Question about Dell 924 All-in-One InkJet Printer
My 924 has been working perfectly until last night and all of a sudden, the paper will not feed and the bottom right of the sheet trying to feed gets a wrinkle and then the feed stops. Do you have any suggestions?
  • 1003 Answers
SOURCE: Dell 924 paper feed
you need to clean paper feed rollers with isopropanol alcohol on a microfiber towel or get a sheet of cardstock to print on as it prints it will force out any foriegn material
To correct paper feed function make sure feed sensor lever isnt broken
Posted on Jan 07, 2008
  • 41 Answers
SOURCE: How to get my Dell Photo 924 to feed paper for printing?
if you are having issue with the paper feed ,moz-screenshot.jpg try these steps
1. Unplug the power adapter
2.open the printer cover , look for any obstructions inside , lift the printer and shake it firmly
3.turn the printer upside down and gently tab on the base,.
4. Put your Hand inside the Input paper tray and manually roll the two rollers
5. Put back the power adapter , turn on the Printer and try to copy a document from the printer.
Try all these steps and if you still have the paper feed issue then purchase the new printer
Posted on Apr 21, 2008
MsMitch
  • 41 Answers
SOURCE: paper won't feed
Dell.com will chat with you on-line to help you toubleshoot that printer.
Posted on May 28, 2008
SOURCE: paper jam/feed problem
ok i have the freakin same problem and the only i have in mind is that GET A NEW ONE printers are **** these days, makes me wana throw them out of the window lol but if ya need to print something important i suggest u go to the library ahh w,e....
Posted on Oct 05, 2008
stif_NEC
  • 441 Answers
SOURCE: paper does not feed
Try feeding a post card or a different kind of paper thru the feeder tray, make sure that it is going in smoothly.
Try something innovative for checking out those rollers
Posted on Feb 08, 2009
Hi, the paper feed into the printer does not work properly. when printing the sheet will try to deed in, then stop. I can hear the roller still moving until the error lights go off. To get a sheet to print...
get yourself a can of electronic contact cleaner in a arisal can. spray this on a rag and clean the paper feed wheels and the seperator pad (cork piece about 3/16 x 1inch) located right under the paper pick wheel.these wheels get glue build up on them and become slippery the contact cleaner will remove the glue with out leaving a residue behind
Nov 01, 2009 | Lexmark E210 Laser Printer
All-IN-One Printer 924 Deep Paper Jam, can not get it out
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 10, 2009 | Dell 924 All-in-One InkJet Printer
Paper doesn't feed right.
Normal 0 Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Jan 07, 2009 | Dell 924 All-in-One InkJet Printer
Paper won't feed and get's stuck
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
Good luck..
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Dec 30, 2008 | Dell 924 All-in-One InkJet Printer
PRINTER FEED ISSUE
Jun 19, 2008 | Dell 924 All-in-One InkJet Printer
Paper jamming and feeding unevenly
I have the exact same problem. Until last night it worked perfectly, and when it ran out of paper, I put more papers in the back of the printer correctly and since then it won't print, it pulls paper to the right and the paper jams. I tooked the printer to the service and they say that I'm lucky that the warranty did not expired yet, cause the problem is a "manufacturing mistake", and that they will take it to the Canon service.
I realy hope they will do the job. I'm expecting to repair be done till tomorow.
Apr 27, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Paper won't feed
Mar 31, 2008 | Dell 924 All-in-One InkJet Printer
Printer
mybe u put a lot of paper .try to put just one and place the paper holder to the left side of the paper
Dec 19, 2007 | Canon PIXMA MP210 Photo All-In-One Printer
Dell 924 paper feed
Oct 29, 2007 | Dell 924 All-in-One InkJet Printer
Epson R1800 refuses fine art papers
Hi Fruitless, Last night I was tearing my hair out trying to get my R1800 to accept some Hahnemuhle Satin 310, and it was just passing through and passing through. About once in 20 trys it would finally print. I was in the middle of making up my own paper profiles for this lovely paper. Anyway, I gave up at about 1:30 am, and went to bed. Today I resumed my attack, and guess what fella, there is a solution. Pass this on to everyone. You did not say what version of Photo Shop you were using. I just got my CS3 a week ago, and if you are using it, you can open a photo for printing. Go to Printing Preferences Dialog Box, > click on Maintenance Tab, and then click on the Bottom button that is labeled as Printer & Options Information. The Printer and Options Dialog Box opens, and there at the bottom is a box that says Thick Paper right beside it. Select or check this box and enjoy yourself thereafter. I did not see this in the User's Guide, but knew there had to be an answer to this problem somewhere. No problems ever since. Best of luck.
Sep 12, 2007 | Epson Stylus Photo R1800 InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
15 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
