Question about HP Photosmart C5180 All-In-One InkJet Printer
I have an error code Oxc18a0001 on my HP c5180. Could you please help me? Thanks
    Genius:
  • 1,011 Answers
Are you using a factory new ink cartridge?
Please consider the following before you read through the information that I obtained from the HP website.
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Issue:
An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print.
Solution:
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Posted on Nov 18, 2009
Tengo una impresora C6280 pero me sale un mensaje de error Oxc18a0001 que hacer
VAYA A ESTE ENLACE.ESTA EN INGLES PERO PUEDE USTED CORRER EL PROGRAMA A VER QUE LE INDICA .LUEGO POSTEE OTRA VEZ.
An '0x ...' Error Message Displays on the Front Panel When Printing HP Photosmart C5380 All-in-One Printer - HP Customer Care (United States - English)
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 05, 2011 | HP Photosmart C5180 All-In-One InkJet...
Hp photosmart c5180 erreur oxc18a0001
hi
That may be, so try thie you have nothing to lose.
Try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
Jan 09, 2011 | HP Office Equipment & Supplies
Ink system failure oxc18a0001 /c5180 all in one ink jet printer
This is a common problem, it is caused by air in the ink feed tubes. This happens if you allow your printer ink to fully run out and the unit sucks air or you use a poorly filled refill cartridge that has air bubbles. To clear the error you will need to do a purge on the system. The procedure takes about 10 minutes to complete. We have a step by step guide to this at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
May 27, 2010 | HP Photosmart C5180 All-In-One InkJet...
I Have a HP Photosmart C5180 and it stopped printing, fault with the printing head Fault No Oxc18a0001 havent found any one who knew what this fault is or knew how to cure it..
Hi Ken
I've had a quick dig around on the net and found a page with 3 solutions that you may like to try. One person has posted on the HP forum that this will resest the printer and confirmed that it worked for her.
LINK
Regards
Scott
Mar 24, 2010 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart All in One error message Ink System failure -Oxc18a0001
There are N no of steps to be done so i am pasting the HP URL ,please follow it and u will get to some kind of solution in the end or u might have to replace the print head .
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&cc=us&lc=en&dlc=en&product=3560280
All the Best
Feb 17, 2010 | HP Photosmart C5180 All-In-One InkJet...
Oxc18a0001 error will not reset by shutting power off
This printer needs to serviced by authorised service provider
Aug 08, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart D7360 - Oxc18a0001 Ink System Failure
please reinstall the drivers
thanks for your question
May 20, 2009 | HP Photosmart C5180 All-In-One InkJet...
Hp error code oxc18a0001
anaanymous
Sep 24, 2008 | HP Photosmart C5180 All-In-One InkJet...
Ink system failure
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer. Please let me know if the issue is not resolve so that i can check for a possible solution for that. Thank you so much. adonscott
Jul 01, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
133 people viewed this question
Seeker5211
Seeker5211
