Question about Amana SXD524VW Side by Side Refrigerator
SXD26VW WILL RUN AND FREEZER WILL GO TO TEN DEGREES AND REF GOES TO 35. WITHOUT OPENINING DOORS BUT TO CHECK TEMP IS 40 DEG AND REF 55 IN A MATTER OF A HOUR
  • Amana Master
  • 5,568 Answers
Listen for fan noise under the cabinet; the fan responsible for circulating air past the coils may have failed. You should also be able to detect a flow of warm air coming from the vent near the floor.
If you have air flow there, the system may need recharged with coolant. If it has ever been moved, the system may have gotten a leak during transport. This will require a service tech.
Posted on Nov 18, 2009
The vegetables in the vegetable drawer freeze. the freezer registers 0 degrees and the refrigerator 40 degrees
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 21, 2011 | LG LFX25960 Bottom Freezer French Door...
Magic chef side by side ref side at 40 deg freezer side at 25 deg but it runs constant. could the thermostat be bad
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
If you need more help go here:
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Sep 19, 2011 | Magic Chef (CSD2610KRW) Top Freezer...
Fridge cool @ 39 deg but freezer warm @ 65 deg on Samsung md#RD267ABRS
NOTE: This
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Sep 19, 2011 | Samsung RF265AA Bottom Freezer French Door...
2007 french door -bottom freezer -kenmore elite fridge- freezing foods in fridge and icemaker not making ice regularly- sporatically making small amounts of ice cubes motherboard was replaced when fridge...
Leo Ponder
imufo2
Sep 14, 2011 | Refrigerators
My refrigerator temperatures suddenly changed from 40 degrees in the main compartment to 8 degrees and -30 in the freezer compartment. I'm unable to adjust the temperatures back to original settings. ...
Leo Ponder
imufo2
Sep 05, 2011 | Refrigerators
Cooler is running too cold / 11-19 deg.
Leo Ponder
imufo2
Aug 24, 2011 | Refrigerators
I have a top refrigerator bottom freezer model # JFC2087HRS no ice maker my freezer only gets down to 26 deg F the refrigerator is about 40 deg. F
NOTE: This
If
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Aug 20, 2011 | Jenn-Air JFC2087HRS Side by Side...
Last two weeks refrigerator temp goes anywhere from 30-35 degrees and freezer temp -5 to -1 degrees.several times a day we attempt to set temp to reccommended temp, but no success.we do not have mannual,...
fridge temp should be 30 to 35 degrees/freezer -1 to -5 f or between 2 to 5 C for fridge and -18 to -22 C for freezer several times a day is too often...... try once every 2 days without opening door in between checks....
Feb 11, 2010 | GE Profile PSW26P Stainless Steel Side by...
Temp problem. freezer temp 0 deg. fresh food 46 deg.
An hour aint enough. Turn off fridge, use blow drier, thers a huge ice cube behind that sheetmetal wall back of freezer inside wall, it takes 48 hours at 75 degrees to let it do itself. Listen for inside motor, its obvious. If so, you hve a defrost problem.
Mar 12, 2009 | Refrigerators
Amana SXD524VW Side by Side Refrigerator Logo
115 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
