Question about Sony Cyber-Shot DSC-F505V Digital Camera
What is wrong with my Sony digital camera if it is turned on and then goes off and it is intermitten.
When I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's...
When I turn on sony cyber-shot camera I get a Problem with the Sony Cyber-shot DSC-W35 Digital Camera when I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's wrong??
Oct 12, 2011 | Sony Cyber-shot DSC-W35 Digital Camera
When i turn my camera on the lens goes in and out and when its done it says 'turn camera off and on again' what is wrong with my camera
the message "turn the power off and on again" actually indicates that there is a mulfunction w/lens. you can try initializing the camera.make sure your using a fully charged batt. (home>settings>main settings>main settings1>initialize).if it still doesnt work, try power reset procedure (turn power off,remove batt, and leave cam w/o power for more than a min.) if still issue persist your camera might require repair or you can go this unconventional route:
http://www.camerahacker.com/Forums/DisplayComments.php?file=Digital%20Camera/Sony/dsc-w50_acess.turn_off_on_again
...so banging the camera may actually work some times.but be careful doing this might cause injury or hardware damage...but what have you got to loose anyway. hope this works for you.tnx:)
Apr 30, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
My lens focuses only intermittenly
If you have the settings on AUTO the camera will automatically adjust to what it thinks will make the best picture.
Try and use the SCN.
You can also switch the flash on and off as you wish.
For more tips and tricks on picture taking please follow this link:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=38/13915/39&pq-locale=en_US
Jan 02, 2010 | Kodak EasyShare M1033 Digital Camera
Turn of and try again
you camera goes in a stand by mode you need to use a memory card nothing is wrong with the camera. So I would suggest you must use a memory card reader for this purpose.
Jan 20, 2009 | Sony Cyber-Shot DSC-P52 Digital Camera
Twisting the lens on the Sony DSC W55
hi there
take the end furthest from the camera and twist to the left then the right very gently and pul gently also do not force it you must be carefull with it. it is usually just grease or dit trapped inside the movement
Sep 18, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
AV Out Keeps Turning Off
Okay well you have to eject the tape and leave the eject open. There is an auto timer that always turns off the picture. If you open up the tape eject and leave it open the camera will always stay on.
Mar 06, 2008 | Sony Handycam DCR-TRV140 Digital Camcorder
Sony DSC-S500
you are right it has defective mechanism,  a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Oct 11, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony Cyber-Shot DSC-F505V Digital Camera Logo
15 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
