Question about Cameras
I have an error code E210, any idea?
I have a Canon 6216 photocopier with an error code E210, any idea?
Rgds
  • 62 Answers
SOURCE: Canon copier NP 6216 all lights on!
Sounds like there is a piece of paper stuck in the machine somewhere. Maybe a sensor arm has been pulled out of location. Let me know.
Posted on Jan 22, 2008
SOURCE: e008 error code on canon
Brother DCP-8065DN Laser Printer no paper error please any solution for that.......!
Posted on Nov 04, 2008
  • 199 Answers
SOURCE: canon ir 2200 Error code E000064-0000
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
YES: Clean the contact, and set it once again.
2. Wiring
Is the wiring between the contacts for the following normal: DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
a. DC controller PCB (J301) <-> composite power supply PCB (J136)
b. composite power supply PCB (J130-7) <-> primary charging roller contact
c. composite power supply PCB (J130-1) <-> developing assembly contact
d. composite power supply PCB (FT133) <-> transfer roller contact
NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
Try replacing the composite power supply PCB. Is the problem corrected?
YES: Yes.
NO: Replace the DC controller PCB.
Posted on Feb 26, 2009
micromaster
  • 3614 Answers
SOURCE: Error code E210
Error E210 means - there is a problem with the lens position.
Under the glass there is a lens that moves to enlarge and reduce the copies. At switch on this has to find a home position. the error code means it has failed to do so. If you look at it is is driven by a belt. The drive pull for this can be seen through the glass. This becomes miss placed and is not driven correctly. Have a look and you will see has has come out of place. You may be able to take it apart and clean it up if not you will need a new drive assembly.
Posted on Jul 08, 2009
SOURCE: error code E007
Canon photocopier IR2016J show error code E007. Please advised me on how to resolve
Posted on Jul 10, 2009
E003 Error code in canon ir2420 photocopier
Code E003-0000 Description Abnormally low temperature (detected by main thermistor)
After the temperature detected by the main thermistor has reached the specified value, it does not reach the specified value during initial rotation. Remedy - Check the connector of the fixing film unit. - Replace the fixing film unit. - Replace the DC controller PCB. Error Codes Canon iR2420 Code E003 0000
Oct 28, 2015 | Canon Office Equipment & Supplies
Error code E210 any ideas
Jul 08, 2009 | Canon NP 6050 Copier
The screen just shows error E000
E000 code Fuser Error
What model of Canon copier is it?
May 15, 2009 | Canon Office Equipment & Supplies
Error code E007
May 05, 2009 | Office Equipment & Supplies
Canon NP6330
is requesting for identification number, use isteric 1111.
thanks
Oct 03, 2008 | Office Equipment & Supplies
Jan 21, 2008 | Office Equipment & Supplies
Cameras Logo
35 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
