Question about Epson PowerLite Cinema 200 Multimedia Projector
Red light flashing 1 per second, rebbot and image
Red light flashing 1 per second, reboot and image comes back but too blurry and dim to use
  • 2,237 Answers
Replace your lamp.
Posted on Nov 19, 2009
Hi, the photos i take are getting blurred and the image is not at all clear no matter how shot the distance may be i click the image.the only new icon i see on the screen is vibration warning symbol along...
If you are shooting in Auto mode with flash, this should solve your problem. Make sure you are not dictating any of the settings, i.e. choosing a longer shutter speed, a very small aperture setting, or a very low ISO (sensitivity) setting.
Typically the vibration warning icon will appear when the camera is trying to use a long shutter speed without flash in order to get the right exposure for a darker scene. Your outdoor (bright light) photos are probably OK.
In dim light with a point and shoot camera, you can have your choice between 1. blurry (using a relatively slow shutter speed), 2. dark (using a shorter shutter speed but no flash), or 3. a good photo with flash (which uses a medium shutter speed and added light from the flash)
Mar 12, 2011 | Cameras
Flashing red light
the ballast needs to be replaced.
Nov 12, 2009 | Epson EMP-54 Multimedia Projector
Sony KDF-55WF655 'rebooting'?
Replace the lamp . p/n XL-2200
Oct 05, 2009 | Sony KDS55A2000 55" HDTV
I have broadband cable service. My cable modem ic connected to a Linksys Dual band wireless router. My computer is then connected to the wireless router on USB port 2. My Link sys VOIP is connected to the...
First unplug your router, then unplug your modem and for 10 seconds. Next plug the modem back in and wait it to reboot(on mine this a series of 4 lights that light up in sequence, when the 4th light stops flashing, reboot is complete). Finally plug your router back in.
Sep 09, 2009 | Linksys Ultra RangePlus Dual-Band...
What is subfield ? panasonic says subfiels what is subfield ?
Does this help
A standard video signal is actually a series of still images, flashed on screen so quickly that we believe we are watching a moving image. The typical frame rate used in North America is 60 frames per second (60Hz) meaning that a TV would display 60 individual still images every second. Sub-field drive is the method used to flash the individual image elements (dots) on a plasma panel. For each frame displayed on the TV the Sub-field drive flashes the dots 8 times or more, meaning that the dots are flashing 480 times per second (480Hz) or more. (Example: 60 frames per second x 8 sub-fields = 480 flashes per second). subfielddrive_en.jpg
Jul 10, 2009 | Panasonic Televison & Video
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
It doesn't start up, only beeps and red light flashes
pls try to use another compatible memory stick.
then confirm the status of your micro processor
Apr 21, 2008 | HP Compaq dc7100 Ultra-slim PC Desktop
Red light continually flashes, and won't take picture
Set the camera to anything except no flash. Turn it off. Take out the battery. Wait 5-10 seconds. Put the battery back in. The flash should now work until you turn the camera off again (and then you must remove/replace the battery to get the flash working again).
The flash requires some kind of "master reset" to work. Haven't found a permanent solution to this.
Mar 05, 2008 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Epson PowerLite Cinema 200 Multimedia Projector Logo
236 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
