Question about Garden
BOLENS, 4,5 HP Model # 90012 PN# 11a-084c163 SN: 10293-31672 We are looking for a manual to know what type/kind of oil and when to do the oil change. We would like to know if we should use only gasoline in the tank or a mix ?
  • 437 Answers
Use 30hd oil in the crankcase about 20 oz., change it about once a year. but check it every time you refuel.
it is a 4 cycle engine so it uses regular gasoline in the fuel tank.
good day.
Posted on Nov 18, 2009
Looking for a manual for a Bolens model 47018 wood chipper So far cannot find one
Try Googling (bolens)(47018)(manual) without parens.
Aug 06, 2017 | HP Garden
Use your computer search engine, type in "Bolens 47018 owner's manual " it will bring up sites to get manual.
May 05, 2015 | Heavy Machinery
Bolens manual
can you show picture and brand of motor
Sep 04, 2014 | Garden
Bolens 11a 074e065
Empting the gas tank and filling with fresh gas may take care of the problem.
Sep 28, 2013 | Mg International MasterCut 20" 123cc Push...
Bolens push mower
Bobbi it's most definately the spark plug. Change it for a new one
Sep 09, 2013 | Garden
ozarkshermit If you want a copy of mine I can e-mail it to you. I have a Bolens Owner/operator manual for the model 47018- 8 HP bluehue hotmail com
Mar 22, 2011 | Mtd Heavy Machinery
What type of oil is used in a yard machine lawn mower model no. 11A-414E029
SAE 30WT i.e non detergent. Change oil every 25 hours and every 4th oil change us a detergent 30 WT oil.
The manuals will never tell you that but having worked on small engines since the mid 60's that 4th oil change with a detergent oil does a bang up job of keeping the oil ring from eventually cooking onto the piston. Also washes out the crank case and makes it look like new!
Kelly
Sep 07, 2010 | Mtd 22" Yard Machine Push Mower
I have a bolens tractor that I think the coil is bad.It is not getting any spark.I dont know how to change the coil.I can not even see the coil.It is a 16 hp v twin that is a side shaft.The model # is...
Before you jupm to the conclusion that the coil is bad lets look at all the safety systems.
All of the itmes below will ground the ignition.
1. The oil level sensor. Check to make sure the oil is filled to full capacity. Service it if necessary. Check for spark after servicing. If there is still no spark disconnect ONE wire from the oil level sensor and check for spark again. If you have spark at that point the oil level sensor is bad. (Don't forget to reconnect the wire if it is NOT defective or you replace the sensor.)
2. The seat has a safety switch that is only actuated when there is a user sitting on the seat. Make sure there is someone sitting on the seat when checking for spark. If you still have no spark disconnect the seat safety switch connector and check for spark.
The seat switch is item 3 of page 10 this link: http://www.sonnysbolens.com/manuals/images/XL-MediumFrameSeries/1467-1667.pdf
3. The attachment drive switch Item 11 of above link can also cause the no spark problem if it is internally grounded.
4. The engine has an electronic ignition coil located under the flywheel. Any ground of the coil lead (black wire) from coil to oil sensor can also cause the no spark condition.
Thanks for using FixYa.
Kelly
May 20, 2010 | Garden
Lost the mother board cd.
you can download all latest drivers for your laptop model from hp support site www.hp.com/#Support
Dec 09, 2008 | HP Compaq nx6110 PC Laptop
Garden Logo
782 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
