Question about Ridgid 17038 4.5 Gallon Oil Free Twinstack Air Compressor
The compressor fills up with air fine.AS i start
The rigid double stack oil compressor fills up with air fine.As i start to use it with my tools the air pressure will eventually go all the way down to zero than fills up without the compressor going on.It does this a couple of times and than goes on to refill.It doesn't get a consistent flow of air before turning on again.Do i need a new pressure adjuster?Is it an expensive fix?
    Scholar:
  • 169 Answers
Yes sounds like a defective pressure regulator, I would order a new one and replace it, pay attention to the flow direction when installing the new one, they have an arrow on them to indicate correct flow direction.
Posted on Nov 26, 2009
  • 59 Answers
I would check the pressure switch. It probably has bad contacts in it. You could try to clean the contacts first before replacing the unit.
Posted on Nov 18, 2009
Our Hitachi EC119Sa will not start if the temp is lower than 60. It also kicks out the restart button
Easy test to determine problem. Plug compressor directly into outlet without extension cord. Start compressor with no air in the tank. It it starts, fill to 50-60 psi and unplug from wall to stop. Wait few minutes and plug the compressor back in. It it starts, most likely problem is too heavy oil or the use of extension cord. If it does not start after few minutes wait, most likely not unloading due to leaking intank check valve or bad cold start valve (see reference # 47 on your parts list). The cold start valve should release air from discharge tube after few minutes. If the intank checkvalve is leaking, the cold start valve will not work and stall the compressor. If all test ok, then just replace oil with 10 - 15 - or 20 wt. Good luck
Dec 26, 2012 | Hitachi EC119SA Twin-Stack Air Compressor...
OIL FILL PLASTIC CAP BLOWS OFF WHEN STARTED!
Hi
It sounds like the sump is being pressurised,and could have a problem with piston and or rings
Also checkout that the high pressure delivery valve is operating properly
John
Jul 29, 2011 | Stanley Bostitch CWC200ST 3HP Oil Lube...
The rigid double stack air compressor fills up with air fine.When i start to use it no air pressure comes out.
There has to be a restriction where the air leaves the compressor. Remove the supply fitting and check to make sure the hole is open into the tank. Also look to see if the fitting isn't blocked. If none of this is the case check the air line for blockage and also check to make sure there is no shut off valve in the line that isn't open.
Mar 13, 2011 | Air Tools & Compressors
Just aquired. Has plastic plug in oil fill oil, which blows out when compressor runs. if I tape the plug in place, the compressor runs fine. why
Check with maker but most vane type pumps the oil is under the same pressure as the tank
so you need a proper stopper !!!
Oct 22, 2010 | Ingersoll Rand DD2T2 T Win Stack Single...
Which air compressor is better-the rigid twin tank or the emglo twin take?
I think Ridgid has now lifetime warranties. You have to fill out papers and mail them. I have a few Ridgid tools and I love them. So check out the Ridgid, you can't go wrong.
Mar 16, 2010 | Ridgid 17038 4.5 Gallon Oil Free Twinstack...
What kind of oil goes in the compressor for a double stack tank, and how much , compressor is an haitachi electric
Here is the skinny on the OIL deal... Download PDF below.. www.imperialoil.com/Canada.../IOCAENINDESCompressor_Oil.pdf
Mar 05, 2010 | Air Tools & Compressors
Have rigid twin stack air compressor. Only keeps about 75 psi and keeps running. I do hear air from the exhaust port (seems normal). Haven't used it for a while. Any ideas? Thanks, in advance.
possiably the " reed valves under the head are not closeing off all the way. These may be bent or somehow distorted their tension most of the time from exsesive heat. Good luck
May 18, 2009 | Ridgid 17038 4.5 Gallon Oil Free Twinstack...
Air compressor will not start at all
push reset on motor -locate in instructions-this will solve. will happen a lot in cold weather -or if oil is low or dirty .
Oct 16, 2008 | Campbell Hausfeld 04 Gallon Twin Stack...
Ridgid 17038 4.5 Gallon Oil Free Twinstack Air Compressor Logo
551 people viewed this question
Top Ridgid Hammering Experts
Tim Whalen
Hippy_dd
Are you a Ridgid Hammering Expert? Answer questions, earn points and help others
