Question about Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator
All of a sudden
My roper fridge last night the freezer thawed out so today i took out the remaining food and stored it cleaned it completely i tilted it and cleaned the coils underneath gently and it is still not cooling what could this be its only 5-6 yrs old
  • 833 Answers
Fixing...first, I assume that the light is on inside. If so, is the compressor working?...that's a mechanical noise from the bottom of the unit. If you don't hear it, it can be a number of things. If you do hear it, does it work for just a brief period and then click off? Unplug the unit, wait 10 minutes and then plug back in. Then listen for the above click-off. How is the thermostat set? Is it in the normal range? Once you go through these checks, we can see if the problem is among the symptoms outlined or something else.
Posted on Jan 10, 2008
6ya staff
SOURCE:
I have an apartment size refrigerator with fridge on top and freezer at the bottom. The freezer has stopped freezing. Upon cleaning out all of the damaged food from the drawers, we noticed that there was...
This sounds like there is a fault in the defrost circuit, so the evaporator is not being defrosted. Alternatively it will be a sensor fault that is reading low and causing the fridge to keep on running trying to reach the desired temperature.
Jun 11, 2017 | Liebherr K 4260 Refrigerator
My fridge/freezer defrost itself last night and the freezing and frigde temperatures went low and my frozen food was all thawed
manually rotate your defrost timer maybe it stuck up and the contact was on the defrost heater. adjust your thermostat setting to coldness then observe unit.
Mar 05, 2011 | Refrigerators
Freezer not freezing
you may have defrost problem or check fan by compressor
Apr 04, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Fridge odor
There are a couple of methods to help remove odors from a fridge. The first is a cookie sheet with baking soda spread across it left in the fridge for several days. The other is something called Activated Carbon. Most stores sell it as a carbon odor filter and it is pretty cheap. It actually works better then the baking soda so I recommend you pick some up and just leave it inside the fridge. You can also put this behind your fridge or wherever you have foul odors. Hope this helps.
Nov 01, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerator nor freezer was not getting cool enough. We have a side by side refrigerator. Last night we cleaned the freezer and saw there was built up ice inside at back..it is a self defrosting...
Remove back cover in freezer to completely thaw out. Check continuity on defrost heater replace if needed, also replace defrost thermostat, that is probably the problem.
Jul 10, 2008 | Refrigerators
Kenmore 77563 Installed last week and freezer defrosted all the food
The refrigerator & freezer operate using the same system. One system. Your still covered by the warranty and I would suggest calling the installers or store from which it was purchased. The problem may be a faulty fan switch .
Apr 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Fridge not cool
the coil is frosted over and no air is being pushed to the fridge it may clear up after a few defrost cycles or remove the food from the freezer and allow it to thaw completely (12hrs) the ice behind the back wall takes a long time to thoroughly melt or you will have soild ice instead of frost and then it will never thaw soild ice.
Sep 29, 2007 | Maytag MFD2560HES Bottom Freezer French...
Bottom mount freezer not getting cold enough
You have a failed component or components in your automatic defrost system. This is why you have excessive frost inside the freezer along the back wall. The timer could be stuck in run mode. The defrost thermostat (bi-metal) could be defective or the defrost heater could be open or shorted.
Sep 18, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator Logo
Top Roper Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Gil Shultz
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
