Question about Watches
The wind up mechanism doesn't work - Watches
    Scholar:
  • 110 Answers
So I am assuming you have a mechanical watch then that does not use a battery. But then again you could have a self winding watch that has a "wind-up" mechanism. If you have a valuable watch then take it to a good repair shop. If you have an inexpensive watch then get a new one. If you have a watch worth less than $50 and you really like it and want it fixed, then a shop can put in a new movement for you. Best of Luck
Posted on Nov 19, 2009
The clock gains as well as striking on the hour only the once tried setting it right but have had no luck yet what I forgot too mention int a antique clock
needs the mechanism taken out of the casing
and checked
something stripped or broken of its winding part
Jan 30, 2017 | The Watches
Watch stopped working
Try winding it by hand. If it will wind manually and works then the problem is the 'winding mechanism' If it won't wind by hand then you need a watchmaker. Find one that is certified if possible, they are the most schooled.
Oct 08, 2012 | Fossil Ansel - ME3022 Analog Watches : One...
Just a quick question On my Omega Double eagle, I went to mexico for the week left my watch at home and when I return I gave it a shake to start the movement being it is a chroncile watch and for some...
A mechanical watch will tend to stop in the same place if an internal gear is slightly unbalanced and/or there's a spot of grease/dirt that makes that particular point on a gear slightly more difficult to pass. I've often seen watches with day/date indicators stop just around midnight, as it takes more energy to advance those dials than just move the hour and minute hands.
Try winding your watch with the crown as opposed to shaking it to wind it via the automatic rotor. Actual winding will bring your mainspring up to full power much faster than a whole lot of winding via automatic rotor. See if this changes the behavior of the watch. If it doesn't, you probably need to have a watchmaker take a look at the watch. He or she will probably recommend cleaning the movement to clear any dirt that might be causing the problem.
May 08, 2011 | Omega Constellation Double Eagle Gold &...
My watch is not working,,is there a battery i must change?
Your watch is a self winding type and does not contain a battery.
To wind it up, swing it from side to side gently for a few minutes (this operates the self winding mechanism).
Self winding watches thrive on use and will only run for 2-3 days if not worn.
Mar 05, 2011 | Rolex Daytona 116520 Wrist Watch
How do you get started to wind a BMW watch. There is no resistance when I wind the crown. There does nt seem to be any plastic or anything in the way. I ve set the date successfully. Its a BMW Chrono...
mcdevito75 here, BMW watch, nice watch, Actually there are 2 ways to start winding an automatic or self wind watch. Since you feel no resistance in the winder (crown) which if you did, would mean the automatic mechanism is attached by gear to the mainspring and winding the crown (stem) would start the winding process. Without any resistance winding the crown, your automatic mechanism is free-lance as a way of saying, in your watch which simply means your BMW watch winds solely on wrist / arm motion. First, make sure you hear the automatic mechanism moveing inside the watch when you move the watch in almost any direction, now simply hold the watch in your hand and with a rocking motion, say from 12--to 6 rock your hand back and forth for about 30 seconds. You can also make circular motions with the watch in your hand for 30 seconds, any motion that will cause the automatic movement in your watch to move will, start the winding process. After you see you watch has started, simply wear your watch to keep it wound.
Jul 31, 2010 | Bulova Watch
Watch winding is not holding
Two words: Wind it! When any self-winding (automatic) watch runs down from not wearing it you have to manually wind it to get it going again. Once you've done that the movement of your wrist will cause the self-winding rotor mechanism to keep it running as long as you are reasonably active and wear it everyday. Just wind it about 40 turns and you'll be good to go. Oris is a great watch company and you should enjoy it for many years.
Apr 16, 2010 | ORIS Watch TT3 Day Date 63575887067MB
Have old Mickey Mouse self winding watch. Bought
I will explain from the last question asked. To get it going you have to visit your nearest watch repair shop and ask for estimate. Shop owner told you things he/she do not understand at all - self winding watches CAN NOT BE OVERWOUND, so, there is the question: are you sure this watch is self winding? I've experience of 26 years of watchmaking and have never came across Mickey Mouse watches having self winding movements. As far as I know, all MM watches are battery driven, but in case if you really have the mechanical one - you are lucky. That means there were past times when those watches were fitted with mechanical movements and now they are rarities. Even if your watch is not self winding, but is mechanical (not battery driven), visit your nearest watch repair shop and ask to check this watch out. In case if it is mechanical - pay the money and get it fixed (you will be a winner anyway). If it is battery driven - put it on your shelf where your's mother in law picture is and treat it accordingly. Rate me , plz.
Feb 18, 2010 | Disney Watches
Kenneth cole k3771, is the self-wind function working?
Self winding watched should not need to be wound as long as they are being worn.
To tell if the self winding mechanism is working, hold the watch close to your ear (hold it vertical, as though it was on your wrist) and rock it gently. You should be able to hear a ratchet operating (a soft clicking noise).
I can't help thinking your suspicion about the mechanism having failed, sound very likely.
Jan 05, 2010 | Kenneth Cole Chronograph Watch for Men
I HAVE A CROTON AUTO WATCH I CAINT GET STARTED
If it does not wind automatically or with the turning of the crown then something is not working in the winding mechanism. If this is a new watch it needs to be sent to the store where purchased for a replacement. If it is not new but under warranty it should be sent to the manufacturer.
If it is out of warranty it can be serviced by a watchmaker. Generally if the watch won't wind it could be a broken mainspring, a broken wheel in the winding mechanism, a broken auto wind weight or even a screw that has come loose and is blocking the weight or gear train of the winding mechanism.
There isn't an easy fix that you could do to get this running.
Hope this helps,
Ken
Yellowstone Watch Inc.
Oct 05, 2009 | Bulova Watch
Red hand for dual timezone
If your watch has mechanical- self winding movement, then ALL the gears, hands and functions are mechanically driven and executed. None of the hands can be winded, as the movement of the hands is the consequence of the releasing power of the winded mainspring. All hands (including dual time zone hand) can be udjusted only to the required time and the rest is done automatically by the gears, cogs and levers.
If the dual time zone hand is not functioning properly- there is some mechanical fault and you will have to get the watchmakers help to sort it out.
Do not forget to rate, please.
Mar 07, 2009 | Breitling Navitimer A2332212 G5 431A watch
Watches Logo
170 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
