Question about JVC RX-8010V Receiver
I have a jvc rx-8010v receiver that i can only get sound to output with line direct selected. this only happens when you turn the receiver off and then on again. i was able to switch between dsp and speaker modes to get it to work again but that doesn't seem to work anymore. also it won't detect any digital inputs. i am able to leave it on for months at a time and it works perfectly but my wife turned it off and i can't get it to work properly now. any help? thanks
  • jas088ac Nov 18, 2009
    but it has happened before and playing with the settings i was able to get it to work again. this time my wife turned it off and i played with the settings some but i got aggravated and haven't really touched it. figured there would be a solution online
  • jas088ac Nov 20, 2009
  • JVC Master
  • 5,807 Answers
Since it would be working only if plugged for months,
there might me a little problem on your low voltage power supply.
this could as simple as a cold solder joints or just the circuit is
partially failing.
these unit does also have a delay when switching inputs from analog
to digital.
try working on analog signal first , like using "Aux " input from external
sources.it could be best detected if you have at least a signal tracer.
include the voltage reading on the low voltage regulators such as
+ 5 V, +12 V and - 12V.
have someone to help you, trace and measure voltages on the
preamp circuits, main amplifier might be good.
here is also some guide
Posted on Nov 20, 2009
  • Rommel Cana
    Rommel Cana Nov 20, 2009
    you need to test first direct , and analog then if there is no output or anything on your amp then there might also be a problem on your main amplifier circuits.
    it could be traced if the output voltages are OK.
    state whether you can hear anything on its output (speakers), so that we can analyze exactly what the problem you are having.
    President:
  • JVC Master
  • 1,114 Answers
Your DSP chipset has failed. This is not an inexpensive repair. Average cost to replace is between 350-500 depending on the svc center. It's a very labor intensive repair requiring human hair size solder points; roughly 100 points. The part itself is also difficult to acquire since most opt to replace the receiver. Sorry for the bad news!
Posted on Nov 18, 2009
  • Frank Fulton
    Frank Fulton Nov 18, 2009
    What has happened is the result of either a faulty chip or a cold solder joint that over time has finally failed. Unfortunately, the only way to be 100% positive is to put it on the bench and scope it. You can send it to any authorized service center for an estimate. On average it will cost between 50-75 and if you decide to repair, they will apply it to your estimate. Nothing would make me and you happier than for me to say it's a setting and this is what you do to fix it. Regretably, this is not the case.
JVC RX-801V - No sound from right channel in speakers or headphones.
I'd troubleshoot first, even though you've already tried the headphones (good thinking). Get a battery (AA battery works) and put the black and red wires on opposite sides to see if the speakers are working.
Is there a menu of settings on the jvc, and is it set to 5.1? Just trying to help...
Jan 15, 2012 | JVC RX-8010V Receiver
Jvc RX 8020 receiver won't play when in DSP or Surround modes no sound at all, can only get sound in analog direct. Owned for 6 yrs. first problem ever!
I'd suspect one of the controls that would be overriden by analog direct is unknowingly activated. LOOK at the front panel and interpret every indicator for how it could cause silence. Refer to the manual for those you don't understand.
Any Tape Monitor activation would disable digital sources completely.
See page 14 for how Line Direct affects DSP modes.
Jun 27, 2011 | JVC RX-8020V Receiver
I have jvc rx 801vbk and it is not putting a sound out i am positive it is not the speakers problem ??
Before you go crazy, and before you do anything, and before you take any of the above advice check the fuses!! Pop the top, look straight down to see 4 or 5 'buss' fuses. Lift at least one end of each fuse and check for continuity with a simple volt-ohm meter. I bet you find at least one bad. Bear in mind it blew for a reason so procede with extreme caution.
Mar 20, 2011 | JVC RX-8010V Receiver
I have the Subwoofer plugged into the output and have it turned ON but it's still not working!
It only drives a self-powerd sub.
The manual...
http://www.retrevo.com/support/JVC-RX-8010VBKC-Receivers-manual/id/315dj079/t/2/
Page 17:
Setting the Subwoofer Information
Register whether you have connected a subwoofer or not.
Before you start, remember....
• There is a time limit in doing the following steps. If the setting is canceled before you finish, start from step 1 again.
On the front panel ONLY:
1. Press SETTING repeatedly until "SUBWOOFER" appears on the display.
The display changes to show the current setting.
2. Press CONTROL UP / DOWN to select "YES" or "NO."
• Each time you press the button, the display alternates between "YES" and "NO."
YES: Select this when a subwoofer is connected.
NO: Select this when no subwoofer is used.
Note:
You cannot use SUBWOOFER OUT ON/OFF on the front panel (see page 14) and adjust the subwoofer output level (see below) when "SUBWOOFER" is set to "NO."
Then continue with setting its relative level and other things.
Feb 06, 2011 | JVC RX-8010V Receiver
Around 4 second after power up the unit shuts down..
my jvc rx-8010v turns on and after 4 seconds it shuts down.
Jan 05, 2011 | JVC RX-8010V Receiver
I have a JVC RX-801VBK. When I turn the power on it clicks on and shuts of. please help
the problem is probably a bad power transformer that will need to be replaced the best way is to contact JVC and they will be able to help you more. it may be easier to purchase a new reciever.
Jan 02, 2011 | JVC RX-8010V Receiver
No sound output at all
check your A-B speaker button. some have a small fuse inside.
Sep 08, 2009 | JVC RX-8010V Receiver
Whistling sound coming from output
Does the whistling show up no matter what you have selected for an input?
Disconnect all the inputs to the receiver and try listening again.
Let me know.
Thanks
Feb 02, 2009 | JVC RX-6042 Receiver
Reciever Shutting Down
I replaced R916 with a 10 ohm wire wound resister and that fixed the problem on the unit I have. That resister is in serise with R 915 so they should be close in value. Both were marked 8 ohms but tested about 11 ohms on R915 and the bad one tested very high (over 1 meg) so I replaced it. When I first put it back together it didn't work but I noticed that the ground screw at EP901 was not retighted so be sure that all ground screws are tight and all conections are redone before testing with the power cord.
Good Luck,
Thomas
Dec 13, 2006 | JVC RX-8010V Receiver
JVC RX-8010V Receiver Logo
150 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
