Question about Texas Instruments TI 880 Matrix Printer
HOW DO I RESET A TI-880? DOES IT HAVE RESETS?
Hello, I wanted to remove all the programs of my TI-84+, so I performed a reset: all RAM cleared. Now it resets ever time I turn my machine on, what can I do about this? Thanks for any help.
It sounds like the small round battery in the battery compartment is either not connected well or dead. Try making sure there's no corrosion on the connection and replacing if that does not work.
Mar 22, 2011 | Texas Instruments TI-84 Plus Calculator
Reset
The TI-83+ has several different resets. If you can, press 2ND MEM to get into the Memory Management menu. Press 7 to select Reset and go from there.
If the calculator is non-responsive, remove all four AAA batteries. Press and hold the ON key for at least ten seconds. Replace the batteries. Turn the calculator on.
Jun 15, 2010 | Texas Instruments TI-83 Plus Calculator
MY TI 880 PRINTER RIBBON WILL NOT REVERSE
This is most likely the ribbon drive and Caltex has them.
call them at 1-800-959-5507 ask for linda.
Mar 18, 2009 | Texas Instruments TI 880 Matrix Printer
Epson Stylus Color 880 printer problem
from Kradinsky "Turn the printer on while holding down both the ink and paper buttons. When the paper light flashes release both buttons", then hold down the ink button for approx. half a minute until the printer lights flash again then release it. That resets the printer.”
Dec 17, 2008 | Epson Stylus 880 InkJet Color Printer
Need to reset calculator
When you press the reset button it resets EVERYTHING. You are now back at square one. Start all over again.
hamar nnelg
Apr 01, 2008 | Computers & Internet
Epson won't print and all lights flash
Mar 15, 2008 | Epson Stylus 880 InkJet Color Printer
My TI turns itself off and resets its RAM whenever I hit an arrow key.
Sorry that you all are having issues with your calculator. Try the reset procedures for your units. Reset procedures can be found in Texas Instruments Knowledge Base which can be found at the following website:
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetId=72521&nUsePub=NO&jttst0=6_23871,23871,-1,0,&jtfm0=&etfm1=&jfn=ZG1012A709F38464426C8B7F954BAD10F30F8264D7A42C7ECAC14E43D33C62440B0C3439BADB85CBF64291010A4860F183F8
Note: Even though the reset procedures are for units that do not turn on, they can still be helpful.
Hopefully that works, if not, you can always contact TI by calling 1-800-TI-CARES (1-800-842-2737) M-TH 8:00 AM - 7:00 PM FRI 10:00 AM - 7:00 PM Central Standard Time.
Dec 23, 2007 | Texas Instruments TI-83 Plus Calculator
Epson stylus 880 printer
Oct 08, 2007 | Epson Stylus 880 InkJet Color Printer
Service Pack 1
NEC Computers has developed a service pack to address several service issues with MobilePro 780 and 880 handheld personal computers. To assure proper operation, NEC Computers strongly recommends that you update your MobilePro 780 and 880 systems immediately by installing this service pack according to the installation instructions. * Download Service Pack One for MobilePro 780 and 880: ftp://ftp.necsam.com/pub/Catalog/3959/MobileProSP1.asp * View Installation Instructions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001186#Installation * See Contents of Service Pack: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001186#Contents * Read Additional Frequently Asked Questions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001186#FAQ Installation Instructions for Service Pack One for MobilePro 780 and 880 First download the service pack (MP78_UPDATE.CAB) to either your HOST or MobilePro system. It must be manually loaded onto your MobilePro by either using a dial up connection, PCMCIA Flash card, or from a connected PC before continuing with the installation. To install the MP78_UPDATE.CAB file, follow these steps: 1. Back up your MobilePro data and configuration using the Microsoft ActiveSync backup procedure. For details on using ActiveSync, see your MobilePro User's Guide. 2. Perform a Full (hard) reset on your MobilePro. Caution: Performing a Full reset erases all your data. Your MobilePro resets to the factory default settings. Please perform the backup first or you will lose data! 3. Copy the MP78_UPDATE.CAB file to you MobilePro desktop. 4. Install the service pack by double tapping the MP78_UPDATE ICON with your stylus. For proper installation, you MUST accept the default location - \Program Files, by clicking OK. 5. The following Message box will be displayed: Warning !!! 1. In order to ensure these patches are properly installed you must perform a Hard Reset prior to the installation. 2. You must back up all application and data files before performing a Hard Reset. The Hard Reset WILL ERASE all applications and data stored on this Mobile Device. 3. This file must be installed immediately after performing a Hard Reset on the Mobile Device (before any applications are reinstalled). 4. Press CANCEL to exit. Or Press CONTINUE to install this file. 6. Press Continue to install the service pack or Cancel to back up your data. 7. When the Setup Finish message box is displayed, Click Ok. This will remove all temporary files from your systems. 8. When the Setup Complete message box is displayed, click Ok. 9. Perform a Soft reset on your MobilePro. 10. Optionally, restore your MobilePro data using the ActiveSync restore procedure. 11. Once the service pack is installed, NECC recommends that you use the ActiveSync b
Sep 14, 2005 | NEC MobilePro 780 Pocket PC
Service Pack
Sep 14, 2005 | NEC MobilePro 880
54 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
