Question about Samsung SGH-U600 Cellular Phone
How do I sync my samsung phone with in car bluetooth acadia 2010
2010 gmc acadia head bolts torque spec?
what motor ?
only found this gmc acadia specific forum
http://www.acadiaforum.net/index.php
Sep 18, 2016 | 2010 GMC Acadia
How to I change the headlight on my 2010 GMC Acadia?
Search "headlamp replacement 2010 GMC Acadia* & got a number of hits. Suggest you try and select best fits.
Jun 16, 2015 | 2010 GMC Acadia
I have a problem with my samsung e1410 bluetooth,and display the message "initilising"
try resetting the Bluetooth headset. and restarting your phone.
after restarting your phone go to bluetooth and delete the headset off the list of Bluetooth devices. Turn on your bluetooth and sync it with your phone. should work after that
Feb 28, 2011 | Samsung Cell Phones
How do i sync my samsung galaxy s to my ford f150
If you have SYNC GEN 1, v 3.1, you can pair the phone without too much difficulty. You turn on the Bluetooth on the phone and make visible before you turn on your key. Scroll through the SYNC menu to the pairing function and the number should appear on your SYNC screen. Type the pairing number into your phone. It may take a couple of tries to get the phone to find your SYNC. It does eventually do it.
The music player on the phone plays through the speakers, but the steering wheel controls have problems if you want to advance to the next track on the MP3 player. Neither Ford nor Samsung seems to have an answer to how to make this function work--some kind of software oversight in the Bluetooth version on the Galaxy S phone.
Jan 06, 2011 | Car Audio & Video
I have recently got a Samsung Galaxy S I9000 and when I try to connect to my blueant st3 a message comes back that the blusant rejects the pairing with the phone. I used to use the bluseant with a nokia...
Darrell 12/11/2010. make sure you have the phone set to sync then press green button on ST3 until it ask what language you require keep it pressed until it states on the screen that you want to sync press ok and you will find that it has connected. You can use the same system to sync it to an I Phone as well
Nov 06, 2010 | Blueant Blue Ant 091193 Supertooth II...
My bb 8310 AT&T device won't pair with a headset or with my ford fusion
Make sure you have the correct password for your phone. Also look in your fusion manual as to the correct steps needed.
  • Press the Power Button. // This is on a 2010 Ford Fusion.
  • Then you hit the Phone Button.
  • It should say “No Phone Paired” that means that no phone has been paired with this.
You now have a choice of options:
  1. Add Bluetooth device
  2. Connect Bluetooth device
  3. Set Primary Phone
  4. Set Bluetooth On/Off
  5. Delete Device
  6. Delete all Devices
You want to choose Add Bluetooth Device, press OK
  • Then on your mobile, turn your Bluetooth On.
  • Setup Bluetooth – Search
  • Now it’s searching for it, when that gets full, Click Sync.
  • Then you’ll want to enter the PIN number that’s on the screen.
  • Say YES to connect to Sync.
  • Now screen on dash will say your mobile phone
Mar 26, 2010 | RIM BlackBerry Curve 8310 Smartphone
Verizon V9M bluetooth cell phone does not fully work with car
I have the same problem and thus far my research shows that the V9M is NOT a supported phone on the 2010 E class. You can store manually numbers into the car's system.
Aug 23, 2009 | Cell Phones
Using Bluetooth to Synch iPhone with Lexus ES350 2009 Phone Book
I think Lexus uses Bluetooth Object Push Protocol (OPP), which means your phone must support OPP. I don't think iPhones support OPP, which means you are SOL. As you noted, there are only 2 workarounds: 1) borrow a phone that supports OPP, or 2) buy a better phone (for example, the motorola droid).
Jul 11, 2009 | LG VOYAGER VX10000 Cellular Phone
How to sync phone with Saab 2003 / 9-3, with bluetooth device?
Sorry, the original Swedish version of the 9-3 had the bluetooth capability but GM removed it for cost reasons. GM has ruined Saab in many ways. There is no way to sync your phone with your 9-3.
Nov 29, 2008 | 2004 Saab 9-3
Samsung SGH-U600 Cellular Phone Logo
171 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
