Question about Brother MFC 210C All-In-One InkJet Printer
Error message - 'unable to print 70'? Please
Error message on printer - 'unable to print 70'?.....Please solve!
SOURCE: error message on my printer that says unable to print 36
If this is a Brother clean the clear strip on the carriage assy. it is a timing strip for the carriage , I have seen ink on these cause the "36" code
Posted on Aug 05, 2009
komguy
  • 2306 Answers
SOURCE: Print unable 32 ?
Print unable 32 is dirt or scratch on the transfer belt assembly. There's a timing mark on the belt that a sensor must read. If the belt is damaged, you will need a new one.
Posted on Aug 07, 2009
komguy
  • 2306 Answers
SOURCE: Printer says "Unable to print 70"
Usually that error means the encoder strip behind the carriage assembly is out of position or very dirty. Best to remove the top cover to correct, you might also find a scrap of paper either on the extreme right or left stopping the carriage from moving properly.
Posted on Sep 15, 2009
  • 903 Answers
SOURCE: Multi-Function Center MFC-240C All-In-One InkJet Printer: i get the message "print unable 36" displayed on m...
Error code 36 is generally because of a paper jam that was not cleared. Remove the rear jam cover (the plastic cover in the back center of the machine)and the paper tray and check for any pieces of paper. Sometimes just a scrap will remain, but it's enough to cause the machine to not work.
Once you've replaced the covers, if the jam code does not reset, turn the machine off and then back on.
Posted on Jun 04, 2010
  • 525 Answers
SOURCE: I cannot print from printer brother DCP-135C with
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
4. then use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter : Note this does not overwrite the number next to PURGE on the LCD screen but once the last number is added it gets reset to 0000
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Posted on Feb 02, 2011
I have a brother's MCF-255MC printer and i keep getting the message unable to clean 50 I followed the steps in the manual and it still didnt work could you please help me?
How do I clear the message "Unable to..." or "... Unable" ? ' Brother
support.brother.com/g/b/faqend.aspx?c=gb&lang=en&prod...eu_as...
Aug 18, 2014 - Unable to Clean (Clean Unable); Unable to Init. ... If the encoder gets markings or debris on its surface, it may cause other problems.
Brother Unable to Clean 50 Error - YouTube
? 0:51
https://www.youtube.com/watch?v=8THfCUgYCMU Jun 9, 2015 - Uploaded by Aceh Com
Printer Brother Unable to Clean 50 Error Cara mengindentifikasi Printer Brother Unable to Clean 50 ...
Clear the "Unable to Clean" Message ' Brother MFCJ4510DW ...
? 1:49
https://www.youtube.com/watch?v=EH3CEA3WbEY
Aug 2, 2013 - Uploaded by Brother Office
Yeah, keep it ... Clear the "Unable to Clean" Message ' Brother MFCJ4510DW, ... assistance, please ...
Printer is displaying unable to print/init/clean 50. Have referred
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting Get a Professional Answer ... Have referred to brother manual and there is nothing jammed in the machine. ... To attempt to resolve it, do the following steps created by Brother in this step by step guide to try resolving the error message: ... Unable to init, unable to print, unable to clean, unable 36, error 46, 50 and error 32 are ...
I am getting error:unable to clean 50, was unable to print - JustAnswer
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting I am getting error:unable to clean 50, was unable to print - Answered by a ... What is the exact model of your Brother printer? ... For example, MFC-615 ... it is not allowing me to press any thing, I keep getting a beeping noise when I press .... How do I remove error messages, epson wf-2750, PC MS10, I 8/12/2017 8/12/2017.
brother MCF 255MC printer message unable to clean 50 Google Search
Aug 14, 2017 | The Office Equipment & Supplies
Hi I have Brother dcp 350 printer. I have the error 46 unable to print/clean i cant get the printer back to normal functions. I have change the inks (all) and I am still get the same error message 46....
The messages unable to print, unable to clean, unable 36, error 46 and error 32 are all print head errors.
1. Remove all the ink cartridges from the machine
2. Clean the contacts on the cartridges as well as inside the machine itself with a small amount of warm water or alcohol on a cotton swab until no ink comes off on the swab.
Note: if any of the other cartridges are low, empty, leaking or bulging replace them
3. Then turn off the machine and unplug it for 70 seconds
4. Plug it back it and wait for the insert cartridges message
5. Insert the cartridges and check to see if the problem is still there. If it is it means the print head has failed and in order to fix this the print head inside the printer needs to be replaced. The print head is the part of the printer that puts ink from the cartridges onto the page
Unfortunately this can sometimes cost more to replace then the machine itself.
Apr 18, 2011 | Brother DCP-350C InkJet Printer
I am getting an error message of unable to print 70 what does this mean and how can i solve this issue
There is a clear encoder strip running through the carrier from the left side to the right. CAREFULLY wipe it with a water dampened cloth. Gently, you don't want to knock it off. If that doesn't help you'll need to have it serviced.
Dec 01, 2010 | Brother MFC 490cw Color Inkjet...
Dear all here i am anil kumar from india i have MFC brother printer DCP-195C but i have facing problem when i print the page the printer show print unable error 70 please solve my problem thanks...
Error 70 normally is a paper jam or something else that is stopping your print head moving correctly.
Open the covers, have a look, and after clearing the jam you must power off and on the machine.
- Dirty encoder strip
- Foreign object, such as a paper clip or ripped piece of paper is stuck in the machine
- Mechanical malfunction
The most common cause of this issue is dirt on the encoder strip.
Oct 27, 2010 | Brother DCP 165C Compact Color Inkjet...
Canon i255 printer error 5100
5100 is a carriage error. check the timing strip for contamination (plastic strip about 1/4" in width). Check for obstructions.
more information on this error can be found at http://www.fixyourownprinter.com/forums/laser/25975
Jul 12, 2009 | Canon MultiPASS F60 All-In-One InkJet...
I do not see anything in the manual for error code 70 on the mfc 290c model Brother. I keep getting a message to check teh User's Manual for maintenance and trouble shooting. TEh machine is less than 6...
code 70 Error are caused by misconfigured system files,If you got code 70 error then 96% chance that your computer has registry problems.I will tell you how to fix it under 2 min and for this you can visit code http://tinyurl.com/nznbpm
Jun 20, 2009 | Brother MFC 210C All-In-One InkJet Printer
Error code print unable 5A on a Brother HL4070CDW
On most printers that are manufactured today have an error chip built onto the motherboard of the printer. If your printer experiences an error. It will register it on on the chip. You will continue getting the error because it needs to be cancelled. To cancel this error follow the instructions below:
1) Turn print on
2) Unplug the printer from the power
3) Wait at least 70 seconds
4) Plug it back in
The error should be cancelled
From Brother's website:
Print Unable ##:
Turn off the printer. Wait a few seconds, then turn it on again. If this does not clear the
problem, call your dealer or a Brother Customer Service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe Diaz
May 10, 2009 | Office Equipment & Supplies
Printer Problem
The computer and the printer are not talking properly.
Most likely the printer is unable to come online and thus cannot be initialized.
Michael
Jan 21, 2009 | Lexmark X85 All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
21 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
