Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Esp 3250 just upgraded to win 7 and plugged printer to usual usb bu keep getting . warning bidirectional support disabled. never had a problem before
  • Anonymous Apr 01, 2014
    wont print and this is what it says bidirectional support disabled ?
  • 100 Answers
I just looked at the Kodak website and could only find the following reference - it is for windows xp but you could try and see if it will work with windows 7.
For WINDOWS 2000 and XP Operating Systems:
  1. Temporarily disable the Windows firewall:
    1. Select Start > Settings > Control Panel > Windows firewall.
    2. Disable the firewall and click OK.
  2. For WINDOWS 2000: Select Start > Settings > Printers. For WINDOWS XP: Select Start > Printers and Faxes.
  3. Right-click the KODAK EASYSHARE Printer Dock, and then select Properties.
  4. Select the Ports tab.
  5. Clear the "Enable bidirectional support" check box.
  6. Click Apply, and then click OK.
  7. Check for correct operation.
  8. Restart the computer.
Hope that helps.
Posted on Nov 18, 2009
  • 65 Answers
Check the kodak website for updated windows 7 drivers
Bidirectional support disabled
See this... http://support.en.kodak.com/app/answers/detail/a_id/1294/~/error%3A-bidirectional-support-is-disabled/selected/true
Jun 28, 2014 | Kodak ESP C310 AllInOne InkJet Printer
Printer Does not recognize Color Cartridge Error 3603 for ESP 3250
Are you using "compatible" cartridges? That is usually the problem. Try using Kodak cartridges. If that doesn't work, it's the printhead. You could try cleaning it.
Nov 03, 2012 | Kodak Esp 3250 Allinone Multifunction ( ...
I tried to insert my memory card from my camera and it will not go in. Are there certain cards it will not take?
yes what kind of camera u have if u have a usb plug in the front you can buy an adapter for your camera at staples or your local electronics store..
Apr 10, 2011 | Kodak ESP5250 All-In-One InkJet Printer
Can i print from my computer without the usb 2.0 cable
To print documents from your computer you will need to have it connected via USB. If you just want to print pictures you can load them on to an SD card (or any of the other supported cards for this printer), plug the card into the printer's card reader and print directly from the printer.
If you want to be able to print without using USB you should look into wireless printers such as the Kodak ESP 7250.
Mar 07, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
My Kodak ESP 3250 won't scan. It just keeps telling me "Scan to computer failed"
Try initiating the scan from the computer, once you plug in the USB cable into your computer, go to My Computer, right click the sanner (should be called something along the lines of KODAK ESP.....) and press scan, then click which program you'll use to scan it, I usually do the Microsoft one, Good luck!!
Feb 12, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I just bought A Kodak esp 3250 series AIO printer. I can print from computer, copy and all that but whenever I try to scan to computer or even preview scan I get a error saying :An error occurred while...
Try a new USB cable. Scanners require bidirectional communication with the computer and thus can fail when printer itself works. (If you use a print server or USB hub, try a direct connection.) Also try changing USB ports.
Another thing to try is to remove the TWAIN driver and reinstall it. This requires the original software CD from Kodak.
1. From your computer desktop, click Start > Run. (In Windows 7, type run in the search box then click on Run.)
2. Type %windir%, then click OK.
3. Double-click twain_32.
4. Right-click Kodak, then select Delete.
5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
6. Double-click aioscannr.msi, then follow the instructions to remove it.
7. Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
8. Open Home Center Software:
a. Select Scan Documents and Pictures.
b. Scan a document.
Unfortunately, if the error persists, the scanner may need service. Contact Kodak: http://www.kodak.com/go/contact .
I hope this helps.
Jan 06, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
981 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
