Question about Palm Tungsten E2 Handheld
Frozen Blank Screen - soft reset doesn't work.... Do NOT want to do hard reset because all my data will be lost and it is my life line. I am panicking. Please help!
  • Palm Expert
  • 346 Answers
If you back up all your data on your desktop it will be restored with your next hotsync after the hard reset. I recommend the hard reset but if you really don't want to try that they I suggest you try using the free palm chat. Here is the link for that. Be sure to scroll to the bottom of the page and you will see palm Chat. Click on the link that says chat now and follow the prompts. Best wishes.
http://kb.palm.com/wps/portal/kb/na/tungsten/e2/unlocked/supportservices/page_en.html
Posted on Nov 19, 2009
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Dec 31, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
Palm T3 frozen, tried restart in hole, nothing?
Doing a soft reset A soft reset tells your handheld to stop what it's doing and start over again. None of your information will be lost. After a soft reset, a screen appears that lets you reset the date and time, if needed. To do a soft reset, use the tip of an unfolded paper clip (or similar object without a sharp tip) to gently press the reset button inside the hole on the back panel of your handheld.
If a soft reset does not unfreeze your handheld, you need to do a hard reset. Doing a hard reset Only do a hard reset if a soft reset doesn't solve your problem, or if you want to clear all of your information from your handheld. [!] IMPORTANT A hard reset deletes all records and entries stored on your handheld, including the username that identifies the handheld. Before you do a hard reset, be sure to synchronize.
1spacer.gif Press and hold the power button. spacer.gif 2spacer.gif While holding the power button, use the tip of an unfolded paper clip (or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your handheld. spacer.gif 3spacer.gif Wait for the Palm Powered™ logo to appear, then release the power button. spacer.gif 4spacer.gif When you see the message that warns you about erasing all of the info on your handheld, do one of the following: blank.gifPress Up on the navigator to finish the reset and show the Digitizer screen.
blank.gifPress any other button to do a soft reset.
Jan 31, 2008 | Palm Tungsten T3 Handheld
Blank frozen screen
IF IT IS A TABLET...
IT WILL SURLY HAVE A RESET BUTTON,RESET YOUR TABLET..NON OF YOUR DATA WILL BE LOST...
Dec 25, 2013 | Cell Phones
The audio works fine but the screen is incomplete and is frozen
Try performing a soft reset or a hard reset to the unit.
The soft reset is done by holding down the power button for at least 10 seconds and allowing the unit to power back on.
A hard reset is done by pressing and holding the bottom right hand corner of the screen while the power is off and then pressing the power button on. A pop up will appear asking to confirm the reset.
The hard reset will erase the user data, so it is advisable to save the data if possible.
Installing and running the Garmin WebUpdater to load or reload the latest update will resolve most issues.
download the latest version of WebUpdater software
You may also want to contact Garmin support for assistance.
http://www.garmin.com/us/support/contact
Sep 28, 2011 | Garmin nuvi 1450 GPS Receiver
My screen is totally frozen..cannot move it at all..was working yesterday, then the battery went dead (I was out) and then I charged it up - since then is totally frozen.
You can try to charge it up again for about 30 minutes and try a reset, here's how:
For soft reset type *#7780#
For hard reset type *#7370#
and if it ask passcode enter the passcode as 12345 as default.
Note: Please backup all your dataif you performing hard reset because hard reset deletes all data on your phone including
contacts music and pictures.
eBookBoy
Jul 10, 2011 | HTC Touch P3452 Smartphone
I can't format my nokia 6680 by typing *#7780#
If soft reset doesn't work( typing in *#7780#) You can try the Hard Reset Method.
  • Warning, doing this will delete all data on the phone and your memory card, so back up all the files first if applicable. Also make sure that the battery is fully charged, since it can cause serious problems if the phone dies while doing a hard reset
While on the main screen/desktop key in the following code: *#7370#. It will erase data on the phone and the memory card, once done it should restart and you're good to go.
Jun 11, 2011 | Nokia 6680 Cellular Phone
My kindle is frozen. holding power switch for 15sec. did not work
Make sure you have enough battery life to support the kindle, because sometimes it stays in the frozen state if it detects you have little battery life.
If this doesn't work, press , , and keys simultaneously (This is it's soft reset)
The last resort I would suggest is to do a hard reset. Make sure your battery is charged to about an hour, remove the cord from your kindle. Turn your kindle over and open the back, you should see the small hole under the word RESET. Get a paper clip, unwind it and insert the clip into the hole CAREFULLY and press for about 10 seconds. The screen should be blank, and it will restart.
May 31, 2011 | Amazon Kindle Wireless Reading Device
My bb is getting rebooting
If your BlackBerry Bold 9000 series device is frozen, rebooting or not responding, you will probably want to reset the unit. Here are the different types of resets that can be performed in the order they should be tried.
Remember your data will we wiped. So make a backup.
Soft Reset
Press ALT + RIGHT SHIFT(CAP) + DELETE.
Double-Soft Reset
Press ALT + RIGHT SHIFT(CAP) + DELETE . The screen will go blank for a few seconds. When the screen comes back on, immediately press ALT + RIGHT SHIFT(CAP) + DELETE again.
Hard Reset
If none of the above works, pull the battery out of the unit for a few seconds, then reinsert it.
Mar 12, 2011 | RIM BlackBerry Bold 9000 Smartphone
The screen has frozen and I can turn it on or off I tried the reset button but that doesnt work either
There are two types of Reset are present
1)Soft Reset.
2)Hard Reset.
Just pressing the Reset button using compass or needle will just do soft reset,It is not more effective in this case.You have to go for Hard Reset.
Hard Reset:All the data's will be lost once you do this.but will solve your problem.
Hold Reset for 5-10 seconds.
Flip power switch quickly 3 times. If this doesn't work.
check the light next to the power switch. If it is flashing yellow, do the same steps. It might take up to two to four tries.
Please do rate the solution if the issue is
resolved or post a comment for further
assistance.
thank you for using fixya have a nice day:-)
Aug 01, 2010 | Sony Reader Pocket PRS-300
Screen is frozen
How to reset iPod Nano if it is not responding or frozen.
Hold down the Center and Menu buttons simultaneously. The screen will start to melt away. Then you will see the Apple appear on the screen.
The iPod has been reset sucessfully.
Music files should still be saved, but some customized settings may be lost.
If that doesn’t fix your problem, try a hard reset by holding down Menu and Play/Pause simultaneously for about 10 seconds. A hard reset will clean all data off the unit.
Jul 25, 2009 | Apple iPod nano MP3 Player
Palm Tungsten E2 Handheld Logo
89 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
