Question about Philips FR951 Receiver
No light on display Philips FR951 - Philips FR951 Receiver
Philips LED TV problem.when TV is on no back light no display only key panel light is on when pressing key indicator is blinking what's the solution?
Ask Philips at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=ca&userLanguage=en
Mar 01, 2015 | Philips Televison & Video
Display
Check and replace the back-light inverter board. Contact any experienced service technician, or the authorized service centre for Philips. Gopakumar Gopalan Google
Mar 29, 2014 | Philips 32PF7320A 32 in. LCD Television
Philips as655 no display of graphics on tuner etc
Ive found with the AS655 Ive been working on,the lights will come on after about2-5 mins of use.this isnt a fix,just a comment.
May 22, 2009 | Marantz CC-4000 5-Disc CD Changer
On switching Philips Tv type:21PT 240B/94R no sound,picture
I have Philips CTV 21 PT 240B/94R. and this time a problem are when set on chenel are not stop to change only forward and bottom right side Display Scan+
Jan 29, 2009 | Televison & Video
What is a display panel for philips plasma Ambilight
The display panel costs about 600$ by itself. It's a metal casing under all of the boards and I definatly would NOT recommend a DIY'er to do it unless you have a digital camera to take pictures of step by step and different colored markers to designate the connectors.
The easiest way to tell a faulty display panel (if it lights) is to gently press on the screen until you see a "ripple effect" in the color. Be warned,pressing too hard can cause pixels to "die" and remain discolored permanently
Nov 03, 2008 | Philips 42MF130A 42 in. Plasma EDTV
Display Problem for Philips FR951PBK01 receiver
hey i own it too mine same thing but when i turn mine on i use the selector and the display comes back on so push power then spin the selector knoby thing it should work
Jul 29, 2007 | Philips FR951 Receiver
Only sound, no picture
turn the AC power off and on again, this worked several times
Jul 05, 2007 | Philips E-box FTR9964 Video Capture
Green light goes on and off
Hi, aside from the blinking green light, does it display something like "No Signal", if it is it might be possible that it's not your monitor that is on the brink, it is possible that your computer isn't turning on and therefore the monitor cannot display anything since there is no video signal from the computer. Perhaps you can try plugging the Philips monitor to another PC that is known to be operational to check if it will display something. If it does then the other PC is not working, if again no display or green light blinks, then the Philips monitor would require service. You might have to have a qualified service personnel to have a look inside and further diagnose the proble. I wouldn't recommend that you try opening the monitor since it's a bit complicated. Hope this be of some use to you and pls post again how things turn up. Kind regards.
May 18, 2007 | Philips 150S (White) 15" LCD Monitor
55 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
