Question about HP Photosmart 3210 Printer
Fault 19a0002 ?????????????????,, must be a fault that happens many times with the HP 3210 all in. can somebody help me ?
    Genius:
  • 1,018 Answers
Are you reporting the correct error. I cannot find it on the HP web site.
I did find an Fault error "0xc19XXXXX". This points to a ink cartridge error.
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
If this does not apply to you, please let me know because there are some other things that might apply
Don
Posted on Nov 18, 2009
Ink system failure error: 0xc18a0007
Look for your specific error. Click the link for reset if your error is not found:
HP Photosmart 3210 Ink System Error
Failing this, your 3210 may require repair service.
I hope you found this document helpful.
Dec 28, 2009 | HP Photosmart 3210 Printer
Local shop says my hp 3210 has fault with ink purging mechanism and cannot be repaired is this true!
Probably, it is true.
You could spend $60 at a different local shop, to get the same diagnosis, or you could invest that $60 into buying a new HP printer.
Try to buy one that uses the same ink-cartridges as your current printer.
Nov 18, 2009 | HP Photosmart 3210 Printer
Black Ink shows empty even after installing on HP Photosmart 3210
These cartridges are really only ik resovoirs for the printer. It does have an ink flow sensor, though. If the printer does not recognize the ink level, it is possible that you got a cart with a bad chip. I refill these alot, and all you can really do is check the chip on the cart and make sure nothing is on the contacts...otherwise replace. A good step would be to put the old cart in and see what happens...
Mar 10, 2009 | HP Photosmart 3210 All-In-One InkJet...
My HP Photosmart 3210 thinks the ink cartridge is still empty even though I have replaced it.
Very simple cartridge. Check the chip on the bottom to be sure that nothing is on the contacts. Try installing the old cart and see what happens. Fortunately, these are not very expensive. Install the old one, unless you ran it until it locked the printer out.
Mar 08, 2009 | HP Photosmart 3210 All-In-One InkJet...
HP Photosmart 3210 Printer will not scan any
I had the same problem and this is what I did to fix it.
Go to control panel
choose printers
look to left and find scanners and cameras
click scanner
a pop up should direct you to scanning options and will lead your scanner to scan the item
hope this helps
Mar 04, 2009 | HP Photosmart 3210 Printer
Paper jam in an HP Photosmart all in one 3210
look at the rear of the machine for an access door.
Feb 03, 2009 | HP Photosmart 3210 All-In-One InkJet...
ok u neeed to to remove all old drivers all printer driver form add remove then run www.ccleaner.com tool get left junk out then go to hp.com download latest driver for your printer vista or xp need try that 1st thx nick
Oct 07, 2008 | HP Photosmart 3210 All-In-One InkJet...
Black Ink Doesn't Work!
nozzles are probally caked with dried ink. remove ink cartrige and clean nozzle area with q-tips and rubbing alcohol(gently) if you can figure hou to remove soaking in warm water works the best. dry for at least a day before re-installing.
Jun 26, 2008 | HP Photosmart 3210 Printer
Paper jam
I tried the Cleaning Kit HP sent me. At the time they didn't mention that it required a direct USB hookup rather than the Network setup I was using.
Another user suggested using Lighter Fluid sprayed on the defective (too hard) paper feed wheels. Crazy solution? Lighter Fluid is mainly Naptha which the user claims softens rubber.
I tried it last night and waited for the fluid to evaporate before plugging the printer in. I really expected the darned thing to go up in flames so I had a pot of water and a blanket nearby as a fire precaution.
Much to my surprise .. the PSC 3210 has been feeding sheets perfectly for the past two days! This is after sitting in a HOT attic abandoned for over a year! I had to replace one ink cartridge which had dried out completely.
I don't know how long this "fix" will continue working but Lighter Fluid is cheap. The PSC 3210 is a quality printer WHEN it prints. It's too bad HP created so much bad will in its customer base because of defective rubber paper feed wheels. I've avoided purchasing HP products for two years now and have warned others to stay away because of this fault with customer service. Instead of replacing the defective rollers in my original printer, they exchanged the printer for a refurbished printer with the same defective rollers!
Mar 31, 2008 | HP Photosmart 3210 Printer
HP Photosmart 3210 Printer Logo
85 people viewed this question
Seeker5211
Seeker5211
