Question about GE WBSR3140DW Top Load Washer
Spin cycle starts, speeds up, then stops spinning
Spin cycle starts then gets to a certain speed & stops spinning; water drains, washer continues to cylce to end (i can hear that the machine is still on and it "acts" like it wants to spin; but sometimes spins intermittently; clothes really wet. I've checked the lid switch, the dampening straps, and it's level .... any help is appreciated. thanks!
  • trice111 Nov 20, 2009
    Thanks for the quick response!
    Just a couple other notes: the water will drain out, pump out. I'm still trying to troubleshoot & I just ran the washer without any clothes and it cycled thru perfectly!! however, it's when clothes are in it that it wants to act up: when it hits the spin cycle, it will start to spin rather fastly (and drain at the same time) & then when it gets real fast, it'll stop spinning but the washer is still powered on & cycling thru. Could this be a BALANCING issue? I didn't think so at first because the machine is stable & doesn't make loud noises (meaning, it doesn't wobble or make noises like when you have a bunch of towels and it's not balanced....). I am NOT an electrician ~ I'm just a gal who's pretty handy when I know what the problem is & needs to save money: can't afford service person, new washer, or multiple trips to the landromat. :o)
    Things I've checked:
    - dampening straps (I replaced one that was broken)
    - belt (looks in great condition, is snug & is on track)
    - lid switch (works properly)
    - water drains well, all the way
    - agitator works like it is supposed to.
    - pump fan turns when washer is on
    - level (i took a level & place it on several areas on top of the machine ... it is pretty level)
    - "reset computer"?? by unplugging, lifting lid 7x **
    How can I tell if this is a problem with the CLUTCH? I thought this could be a problem, too ... but then again, the washer worked fine & spinned perfectly w/out clothes in it, I'm thinking it's not the clutch ...hmmm... THANKS for any more INPUT
    ** ps: I read where someone else mentioned about unplugging the machine for a few mins & then lift the lid slowly seven times to reset the computer & that might work .... I tried that, too.)
    Scholar:
  • 53 Answers
This fault often occurs when something (like a small coin or a paper tissue) has blocked the drain pump!
The only way to fix this would be to get a service engineer to remove the pump and check for a blockage, unless of course you are an experienced electrician or technician and don't mind doing it yourself.
Posted on Nov 18, 2009
Washer does not spin cycle, why?
In top load washers, if the machine goes through the cycles and then just stops at the spin cycle and leaves you with no noise and a tub full of water more than likely the lid switch is bad and not completing the circuit for cycle to continue. This is a safety precaution to prevent injury by reaching in the machine while at high speed spin. If the machine is getting to the spin cycle and still turning slowly but not draining the water, the pump is probably the culprit, either being locked up or in most cases something like a sock, etc. is stuck in it preventing it from turning. This is usually indicated by a humming sound during the spin/drain section with no water draining.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 30, 2012 | Whirlpool Washing Machines
I have a Frigidaire front-loading washing machine, model# FTF2140ES3 (serial# XC63816300). It works fine through the rinse cycle, but does not drain or spin. If I turn it to the rinse/spin only cycle, it...
Hi
Thanks for using FixYa. Please check the water pump. Either the water pump bearing is bad or there are some tiny pieces of debris stuck in the water pump. It is located below the door latch assembly. Remove the front panel and check the drain pump which is attached with hoses. Remove its clamps and clean the drain pump. You can also remove the drain pump by unbolting it from the washer base. If still the issue persists, then check the motor speed control board which is located inside the bottom of the washer. Please do accept the solution if the issue is resolved or
post a comment for further assistance.
Thanks
Rylee
Jun 08, 2010 | Washing Machines
Brand new. Load gets stuck on 14 minutes or some other time & repeats over & over. Wont finish cycle. We have to use the drain & spin to get the water out but then clothes are not rinsed well....
Sounds like you are probably doing a very bulky or real off balance load on a high spin speed setting. The washer is trying to get the load up to spin speed, but the load is too off balanced. Try the lowest spin speed setting for that load. If it makes it through that, then power machine back on and just push the spin speed button until the next higher speed shows up, and then the start button if you want to spin it out better. If it still didn't make it through the original cycle on the lowest spin speed, your load must be way too off balanced, like one coat that is saturated with water. If that is the case, you may even have to squeeze some water out of it by hand before you would be able to get the washer to get it up to spin speed.
Mar 21, 2010 | LG WM2487H Front Load Washer
Chugging like noise during certain cycles
your clutch need to be replaced as does the tub shaft bearings i;m sorry this is not a do-it-yourself job, try to make a deal to trade in your washer
Apr 22, 2009 | GE Washing Machines
Clothes come out soaking wet
Is the Delicate or Hand Washables cycle selected?
Spin speeds can vary by the cycle that is selected. Your washer is designed so that in certain cycles, such asDelicate or Hand Washables cycles, the spin speeds are slower. In these cycles, more water is retained in the load at the end of the cycle to keep delicate fabrics from shrinking and wrinkling. Select the appropriate cycle based on the fabric being washed.
Was an Extra Low, Low or No Spin option selected?
Select the highest spin speed for the fabric being washed. If extra low spin or no spin was selected, the washer may not remove enough water from the load.
Were you washing one bulky item, such as a rug or large blanket?
Consider adding more items to help balance the load during spin. Select $FL-drainspin cycle and restart the washer. Your washer is designed to detect an unbalanced load and automatically lower the spin speed. Unbalanced conditions are more likely to occur with a single, bulky item.
Are excessive suds present?
Use only HE High Efficiency detergent. Using non-HE detergent or more than the manufacturer's recommended amount of detergent can cause excessive suds. The excess suds can cause the washer to run at a reduced spin speed, which will result in very wet loads.
See also: Why HE High Efficiency detergent is required.
Is the drain hose kinked or is the drain clogged?
Make sure the drain hose is not kinked. Straighten the hose for adequate water flow. Remove any blockage from the drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
Is the end of the drain hose more than 96" (244 cm) above the floor?
The drainpipe (standpipe) height requirements are: 96" (244 cm) maximum and 30" (76.2 cm) minimum. Your washer will not be able to adequately pump the water out of the washer if the drainpipe (standpipe) exceeds 96" (244 cm). In this case, the water may flow back into the washer. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
Is your outlet voltage low?
Check electrical source or call an electrician.
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Will not spin,
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Code to restart washer Duet
Answer Is the Delicate or Hand Washables cycle selected?
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GE Washer does not reach full spin speed...stops abruptly
HI thanks for your question. the G E washer has to get rid of all the water before it starts to spin. check to see if you have a good water flow on pump out. if not clean the pump . thanks the appliance doc. please rate my answer. thanks
Oct 08, 2008 | GE Washing Machines
Drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Nov 05, 2006 | GE WWSE5200B Top Load Washer
GE WBSR3140DW Top Load Washer Logo
301 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
