Question about Hotpoint Aquarius WF220 Front Load Washer
Washing machine leaked, on/off button and dryer flashes, doesn't seem to be any problem with the hose pipe. but floor flooded.
    Problem Solver:
  • 5 Answers
Hotpoint aquarius washing machine floods every eash and will not drain. looked at the back hose but not sure how to disconnect to check for blockage. Also is there filter somewhere? none on the front and unscrewed the back panel but i could not see any filter, any suggestions?
cheers
Posted on Jan 10, 2010
  • 95 Answers
Water pump seal u\s
Posted on Nov 18, 2009
Flooding on floor
Look underneath for a hose leak on the drain pump. If this is a front loader, be sure the door and door seal is clean all the way around.
Feb 22, 2015 | Washing Machines
Kenmore washing machine 2 year old is now flooding my floor every 20 loads happiend 4 times. Please help.
Is the water flooding coming from the top of the washing machine?
Check the drain pipe in the back to see that it's not loose. Also, look inside the drain pipe and make sure there is no algae. Algae might cause low flow through the drain pipe and it will overflow.
Hope this helps.
Feb 07, 2014 | Washing Machines
Hotpoint wd440 washer/dryer. 1st problem was it wouldn't drain so I cleared the pipe. Now the machine 'wash' light flashes during a wash. The washing machine doesn't seem to hold the water...
Make sure that the outlet of the pipe is at least as high above the floor as the top of the machine. If it is lower than the level of the water, it will just drain - there is no shut-off valve to stop it from doing this. Please rate this answer.
Jun 17, 2011 | Hotpoint Washing Machines
How to set my wshing machine initialy?
If the laundry area already has all the set up, all you have to de is hook the washer's
Diagram of a washing machine to help you install a washing machine
drain hose over the sink's edge. If there is no sink nearby, the washer will need to drain into a standpipe. A drain pipe is basically a pipe with a diameter of 2 inches with a built-in trap that taps into the nearest drainpipe. The top of the standpipe should be between 18 to 42 inches above the trap. The trap should be about 6 to 20 inches above the floor. Standpipes are readily available with built-in traps or can be assembled using standard drainpipe and elbow fittings.
To prevent any unexpected and unwanted flood because of any leakage or bust f the hose pipe, you can use a single-lever valve in place of conventional washing machine shutoff valves. You can simply flip the liver to shut off when the washing machine is not in use.
  1. Screw the washing machine's water supply hoses onto the connections at the back of the washing machine. If the hoses are marked, orient them to hot and cold according to the markings.
  2. Connect the washing machine supply hoses to the right valves. Adjust the level of the machine.
  3. Put the drain hose into the standpipe or the laundry sink. Turn on the water supply valves, and check for leaks.
May 17, 2011 | Washing Machines
Why is my dishwasher flashing on the eco 45 button
This doe seem that the anti flood system has triggered. This device puts the machiene in pump out mode and shuts off the input water supply.
The device is a safety device that triggers once it detects a water leak (pipe / clamp) and consists of a polystireene float and micro switch at the floor of the washer. First check to see if the float has activated the micro switch and then dry the machiene floor and check for leaks.
Jan 25, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Hi my whirlpool dishwasher wont stop drainning even when the start button is of
This is a typical Anti Flood system activation. This system activates when water leaks onto the floor of the machiene due to a leak fault (pipe/hose clamp/ partly blocked pipe). The machiene automatically switches to pump out mode and stops water inlet. The anti flood system is a polystireen float / micro switch at the base of the machiene floor. Dry the floor and drectify the leak and it should work.
Jan 24, 2010 | Whirlpool ADG450 Slim-Line Built-in...
It wont start and is flashing to the symbol of an arrow pointing to a line
Jan 24, 2010 | Dishwashers
Leaking out of the bottom
The water drainage pipe is probably tampered. You need to replace it. Take apart the washing mashine and find the drainge pipe. If it is not tampered, some pipe is loose or broken in the washine mashine. If all this is too hard, call a repair man to fix it.
Apr 07, 2009 | Washing Machines
Water leaking all over floor
Just a suggestion but it could be that the person who installed it did not seal the pipes properly, hence the leaking on your floor.
If you recheck these pipes to prevent further problems and see what happens.
Regards,
David
Nov 05, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Hotpoint Aquarius WF220 Front Load Washer Logo
136 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
