Question about Panasonic Viera TH-46PZ85U Plasma TV
Panasonic Plasma TV TH-46PZ85U Power supply problem
I have a Panasonic Plasma TV TH-46PZ85U and I'm receiving the two blinks code.
The tv is not turning on and after some researches I know the problem is the power supply.
My question is:
If I buy the power supply (model ETX2MM704MG) can I switch the part by myself?
Is it just take out the screws and cable and plug the new power supply? Or I really need a technical guy?
  • 44 Answers
SOURCE: 46pz85U two binking red light - no picture
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Dec 03, 2009
  • 8457 Answers
SOURCE: TH-50PZ80U POWER INDICATOR LIGHT KEEPS BLINKING
Power board it dead,take the tv aparts.Check for Capacitors parts for puff up or burst open.Know how to solders?replaced these capacitors in the power board.Or replaced the whole power board.Tries Shopjimmy.com,Ebay.com.
Posted on Jan 19, 2010
SOURCE: Panasonic TH-50PZ Plasma TV won't come on.
I had the same issue twice with a TH 42PWD5. turns out it was my UPS that was killing the switching power supply. Warranty covered it but when I removed the UPS not a single issue in 3 years.
Posted on Jul 01, 2008
  • 61 Answers
SOURCE: Power light blinking 2 times
2 blinks means the unit is having problem with 12 volt supply.
while power on you can check 12DC on power supply before shutdown.if the voltage is constant before shut down I would recommend to replace D board.
Posted on Oct 09, 2008
SOURCE: Panasonic TH-42PX60U plasma TV: red blinking light
are you using a PC to feed a signal or maybe a cable with an adapter?
I had the same issue when I used one of the rear HDMI ports to show a PC display. Apparently there is a software difference between the rear and side/front ports. Inputting the PC through the side HDMI port has solved the problem for me (so far!)
Posted on Apr 21, 2009
10 blinks code
I don't know what to do with 10 blinking of my Panasonic TH-46PZ85U.
I bought It in summer 2008...is it already kaput ? I'm not sure any more to want to make repair my tv set. I wonder how much could it cost ? Bye-bye plazma.
Aug 18, 2012 | Panasonic Viera TH-46PZ85U Plasma TV
Panasonic plasma th42pz85u blinking light 10 times
This is the error code, indicating a failure inside the board. Might need attention by a qualified service technician.
Jul 30, 2012 | Panasonic Viera TH-46PZ85U Plasma TV
TV won't turn on
at plug in only is there a light blinking and if so how many Blinks? and if not hit the power button and do the same. look for the number of blinks. there are many things that could be wrong for the same code.
Nov 16, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
Panasonic - TH-46PZ85U - Will not power up, either from the remote or from the TV on-off power button. With the TV plugged in, a light on the bottom left corner flashes 10 times, pauses and then the...
Could be a cooling fan failure, there are five fans across the back of this tv ( i think) if even 1 fails the power supply shuts down. If so fan needs replacing,
pete
Nov 11, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
I have a Panasonic TH-46PZ85U Plasma TV with a two blinking light code, no picture. How do I fix. I Have removed the back panel and looked for damaged caps but I do not see any.
hi; the blinking light code means that you have a fault in the power supply unit, unplug the tv from the power source, check all transistors you will find some of there shorted, just replace them; if you need a help about repairing i'll help you
Nov 06, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
My panasonic th-46pz85u has 2 blinking lights and wont turn on
The power supply board it dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 21, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
The tv is not turning on all I get is a red blinking light next to the power switch
The power supply board is dead.That the board where the power a/c cord plug into it.Take the tv aparts,replaced the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jun 23, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
I have a Th-46pz85u panasonic plasma tv that is blinking the power light 10 times. I was curious to see what the replacement part is to fix that problem. I have the Panasonic error codes and that error...
Yes,this codes is a 100% correct is ur power supply board.U searches all around the power supply board and it supporting boards for those leakages gases capacitors?These capacitors alway have bulges on it top or puff on it top.Replaced these bad capacitors,u will get ur power voltages stable and ur power supply board will work.Not,than one or more of ur power transformers have a shorted power pins legs.The power transformers,coil is dead.The transformer must be replaced.
May 03, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
Panasonic TH-46PZ85U when i turn on tv does not go on but red power light flashes. What can I do to fix this?
Power supply board is dead.Must change the power supply board to solved this.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 19, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
7 blinking Red Light. Power Supply problem??
Need replaced su.sd and sc board
Panasonic TXNSC1RKTUS SC BOARD BOARD, SCAN DRIVE ASSY
Panasonic TXNSU1RKTU SU BOARD BOARD, UPPER SCAN OUT ASSY
Panasonic TXNSD1RKTU SD BOARD BOARD, LOWER SCAN OUT ASSY
Dec 09, 2009 | Panasonic Viera TH-46PZ85U Plasma TV
Panasonic Viera TH-46PZ85U Plasma TV Logo
1,294 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
