Question about Maytag MAH2400A Front Load Washer
Mah2400Aww model has error codes 3E and od what do they mean and how do I fix.
5 Suggested Answers
SOURCE: Maytag front loading washing machine
3E has something to do with the motor control. Apparently the design of this machine allows a water leak either from the water intake box or down a rubber hose which runs along with the motor wire harness. The water tracks to the harness and motor and shorts the whole mess out. a.k.a. fried motor.
pull the back plate off (3 screws) and look at the motor where the wire harness plugs into it. Notice a bunch of green stuff- that is corrosion from the electrical short circuit causing your problem. See the rust build up on the side rail below the motor (as there will be none on the side adjacent) this is indicative of a water leak.
Our machine started doing this within the first week and we had the "service" people come out and "fix" it, but it appeared they did nothing. When I opened the machine up I discovered the problem when I ohmed out the rotor contacts in the motor wire harness and found it to be open instead of the factory specs of appx 2.5 ohms.
Maytag (now Whirlpool) does not want to send me a new motor and harness because of their bad design. The machine is a sealed unit only 23 months old. Note to all...do not buy Maytag or Whirlpool. That Maytag repair man is sitting on his bum because the company does not care about their consumers and their cheaply made products (sold at high markups).
If you want pictures write me at aboxoffrogs@optonline.net
Posted on Dec 24, 2007
SOURCE: Maytag MAH2400A Front Load
how do you install a new control board
Posted on May 11, 2008
3E = Drive system is not working correctly. Bad windings, speed sensor, wiring connections or Control Board.
Posted on Aug 25, 2008
  • 296 Answers
SOURCE: cycle stops 3E code appears
Well the error code 3E means that the overcurrent is detected at the moter.
Please check it if you have some overcurrent problem!
Thanks!
mannu_rakesh
Posted on Sep 01, 2009
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
My machine leader stoped it give me a number 3E WHAT THAT MEAN
This video will help you diagnose the fault on your samsung 3e error codes and the video will help you solve the problem
Mar 08, 2013 | Washing Machines
How to repair nd code on a maytag mah2400aww washer
Remove the back panel (2 screws). On the bottom tray is the water discharge pump. Clear any obstructions.
Nov 14, 2012 | Maytag MAH2400AWW: Compact Front Load...
Errhr code ee
There is no error code ee
Could it be 3E or E3
if is 3E then it means "High current detected"
if its E3 then it means "Motor not running properly"
here is the link to the manual I checked all manuals starting with the model number Wf337AA the error codes are all the same.
http://downloadcenter.samsung.com/content/UM/200710/20071010083409359_WF337A-02440A-06[1].pdf
Jul 11, 2012 | Samsung WF337AA Front Load Washer
What is code 3E on a Maytag model MAH2400AWW
CODE 3E IS SOMETHING TO DO WITH THE MOTOR. MINE JUST WENT OUT AND TURNS OUT THE RELAY IS BAD TOO. HAVING TO GET A NEW WASHER. TOO EXPENSIVE TO FIX.
Nov 27, 2010 | Washing Machines
Maytag mah2400aww 3E error and it will not spin
I have this problem with my unit. Called Maytag and got blown off. Unplugged the unit for 24 hours and it reset. Ran fine for a while but the problem comes back.
Jan 14, 2010 | Maytag MAH2400A Front Load Washer
Cycle stops 3E code appears
Thanks!
mannu_rakesh
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Jun 12, 2008 | Maytag MAH2400A Front Load Washer
Duet Model GEW9200LW0 Dryer will not start-Code 3E
I have a GEW9200LW0 whirlpool dryer, that displays 3E when I try and start the dryer. nothing happens,All i get is the 3E code.
Dec 08, 2007 | Dryers
Maytag MAH2400A Front Load Washer Logo
430 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
