Question about Midland 75-822 40-Channels Handheld CB Radio
I have a midland 75-822. the radio with the battery pack in works great but the dc adapter or vehicle adapter (not sure whst it's called but it plugs into the car cigarette lighter and the cars antenna) doesn't work . do you have that part that you could sell
  • Frank Fulton
    Frank Fulton May 11, 2010
    Have you checked the fuse in the cig adapter? very common failure.
  • 3,018 Answers
  • Make sure to check the fuse to the socket you are using in your car. Get the multi-meter out and check for polarity before you condemn your DC cord.
  • If you have done this then make sure you check the inline fuse for the power cord. Sometimes the adapter itself (plastic piece that goes in the socket) has a fuse hidden in there.
  • The problem is the "official" DC adapter has the antenna and the DC power feed as a little pack that slides onto the radio. The actual power feed is a standard 12 Volt DC power cord available anywhere really for $5usd. If it was me (and anyone with minimal soldiering skills can too) pick up a 12 Volt DC power cord and either open the box up and carefully separate the two wires going into the pack and soldier a new 12 volt DC cord right in there.
  • One could separate the wires up a bit and just cut off a portion of the power cord and soldier in the new one without opening the pack as well.
  • Good luck to you and hope this helps.
Posted on Nov 03, 2011
    Champion:
  • 219 Answers
Take the one you have to a radio shack they should care one for you.
Posted on Nov 21, 2009
What voltage DC charger does a Midland LXT326 use?
http://www.buytwowayradios.com/Products/Midland/manuals/LXT-345-manual.pdf
I don't see it in there either. But since the battery is 4.8v, my educated guess would be somewhere around 6v. Its not stated in the manual though, and you can't see it on the picture towards the end where they offer a charger.
I don't know if you can charge by putting your own batteries in there. I'm guessing probably not, they usually put a different contact in there for the battery pack so you don't accidentally attempt to charge standard batteries.
Jul 09, 2014 | Midland Radio Communications
How many batteries connected in series at the battery pack there is?each one is 1.2 Volts, just add each one and add 10% Voltage.The final voltage is it
Wont turn on
did you try plugging it in. if its AC/DC try the other one to see if the switch is in the wrong position . May have a blown fuse also .
Dec 09, 2013 | Midland Radio Midland Gxt 1000 Vp4 Radio...
I have a Midland Public alert weather radio Model # WR-300 Problem is lost the DC in power pack. Wondering what the DC input voltage and current are for this model. I have some power packs but want the...
It takes 4 AA batteries, that is 6 volts. You will find that a 6V 500Ma power supply will be the right thing, just make sure that the polarity of the plug is right!
Feb 11, 2011 | Vacuums
WR-100 recieves fine with batteries but has nothing but static when plugged in
Check the back of the radio and make sure that the AC adapter is plugged in to an outlet that has the correct voltage for the radio to have power. Make sure that it is plugged into the DC jack securely.
Jun 16, 2010 | Midland WR-100 Weather/RDS Radio
Midland rechargeable battery packs won't recharge and vibrate
You might contact Midland Radio Corp to see if they have a fix for your problem. If I had to give an educated guess I would say the batteries need jump started (which sometimes happens when they are new and too low of charge; or there is a problem where they contact the charger and they are not receiving a full charge; or they are defective. I am sure the factory would be happy to assist you in solving the issue.
Here is there info: http://www.midlandradio.com/contact_us.asp
MIDLAND RADIO CORPORATION
5900 Parretta Drive
Kansas City, MO 64120
P. 816.241.8500
F. 816.241.5713
Email: mail@midlandradio.com
Nov 07, 2008 | Radio Communications
Midland radio battery pack constant vibrate
Hello pjbracht, I just responed to a duplicate of your problem. If they are new, return the battiers and confirm they are "by the book" replacements. If so ask for replacemrnts with a higher mAhr. It is not correct for vibration from a battery pack, lead, NiCad, Ni-MH, period.
Nov 01, 2008 | Midland Radio Communications
Low battery icon on Midland LXT350 walkie-talkies
Your LXT350 is equipped for using an optional rechargeable NiMH battery pack which can be recharged by inserting the AC adapter into the radio charge jack, or with the optional desktop charger.
I would make sure the radio is off, then insert the charger. Charge only for the prescribed time (no more/no less) and remove from the charger.
Charge time is initially 24 hours. Charge time is about 12 hours thereafter. For maximum battery life, it is recommend charging the battery pack when the low battery icon comes on. Remove the radios from the charger when the charge time expires.
Jan 01, 2008 | Radio Communications
Supersonic SC-299TDVD
Battery back needs to be connected to the DVD player when charging. connect the batter pack to player. Run the DC/out from the battery pack to the DC/in in the player. plug the charger into the wall.
if that does not work, you have a bad battery
Dec 27, 2007 | Supersonic SC-299TDVD
Midland 75-822 40-Channels Handheld CB Radio Logo
450 people viewed this question
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
