Question about Kenmore Washing Machines
Kenmore (SEARS) Dryer - ''26 88802'' Shut off Problem
Our Kenmore dryer purchased in 1998 (has moisture sensor). Timer does not advance thru the cycle - machine just keeps running. Vents & hoses are all very clean. Have not taken off any panels to clean lint.
This machine is 10+ yrs old and has never caused problems - does it make sense to replace it now - are the newer ones more energy efficient.
Thanks
Keith
  • Keith Clark Nov 19, 2009
    The machine has has combined automatic and manual timer. We have never used the manual timer, so I tested it without any clothes to dry. It works, but I would estimate the allotted time is doubled; ask for 10 mins. & it runs for 20/25.
    Is the moisture sensor the black ( with 2 silver metal stips) module inside the drum.
    No Lights. First noticed the problem about a week ago at 4 am ( put on around 10pm ) when I realized the dryer was still running in the auto mode, so I shut it off manually.
    President:
  • 1,015 Answers
I am assuming that this machine has a mechanical timer. It sounds like the mechanical timer might have stopped turning. Does it stay on during every cycle(timed & auto)? If it shuts off with timed but not auto dry then it is a problem with the moisture sensor otherwise it sounds like the timer. You could try removing the timer and blowing it out with compressed air completely and see it starts working again. If the timer needs replacement they cost around $200 dollars. The moisture sensor contacts inisde the dryer might just need cleaning. Try using some rubbing alchohol and a cloth on the contacts(two metal strips next to each other). The moisture sensor uses low voltage to measure if the moisture inside the dryer. It is possible that a wire connector has come loose inside the dryer causing the problem. And sometimes I have found that a mouse living in the dryer will chew through wires and cause problems. Let me know if you have any other questions.
Posted on Nov 18, 2009
  • muebe Nov 19, 2009
    Yes the part with the two metal strips is the moisture sensor. It is possible that the moisture sensor has stopped working if the timer moves to shut off the dryer. Do you have any lights that indicate if the clothes are "wet" and "damp" and if you do are they coming on when the clothes are wet or damp?
    Well if the timer is shutting off the dryer in the maual mode(even though it is 20 minutes for 10) then I would lean toward the moisture sensor is defective. I am not sure how much it cost for one. you would need to find out what voltage reading it should have when moist clothes are in the dryer. Then you would test those wires coming from the sensor with a fluke meter to make sure it is the sensor head is defective. I am not sure how much money you would want to invest in a dryer that is 10 years old.
My kenmore dryer heat element goes on and off. The clothes take hours to dry.
It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Dec 31, 2009 | Kenmore Dryers
Dryer will not turn off
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
May 20, 2009 | Dryers
Kenmore 11070702990 Gas Dryer - Timer does not work
May 09, 2009 | Kenmore 60172 Electric Commercial Dryer
Gas dryer wont trun off after drying
May 08, 2009 | Dryers
Takes too long to dry or keeps running when clothes are dry
May 07, 2009 | Kenmore Elite Oasis 6809 Electric Dryer
Dryer runs but wont auto shut off
On auto dry cycles, the cycle is controlled by moisture sensing bars located on either the rear or front bulkhead, ( visible inside dryer ) if the moisture sensor bars are shorted together (normally by wet clothing) the dryer will continue to run. If the dryer continues to run when the clothes are plenty dry, check and see if there is anything stuck between the sensor bars, (sometimes a metal sequin will cause this) or see if they are damaged. If not, you may have a problem with a timer contact, if the timer advances and stops moving at the same spot each time, I would suspect the timer. If this is an EvenHeat dryer, examine the control board located to the right of the timer in the control panel, for any burned components. Hope this helps.
Sep 15, 2008 | Kenmore 73952 Gas Dryer
My Kenmore Model# 110 66652500
See the following hints from Repairclinic:
If it does not heat up, the element can also be faulty.
If you need to call a technician there is a phone number listed at the end of the user manual.
Sep 04, 2008 | Kenmore 63012 Electric Dryer
Auto Dry not advancing
It sounds like a timer problem since it happens during timed also. Some dryers don't have an actual moisture sensor for auto dry. They work by knowing that as long as the clothes are wet the temp won't go past a certain point. As the clothes dry it trips a thermostat that lets the timer advance. Until this is fixed DON"T trust the timer to shut off the dryer. Sometimes it won't or could leave the dryer running for hours. This has nothing whatsoever to do with fuses. There are no fuses in a dryer. Just high limit thermostats and other devices that will shut off the heat but usually not the motor.
May 30, 2008 | Kenmore 73952 Gas Dryer
Kenmore dryer
Jeff, almost sounds like a timer issue, but I was fooled on this once. Under the consol is a inline resistor from the main plug. If this resistor is bad, dryer keeps running in timed dry. Part number for the resistor is 3401076. Look it up on the web so you know what it looks like. Just splices in.. Catriver..post back.
Sep 14, 2006 | Kenmore 62602 Electric Dryer
Washing Machines Logo
116 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
