Question about Campbell Hausfeld Air Tools & Compressors
Need gasket and diagram to replace old blown set. tank will not fill. where can I find these parts
  • David Ford
    David Ford May 11, 2010
    what is the brand and model number and I will try and help
  • 530 Answers
Here is a link that may or may not have what you need. I wish I could be more specific however you didn't include any details like the model # of your compressor. We are here to help so if you can't find what you need at the site please respond back and include the model # of your compressor. If there is parts available I will find them.
Hope this helps.
http://www.mastertoolrepair.com/
Posted on Nov 23, 2009
Where do i find parts
Nixon Power Services in TN can help you with a part
May 01, 2013 | Kohler Limited Edition Marine Generator 2...
Cf2600 won't build pure pressure. Could air intake be stopped up. Had dirt dobber stop up on older compressor. Where is air intake. Can't locate.
No there is not a filter. Since the pump is enclosed in the plastic covers there would not be a way to service it. Now if it is not building any pressure then it could be a few things. First would be the drive belt. (item 125) If it breaks then it won't pump at all. Also if the air hose that exits the pump (item 122) gets a hole in it then it won't fill the tank. A worn head valve plate (item 106), blown gasket (item 105), or a worn piston and sleeve (items 109 and 112-2) can also cause this. If the check valve into the tank (item 16) gets stuck open it too will limit how much the compressor will pump BUT usually it will build up some pressure then just keep running without building any higher pressure into the tank.
Here is a parts diagram so you can see where the belt and other parts are located plus it contains all of the part numbers.
PC CF2600 diagram
Aug 23, 2012 | Porter Cable Air Tools & Compressors
Installed Fluidmaster 401LG Fill Valve but when I turn the water back on water leaks from the coupling nut. Please help!
Hi ttbailey71...
You need to unistall the fill valve and dewater and dry your tank.
After the tank is dry, put a little silicone on the top part of the threads on the fill valve
then put some silicone sealant on both sides of the gasket of the fill valve,reinstall,and snug the nut down on the fill valve body, do not over tighten...as the gasket will be pushed out from under the fill valve and will start leaking again.
Let the silicone set 24 hrs, then refill with water.
That should solve your leakage problem.
Free Aswer...Please take time to rate me
Jun 05, 2011 | Home
Need step by step explanation of removing and replacing a triangle toilet gasket.
Turn off the water to the fixture.
Flush the toilet and hold the handle down to let as much water out of the tank as possible.
Sponge the rest of the water out so the tank is dry.
Remove or undo the water supply tube from the fill valve.
Remove the three bolts holding the tank to the bowl and remove the tank.
Replace the old seal with the new one and reverse the whole process.
You should be good to go.
Good luck.
Mar 06, 2011 | Kohler KOHGP51487 Authorized Original...
I just replaced the fluid valve with the fluimaster 400AC and water coming out every few seconds from the bottom of the tank where the rubber seal is?
Hi, W/D here.
Easy fix. Tighten the nut on the underside of the tank that holds the fill valve in place. It will rotate inside the tank about 45 degrees (or so). While holding the underside with the wrench, rotate the fill valve with your hand back towards the right position, which tightens the fitting by about 1/6 turn. When you turn the fill valve, you want to have your hand spread over the valve as much as possible to apply a more equal pressure so that the valve doesn't crack or break. You can do this several times, if necessary, but don't over tighten. If it gets too hard to move, you may have to remove the fill valve and clean the rubber gasket and the tank seating surface. Make sure that the gasket is centered in the tank hole when you re-install it.
If the leakage is in the seal where the supply line mates to the fill valve, you can tighten it further, and this may cause the leak to stop, which is usually the case. Again, you may have to re-orient the fill valve if it moves. If this does not stop the leak, remove the fill line from the fill valve and inspect the end for cracks in the gasket or any other deterioration. If you are re-using your old line, you can remove the old gasket and use the one supplied with your installation kit. Should this fail to fit, or leakage occurs, you may need to replace the supply line.
Best regards, --W/D--
Jan 24, 2011 | Home
Cooling is boiling in the fill tank any ideas
Might just be air trapped in the system. Bleed the system on a set of Oil change ramps with the front end as High up as you can get it. Make sure the heater is on and that you get all the air out of the system before you condemn it to a blown Cylinder head gasket.
Could be a blown head gasket too. A radiator compression test $30, can find the problem.
Oct 26, 2010 | 1999 Volkswagen Beetle
Tank does not fill to proper psi. tank fills to 60 psi motor keeps running but wont fill to 150 that its supposed too. when i shut off compressor no air leaking????
strip the cyclinder off and inspect the valves if closing and opening also check to make sure you dont have a blown head gasket also on the tank from the pipe from the pump unit is a gold valve you need to open the end off this valve with the tank drained and turn the ruber around with the spring inside and replace this if still doesnt work get back to me bud
Sep 11, 2009 | Air Tools & Compressors
Water leaks from tank to bowl till water level in the tank is jus
Yes. You will have to remove your tank from the bowl to replace the defective fill stack(the tube thing your flapper is attached to) it is not as hard as it seems.First remove water supply tube.Then remove the through the tank bolts. should be two of them. Lift off and turn tank upside down. remove spud gasket. Unscrew old stack. You should be able to get a universal kit to work with your tank and should come with all new parts including new flapper and spud gasket. You will need new through the tank bolts and note the sequence of assembly to get water tight seal on tank. Hope this helps
Aug 03, 2009 | American Standard 2002.014 - Champion4...
Air Tools & Compressors Logo
43 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
