Question about LG VX8350 Cellular Phone
How to lock front keys LG VX8350? I bought a $30.00 holder that activates the front buttons, using up the battery by keeping the outside deisplay lit all the time. Thanks,
I bought this verizon phone from goodwill. It a lg vx8350. it has a lock code on it. I cannot opperate anything on it unless i know that password. Can you please help fix that.
sorry the phone has been locked down, you need to contact the carrier, and hope the phone has not been reported stolen......
Dec 19, 2010 | LG Cell Phones
Just bought a x reg ford puma but the key fob does not work, bought a new battery and fitted it, needs re-programming but don't know how to do it.
Telephone: Fax: VAT Registration No.:
Infrared remote control
NOTE: Infrared emitter can be seen at front edge of key.
System operation
Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system.
Programming
When
Key batteries completely discharged. Key batteries not replaced within 15 seconds. Key added or replaced. System malfunction.
How
Obtain all keys fitted with remote control. Turn ignition switch to position I. Wait approximately 10 seconds. Ensure clock LED illuminates.
NOTE: LED illuminates for approximately 5 seconds.
Switch ignition OFF and remove key, while LED illuminated. Programming mode activated for approximately 20 seconds (LED illuminated). Proceed as follows: Point key at receiver (located near interior lamp). Press and hold unlock button Fig. 1 [1]. After approximately 1 second key LED will flash once [3]. Press lock button 3 times Fig. 1 [2]. Release unlock button Fig. 1 [1]. Continue to point key at receiver until LEDs in clock and key have flashed 5 times. Ensure LED remains illuminated. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode and extinguish clock LED: Switch ignition ON and OFF. Wait approximately 20 seconds.
NOTE: A maximum of 4 keys can be programmed. Fig. 1
Radio frequency remote control
System operation
Pressing tailgate release button twice within 3 seconds unlocks the tailgate - if fitted. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system. Interior lamp illuminates when disarming system.
Programming
When
How
Obtain all keys fitted with remote control. Fasten seat belts and close all doors. From position I, turn ignition switch as follows: To position II. To position I. To position II. To position I. To position II. To position I. Programming mode activated for approximately 20 seconds. LED or fog lamps ON warning lamp illuminates (some models) or the system will emit an acoustic signal to indicate start of programming mode. Proceed as follows: Type 1: Press and hold unlock button Fig. 1 [1]. Type 2: Press unlock button Fig. 2 [2]. Ensure clock LED or fog lamps ON warning lamp flashes (some models) or wait for acoustic signal (indicates correct programming). Wait 2 seconds. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode: Switch ignition ON. Wait 20 seconds.
Aug 25, 2010 | Ford Focus Cars & Trucks
Which button is flash on a LG VX8350?
WES, There is never any button for the flash. It is connected to the shutter button of the camera. the idea is that the flash has to go at the exact moment when the shutter opens. Hence it can only be controlled electronically. If you want to operate the flash, the in the camera settings you must activate the flash (as auto). Whenever the flash is needed as per the light conditions. it will operate.
Aug 24, 2010 | LG VX8350 Cellular Phone
My verizon LG VX8350 just blinks the Verizon logo on and off
Refer to this page:
http://www.fixya.com/support/t1798043-cell_phone_turn
Jul 06, 2009 | Verizon Communications LG VX8350 Cell...
Can I switch sim chips between 2 LG VX8350 phones? How is it done?
yes, the sim card is located under the battery in most phones just pop it out and put it in the new phone and voila.
Jun 27, 2009 | LG VX8350 Cellular Phone
Hinge broke on my Verizon LG VX8350 phone
I called customer service and spoke with someone different who is sending me out a new phone free of charge.
Jun 22, 2009 | LG VX8350 Cellular Phone
The outside camera on my phone always comes on in my pocket. How can I put my outside camera on lock and still use my camera while my phone is flipped open??
this might work it did it to mine 2, the camera button on the side might be jammed. try to unjam it. another problem is that it might be to sensitive
May 28, 2009 | Verizon Communications LG VX8350 Cell...
Cracked screen LG vx8350
you will be able to just replace the lcd
thanks
erik
Feb 26, 2009 | LG VX8350 Cellular Phone
Central locking not working on key.
Before you spend bigger amount, check the battery in the key. Usually a CR2032 battery can be find there. (Open the Keyfob by inserting an object into the key ring holder and pulling the top and bottom apart, Seperate the two halfs, Open the top half to expose the battery... )
Nov 28, 2008 | 1998 Audi A6
Locked white chocolate phone-can't unlock it.
try taking out the battery, then put it back in and turn it on...if that doesnt work just call verizon.
Dec 26, 2007 | LG CHOCOLATE VX8500 Cellular Phone
LG VX8350 Cellular Phone Logo
232 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
