Question about Saeco Incanto Classic Espresso Machine
Small coffee and coffee buttons flashing, hot water button on solid, water tank and priming butten on solid. I can open steam knob and let cold water run all day, but that's all that happens. What's wrong?
  • d2batista Nov 18, 2009
    How do you get to the flow meter?
  • 1,089 Answers
HI
Its your flow meter. If you have a restriction in the intake line the message will not go away. There is a flow meter inside the machine that measures water flow. If the flow meter does not spin when the pump is running, the computer thinks that the pump is not primed. Coffee grounds will get into the intake and restrict the flow meter. If you get a restriction in the water intake (below the water tank, on the machine) the pump may run and water comes out, but the flow meter does not create the jet of water to spin the turbine wheel to send impulses to the computer. You get the ventilate message.
You need to take the flow meter apart and clean it or replace it.
Posted on Nov 18, 2009
How do i prime the machine.? i hav e tried every button.
Press the hot water button to select water then open the knob to run hot water from the steam tap.
Jan 27, 2011 | Starbucks Saeco Italia Digital Barista...
Hello The lights on the front of the machine wont stop flashing so I can't press the cup symbols to make coffee. The hot water is coming out though through the steamer spout. Thanks!
Circuit Priming
When the machine operates for the first time and when
all the water has been dispensed, the machine circuit
needs priming. In this case, the 4 buttons of the control
panel will flash at the same time.
• Press the ON/OFF button . The 4 buttons will
flash.
• Place a container under the cappuccinatore.
• Open the "hot water/steam" knob by turning
it anticlockwise.
• Press the hot water button.
• Wait for water dispensing to stop.
• Close the "hot water/steam" knob by turning it
clockwise. Remove the container.
When the first priming ends, the warming up
starts. Before brewing coffee, water and steam,
please wait for lights 15 and 16 to be permanently on.
The machine is now ready to brew coffee and dispense
steam. Please see related sections for operating details.
Note: if priming is not completed, the 4 buttons
will keep on fl ashing. The machine cannot be
used.
Jan 14, 2011 | Saeco Nina Bar Espresso Machine
How do you descale a Saeco Magic Comfort Plus coffee machine? do you buy some fluid from somewhere and pump it through or what?
Hi
To descale your Magic Comfort +, enter the menu and scroll to descale. Push the menu button to descale. Mix your solution in your water tank. Use warm to hot water and dissolve all the solution. Place the water tank on your machine. With a container under the steam wand that is large enough to catch all the water in the tank, you are ready to begin. To start the descaling process, open the steam knob. The machine will automatically start the descaling process and when it is finished, it will shut off and tell you that it needs to be rinsed. Remove the water tank and rinse with fresh water. Refill the water tank and place it on the machine. Turn off the machine, wait a moment, and then turn it back on. Press the hot water button to start pumping fresh water through the boiler. Pump out about 16 oz. of water and then turn off the hot water button and open the steam knob to rinse the steam boiler. When it starts to go to steam, turn off and turn on the hot water button again. Pump out another 16 oz. Repeat this process with the steam knob until you have emptied the water tank. Descaling is complete. Go to your menu and scroll to "reset descale", push the enter button and chose "Yes" and push the enter button. Now it will tell you we next to be descaled.
Jun 11, 2010 | Saeco Magic Comfort Plus Espresso Machine
Flashing lights on my saeco italia espresso machine
I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Feb 22, 2010 | Starbucks Saeco Italia Digital Barista...
Saeco Italia SUP021 YR green lights and red water light flashing
You can't manually reset. The machine will have to do it. I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Sep 14, 2009 | Starbucks Saeco Italia Digital Barista...
Starbucks Sirena. lights blink, won't heat.
johnshami had this solution on another post, and it worked for us:
  1. make sure the water in the tank is stone cold -- which is a no brainer since it will not heat h2o unless it's primed.
  2. take off steamer wand cover, turn the steamer knob clockwise till pump starts.
  3. then s*ck (as you would on a straw, with your lips sealed around the end of the steamer wand) the tip of the end of the metal tip hard until pump stops
  4. may need to do it a couple of times. yes this seems crazy, but it works! you are flushing out the vapor lock in the pump.
Jun 10, 2009 | Saeco Starbucks Sirena Espresso Machine
Descaling
(Button 26 is the right-most one (2 intersecting
ovals.)
From the Manual:
Press the button (26) for at least 5 seconds to
select the descaling operating mode; the LED
emits a fixed light.
• Direct the steam nozzle (14) toward the drip
tray.
• Position a vessel of adequate capacity under
the steam nozzle and turn the hot water knob
anticlockwise (16). The appliance starts an
automatic descaling cycle with pauses preset
by the manufacturer and managed
automatically by the appliance.
• At the end of the cycle, the flow of the
descaling solution is shut off and the 5 buttons
start flashing simultaneously.
• Turn the knob of the hot water nozzle (16)
clockwise to OFF. In this case, also the warning
light (27) flashes.
• Rinse the water tank and fill it with fresh
drinking water.
the steam nozzle and empty 2/3 of the
contents of the water tank by turning the steam
knob (16) anticlockwise; to shut off the flow,
turn the knob (16) clockwise.
• Let the appliance heat up and empty the
remaining contents of the water tank by turning
the steam knob (16) anticlockwise; to stop the
flow, turn it clockwise.
HTH
dave
Aug 14, 2008 | Gaggia Syncrony Compact Coffee...
Water won't flow through the tubes
You might need to prime the pump manually since the machine has been moved.
directions:
Fill water tank.
Turn power on.
Open the steam knob all the way.
Press the coffee button.
Put a cup under the steam pump wand.
Wait until you see a steady flow of water and no air.
When you see the flow of water, close the steam knob.
Turn off the coffee button.
Now the machine should be ready to brew an espresso.
If that does not work you can contact the service center for more suggestions:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Mar 29, 2007 | Briel Chamonix ES-35 Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
561 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
