Question about Sharp AR-5316 Advanced Digital Imager Copier
Looking for part number for Sharp AR5132 polygon motor
    Problem Solver:
  • 17 Answers
Ploy for the AR-5316 copier is RMOTN0022QSPZ
AR-5132 I think I still have the parts guide at work will look next week. I may also have a pulled working laser unit. I can check with my office for a price if you want and if I can find it.
Posted on Nov 21, 2009
ERROR CODE L6
Polygon motor lock detection
Detail : The polygon motor does not rotate.
The motor lock signal is detected for 6sec after
rotation of the polygon motor. The motor lock
signal is detected for 1sec during rotation of the
polygon motor.
Cause : Polygon motor unit abnormality
Improper connection or disconnection of the
polygon motor and the harness.
MCU PWB abnormality
Check and remedy : Use SIM 61-1 to check the polygon motor
operations.
Check connection of the polygon motor
harness/connector.
Replace the polygon motor..
Replace the MCU PWB.
Apr 30, 2014 | Sharp AR-M160 Laser Printer
SHARP-235, lp 6-10 CALL FOR SERVICE CODE...Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service lp 6-10 what dos it mean
L6 10 Content Polygon motor lock trouble
Details The polygon motor does not rotate.
or more after the polygon motor rotates.
The motor lock signal is detected for 1sec
during rotation of the polygon motor.
Cause Polygon motor unit failure
Polygon motor connection harness trouble
or disconnection
MCU PWB failure
Check
and
remedy
Check the polygon motor operation with
SIM 61-1.
Check connector/harness of polygon
motor
If the polygon motor isn't working then you will neeto buy a new Laser Unit. They can be expensive if you can get one. To replace it will tak alot of disassembly as well. Might be better and more cost effective to get a new machine.
Oct 22, 2011 | Sharp AR-235 Copier
My sharp Digital Photo copier AR-5020 have display L6 give the solution of the problem & what is the rate of LC polygonal mirror motor
check the POLYGON motor operation with SIM 61 - 1.
Check the polygon motors if it is rotating if not while it is receiving PD replace it, if this does not w2ork the problem is in the MCU power supply.
Jul 12, 2011 | Sharp AR208D Copier
My sharp AR-5316 is displaying an error code L6. please what could be the possible fault and solution. mzm from dubai
Error code L6: Polygon motor lock trouble Details : The polygon motor does not rotate. Possible Cause :
  1. Polygon motor unit failure
  2. Polygon motor connection harness trouble
or disconnection
  1. MCU PWB failure
Solution:
  1. Replace the polygon motor.
  2. Replace the MCU PWB.
Oct 14, 2010 | Sharp AR-5316 Advanced Digital Imager...
What does error code L6-10 mean on a Sharp AR-235 copier? Would it be worth fixing? Thanks
L6-10 Content Polygon motor lock detection
Detail
It is judged that the polygon motor lock signal
is not outputted.
Lock signal is checked in the interval of
10sec after starting the polygon motor, and it
is judged that the polygon motor does not
rotate normally.
Cause
The LSU connector or harness in the LSU is
disconnected or broken.
Polygon motor trouble
Check and
remedy
Use DIAG (SIM61-1) to check the polygon
motor operation.
Check connector and harness connection.
Replace LSU.
Jan 24, 2010 | Sharp AR-235 Copier
Hi we have a Sharp AR-M208 displaying error code L6-10. Need to know what that relates to and some basic trouble shooting to resolve. Thanks in advance!
L6-10 Content Polygon motor lock detection.
Detail It is judged that the polygon motor lock signal
is not outputted.
rotate normally.
Cause The LSU connector or harness in the LSU is
Check and
remedy Use DIAG (SIM61-1) to check the polygon
motor operation.
Replace LSU.
Jan 10, 2010 | Sharp AR-M208N Copier
Sharp AR-M205 - Error Code L6
L6 10 Content Polygon motor lock detected Detail It was judged that there is no output of polygon motor lock signal of LSU. The lock signal was checked at about 10-second intervals after the polygon motor started rotating. As result, it was judged that the polygon motor failed to operate normally. Cause Disconnected connecter to LSU or detached harness inside LSU or broken wire. Polygon motor defective Check and remedy Check polygon motor operation with SIM61-1. Check harness and connector for connection. Replace LSU if needed
Dec 14, 2009 | Sharp AR-M205 Copier
Error l4 02 in sharp ar5132
Dear sir;the error code you ask about for sharp copier, it means drum motor problem, why don't give them a try to reset before go to replace it, the procedure is
1, press "clear", "pause", "0", "pause"key
2, press 14 then press start.
Have anymore question, please let me know,
HAVE A HAPPY HOLIDAY !!!
Dec 17, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar-m208 message
Polygon mirror motor not up to speed. Check the motor, you power supply, and the board the motor it connected to.
Sep 23, 2008 | Sharp AR-M208 All-In-One Laser Printer
POLYGON MOTOR DEFECTIVE - SHARP JX-9500 printer, do you have a solution? Thanks
Theres a company I do business with that sells Sharp parts called Precision Roller. There located in Arizona. The phone number is 800-323-9523.
Manualuniverse.com might have the service you are looking for.
Jul 31, 2008 | Sharp Office Equipment & Supplies
Sharp AR-5316 Advanced Digital Imager Copier Logo
87 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
