Question about GE JE2160 Microwave Oven
The paint (or whatever it is covering the bottom)
We bought this GE Microwave in April 2007, had to replace a tube in July 2008, and now the turntable has made a track on the bottom of the unit, and the paint can be lifted off in a sheet. What can be done about about this? It seems that we bought a clunker. We had our other GE Microwave unit for 20 years with no problems.
  • hoagann Nov 18, 2009
    That's a good answer, but I think the bottom of the microwave is beyond repair. It is showing the metal underneath. What above the metal? Paint, or some other substance?
    Scholar:
  • 53 Answers
Check the 3 wheels on the circular plastic part that's fitted below the turntable.
It sounds like they may need some filing down. Run your fingers around the wheels to see if there are any sharp bits of plastic that could be cutting into the paintwork on the base.
Clean out the base of your oven and apply a thin film of vaseline to each of the 3 wheels. This will help rotation in future.
Remember to keep cleaning out any excess food particles that may lodge below the turntable, as these will eventually slow down or stop the rotation, which in turn means that your food is not heated evenly throughout!!!
Posted on Nov 18, 2009
GE Profile Spacemaker XL1800 microwave turntable
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
On some, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Oct 28, 2013 | GE WB26X10037 Microwave Stirrer Motor
Paint inside microwave is chipped and blistered. How do you fix it?
HI,
If you are able to spent money for a new Microwave then go for a new one.
If you are interested to repair and reuse the existing Microwave then keep on thing in mind, if you paint it then also it will not lasts for a long time as the metal underneath is rusted.
Ajin
Jul 14, 2012 | GE Microwave Ovens
Mircowave runs but doesn't heat and it has a load hum.
You may need a new microwave..however, the diode may be defective or the magnatron tube may need replacing,,The magnatron tube is only warranted for 5 years so it may be used up as the model is (10years)fairly old.
Jun 18, 2010 | General Electric Microwave Oven
Not heating
most likly it is the mag and the diode. it should be covered for ten years after you bought the unit so check into that. you will have to pay a ge authorize servicer to replace it though but parts should be covered and still cheaper than a new microwave
Jun 02, 2010 | GE Adora DVM1850 Microwave Oven
Paint in the GE micro oven is flaking off.
no problems,,, just paint it,, so long as you use normal paints without any metal in them any enamel paint will do,, but it will work fine as it is,, it realy dont need any paint on it,, its only there to make it look nice,,however if you do paint it you must let it dry out fully before you use it again or you may find it go's with a big "bang!" when the paint catches fire!!!!!!!!!
Mar 05, 2010 | GE JVM1440 Microwave Oven
Flashing is occurring around the plastic turntable piece which is causing it to melt. Took off and saw that the enamel was pitted around the turntable opening. When I remove the plastic turntable piece, no...
It sounds like you are talking about the turntable tray adapter in the bottom.
What usually causes arcing is the reaction of the RF (microwave) energy acting on carbon. It's great that the motor and orifice are OK. Sounds like you just need to replace the T/T adapter. If the paint is pitted or altered, you need to use a special catalytic paint for microwave cavities to touch it up. The paint's main purpose is to protect the metal from rust but it is a high temperature paint to stand up to the higher temperature of that environment.
Sep 12, 2009 | GE JVM1350BW/WW/AW/SY Microwave Oven
I have a built-in GE microwave Model JTP85W0A1WW built in April 1999. It appears to work (fan turns on and digital readout counts down) but the turntable no longer turns and nothing is heated. Seems...
I had the exact same problem. There are two switches on the door. One is a safety lockout switch for the magnatron. The switch just wears out.
Jan 13, 2009 | Microwave Ovens
Metal turntable's enamel chipped, so sparks fly.
Try Going To Your Local Hardware Store And Finding Enamel Repair.
It May Just Cook But I Hope It Doesn't.
Jan 05, 2009 | Sharp R-820B Convection/Microwave Oven
I have an over the range microwave oven Spacemaker XL1800 that came with new house that I bought in July 2007. The control panel has a clear cellophane covering that is bubbling. Should this be removed...
Maybe I misunderstood what this site is all about. I thought you were from GE. This microwave is still under warranty and I want it fixed by GE. Please let me know what this site is. Thank you.
May 10, 2008 | GE Microwave Ovens
GE JE2160 Microwave Oven Logo
124 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
