top of the refrigerator section on the right side in the rear corner. If the filter is not located at one of these locations then there is no filter on your unit. You will need to put an in-line filter in your water supply line.
Thank you for choosing FixYa.com if you have any further questions please post back to the thread.
Justin
Apr 23, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Location of water filter on maytag model msd2351hew
Hi.The water filter is located in the upper right-hand corner of the fresh food compartment. You will need to turn the filter, counterclockwise, to release it form the housing.
Dec 04, 2009 | Maytag Refrigerators
Replace water filter
HI. Frist, make sure that your unit is equipped with this feature. if you have varifyed that your unit is equipped with a filter fo this nature, the location will be on teh front, lower grille area. This is the most common location for a water filter. Simply kneel down, and look at the bottom section of your unit, on the front. There is a grill, with a circular cut-out. This will be where the filter is housed. You will need to turn the handle counter-clockwise to release.
Now, in newer units, the filter will be located inside the refrigerator compartment, just above the top shelf, in the right, or left corner. if both locations do not show a filter, check the backside of the unit for a 8 inch cylindrical device.
Nov 19, 2009 | Whirlpool Refrigerators
Where is the water filter located on a kitchenaid ksrp25qdwh00
This particular water filter is known as a ``in line water filter`` and is located at the BOTTOM of the fridge at the LEFT hand side. located in the grill at the bottom. first you must remove the filter cap and then It simply twists out for easy replacement. part number for the water filter is 2255519. and should be replaced based on a 6 month period or the amount of water filtered. hope this helps
Thanks
Oct 12, 2009 | KitchenAid Superba Architect KSCS25INSS...
Where is the water filter located on the Samsung SRS2028CSS
food compartment.
1. Remove blue bypass cap and
retain for later use.
2. Remove sealing label from end
of filter and insert into filter head.
3. Rotate gently clockwise until
filter stops. Snap filter cover
closed.
4. Reduce water spurts by
flushing air from system.
Run water continuously for
two minutes through
dispenser until water runs steady. During initial
use, allow about a one- to two-minute delay in
water dispersal to allow internal water tank to fill.
Sep 10, 2009 | Jenn-Air JFC2089HT Bottom Freezer French...
Can't locate the water filter. water has a bad taste
The base grille water filter is located below the freezer
compartment door. Depending on your model, you may have a filter that is installed behind the base grille or a filter that is installed through the base grille.
May 23, 2009 | Kenmore Refrigerators
Location ofwater filter(s) whirlpool modeled22dq
Hi, The filter is located behind the kickplate. You can see the handle for the filter in the kick plate. I believe you turn the filter handle Counter clock wise to remove it. It will tke a little bit of force. Yes this filters the water in the door.
Let me know If I canassist you further. Thanks
Vic
May 17, 2009 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
147 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
