Question about Lanzar VIBE266 Car Audio Amplifier
Fried Amp My LANZAR Vibe266 fried the other day and i think i can repair it if i had the wiring diagrams. Anyone know where i can get them?
The ground wire is burn where it connects to a metal bar that looks like a shunt and right across from that is another burnt spot on the other shunt bar.
Posted on Jan 11, 2008
  • 631 Answers
It's unlikely that anyone will have a schematic for this amp. Lanzar has refused to provide them in the past. What 'fried' in the amp?
I need to wire 2 12" DVC Lanzar MAXP124D to an 8 ohm load. Had it wired at a 2 ohm setting and it would over heat my amp. So tried to wire it to 8 and it wouldn't work. Need help.Thanks.
Your 8ohm channel is fried why happened was you ran 2 12s in an 8ohm load and turned it down to 2ohms the speakers was pulling all the power and that made it over heat and when it over heated it fried you're amp. It ain't no good you can't fix that
May 11, 2015 | Lanzar Car Audio & Video
Lanzar vibe266 2000 watt stays in protect mode
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty .
.A thumbs up would be greatly appreciated if this answer is helpful to you. lanzar-vibe266-2000-watt-stays-in-zb4bomd1rt4qms0dqd12kkt2-3-0.jpg
Feb 05, 2013 | Lanzar VIBE266 Car Audio Amplifier
Will a Lanzar Vibe 286 4000 watt amp push a power acoustik fubr 12 700 rms 1800 max ....
Yes it should do the job. You will need to wire the sub in series and make sure you have a 4ohm load on the amp. It should be right at around 700 watts RMS @ 12-13 volts.
May 18, 2012 | Lanzar VIBE266 Car Audio Amplifier
2 ohm speakers wont work on a lanzar max pro 4000 watt
The 2 ohm stable rating on the amp is PER channel meaning that you could effectively hook up a 2 ohm speaker or a 2 ohm load to each channel without the amp getting f"d up-butin bridged mode it will only be 4 ohm stable. to achieve a 4 ohm load with your sub the type x wire the coils in series that will get you at 4 ohms to run in bridged mono .But you will get the exact same amount of power if you wire each coil to one channel of the amp as bridged mono sees the sum of your 2 ohm channels combined-Hope that helps.
Jun 08, 2009 | Lanzar VIBE266 Car Audio Amplifier
Fried Woofer
The problem are worsen that before. It is wisely to replace both left and right amplifier
IC, but make ensure that the power supply feed a good amount of voltage to amplifier,
Also a strong good signal. Be sure to measure it.
Jun 22, 2008 | Alesis M1-Active MkII Main / Stereo...
Bridged lanzar amp
no idea, but i think you should leave the subs the right way in the box
Feb 15, 2008 | Lanzar VIBE266 Car Audio Amplifier
Lanzar vibe266
Please write more how you have made connections. I need schemtaics to help you.
Jan 26, 2008 | Lanzar VIBE266 Car Audio Amplifier
Now speakers
Check your connections on your speakers themselves, also check your connections of the speaker wire to your amp and also check for any cuts or damage throughout your wiring as this my be caused by the + and - wires that touch
Mar 14, 2007 | Lanzar VIBE266 Car Audio Amplifier
Amp LED flashes on but right back off
This sounds like a problem with the power input to the amplifier; it's possible, but unlikely, that your CD player is causing it. Before you can do any real troubleshooting, you need a voltmeter. When your CD player is turned on, you should get a voltmeter reading of around 12 volts at the amplifier's remote terminal and B+ (power) terminal. If your main power wire doesn't show voltage, check for a loose or corroded connection at the battery or fuseholder, and try replacing the fuse (even if it looks okay). If there's no voltage on the remote wire, it may be pinched or shorted between the CD player and the amplifier, or the CD player may be faulty. If you get a good voltage reading on both wires, but the amp won't turn on, then you have a problem in the amplifier.
Mar 05, 2007 | Lanzar VIBE266 Car Audio Amplifier
My vibe 286 4000 watt lanzar amp wont stay on..
Check your speaker load. It probably should be 4 ohms per channel. Also, if you are bridging then you must double your ohms load. It may be that your old amp could tolerate a lower impedence (ohms load) than the new amp. Do this now so you don't fry your amp. Good luck.
Mar 03, 2007 | Lanzar VIBE266 Car Audio Amplifier
Lanzar VIBE266 Car Audio Amplifier Logo
139 people viewed this question
Top Lanzar Car Audio & Video Experts
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
