Question about Lexmark X5150 All-In-One InkJet Printer
Cartridge is stalled
Whenever I'm trying to print a picture, the printer will do about 1/3 of the page or 1/3 of the job (if it's multi-pages), and it stops. A window appears ont he screen saying the cartridge is stalled. It suggests to look for something blacking the cartridge and start over. This never changes anything. Help!!
  • wangyoo Feb 03, 2008
    After refilling #82 and #83 ink cartridges, put them back in. Trying to print and also make a copy but no ink come out . The machine seem to work fine but only the plain paper. Please help me. I lost all manual book guide. Ineed some a quick help. My term paper has been dued!!!
    Sam!
I had the same problem and fixed it by physically pushing the cartridges to the left. Yes I was a little frustrated at the time and using brute force may not always be the best idea but...it worked! I felt as if it was stuck there and I released it.
Posted on Oct 24, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
I had the same problem. I fixed it by oiling the bar that the print head rides on. I used sewing machine oil but I imagine regular 2 in one oil would work fine.
Posted on Jan 28, 2008
    Scholar:
  • 64 Answers
When the printer is new, the manufactures often insert small pieces of foam in the railing system of the print head. The foam prevents the printer head from moving during transit. There may be a small piece of foam packaging still left inside from when it was new.
Open up the printer and look carefully inside with a torch light or move the printer to a well lit area so as to see inside where the printer head lives.
Most of the packaging is obvious, white or similar color and make now be tarnished with age.
If you are unsure about what to look for, it might be best to take the printer to a dealer or repair shop and explain the problem carefully to them.
Posted on Jan 13, 2008
The logo in my print job is color Green but its coming out in color blue. what is the problem
Check the yellow toner cartridge, printing a configuration page.
Configuration page
The Configuration page lists the current settings and properties of the printer. You can print a
Configuration page from the printer or HP Toolbox. To print the Configuration page from the printer,
complete the following steps.
1 Press the (LEFT ARROW) or the (RIGHT ARROW) buttons to select the Reports menu.
2 Press the button (SELECT).
3 Press the (LEFT ARROW) or the (RIGHT ARROW) buttons to select Config report.
4 Press the button (SELECT) to print the Configuration page.
Yellow print OK?
No? try print with another yellow toner cartridge (Q6002A).
Aug 10, 2011 | HP Color LaserJet 2600n Printer
My printer is printing blank pages
I used to have one of these printers.
1. Check the ink levels.
2. Try printing on DVD.
The C309 has a black photo cartridge.
Text prints from the regular black cartridge and pictures print from the photo black cartridge.
THe best way to tell if by checking first the ink levels and replace cartridge if necessary.
One thing you can do to check if the printer is printing is by adjusting on the Printer Setttings and printing on one color.
To do this you need to choose the color from a circular palette .
Another way is to use Word or any other processor and change the font color to blue and print it.
Hope it helps.
Feb 05, 2011 | HP Photosmart Premium C309A All-In-One...
Whenever i try to print it does 1/2 page then the cartridge keeps getting stalled on one side. Error message on screen says print cartridge stalled, error message on printer says clear carraige jam. Cannot...
If there's a carriage jam. While the printer is turned on, Open the access door of you printer.
If the carriage is stuck at the left side, try moving it manually by hand to the right most part of the window. If it's stuck on the right, try moving it by hand to the left.
If you've already done that. While the printer is turned on, unplug the power cord from the back. Close the access door. And then plug it back in.
Make sure you restart the computer first just to avoid documents getting stuck in the print queue. Try printing again. Usually it does the trick.
Feb 03, 2011 | Office Equipment & Supplies
Printer problem for a dell 924 printer
I have run across several Dell & Lexmark printers that after a while of working great, decide to have an "issue"... If you are printing more than 1 page, they will print the first page, then stop. The computer says "Cartridge Stall" and the printer says "Hardware Error 0502" or something similar, depending on the printer... Anyway, the message on the computer suggests making sure your cartridges are installed correctly, and nothing is blocking their path... After dealing with this many times, I have finally found a solution that seems to work!
There is usually a metal bar that the cartridges slide back and forth on... over time, this bar can become "gunked up"... Use alcohol pads to clean up the bar, and the surrounding area.... Clean out as much of the track as you can also. Tada... .No more cartridge stall!!
Oct 22, 2009 | Dell A940 All-In-One InkJet Printer
HP psc 1315v (printer, scanner, copier) Will not print
The test page printing out every time it gets turned on is the printer's way of telling you it wants to be calibrated. Lay the test page on the scanner (follow the pictures on the test page) and scan it in. This should fix that problem and the "occasionally after waiting, something prints" problem.
Unfortunately, I don't have an answer to the "E" on the display or check printer cartridge light. Hope this helps!
Sep 06, 2008 | HP PSC 1350v All-In-One InkJet Printer
Hp printer 5420 photosmart
sadone:
I assume all hardware connections are fine, and any lose cable connections are already checked then......
1)Send a test page to the printer Open up the print jobs, and try deleting all jobs (click on the printer from printer and faxes under control panel, delete all print jobs, Still in this window click printer and uncheck the print offline, does this help?) if not then
2)Try uninstalling and reinstalling the printer driver and then try printing a test page.
3)Try uninstalling and reinstalling the printer software and driver and then try printing a test page.
If nothing works then:
-Uninstall all printer software, driver unplug and reseat an original hp cartridge and go this link install software and driver and follow instructions on how to install the drivers, at the end click the check button to see if driver is fine. Now you should be able to print.
Dec 24, 2007 | Office Equipment & Supplies
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
HP 4650N Will not print more than one copy of a job
make sure when printing it has all checked off in the page range box instead of pages
Aug 28, 2007 | HP LaserJet 4650n Printer
Lexmark X5150 All-In-One InkJet Printer Logo
85 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
