Question about Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher
Door handle loose
I took the screws out of the door panel to get to the screws holding the door handle in place. As I pulled the panel off the door, two plastic pieces fell out on to the floor before I could see where they belonged. Tightened the door handle screws and put the panel back on. Washer is working fine. Must be some type of spacers.
  • Anonymous Mar 26, 2014
    Handle is loose. Cannot figure out how to tighten it. There are two two holes under the handle but no tool seems to work.
    Sniper:
  • 74 Answers
They are a vivration attenuator and yes are spacer too, but are a little dificult to mount if the machine are working well ok leaved like that but check every coples of month for a loose screew.....good luck and rate me
Posted on Jan 10, 2008
  • take123 Jan 12, 2008
    hey rate me plis
Drivers door handle replacement....would like to see how to sheet
on inside of door panel r3-6 screws pull out panel pop off be gental dont break tabs that unclip 1 screw holds handle on unclip rod connecting hanle on out side 2 handle on inside pull out put together how u took it apart
Jan 26, 2011 | 2006 Buick LaCrosse
Tip
Door handle repair for Ford fusion
The door handle will not allow unlocking from the inside. This is a common problem with the Ford Fusion 2007 to 2012 and other cars. A cheap piece of plastic breaks that connects the lock lever with the door handle. You can roll down the window and unlock from the outside or hold both levers together and pull open from the inside. This is a very simple repair. Go to any of many web sites for auto parts and buy a replacement. I bought a Dorman 81702 Ford/Lincoln/Mercury Interior Front Driver Side Replacement Door Handle. I popped off the lid that covers a hidden screw inside the recess of the door handle. You have to use a torque bit to unscrew the screw. I then unscrewed the torque screw holding the upper part of the door panel that is opposite the door hinge. The upper part of the door panel can be be carefully pulled away with moderate pressure allowing access to the door handle mechanism. One more bolt holds the door handle part in place. Pull out the broken door handle part, remove the locking cable and put in the new part. Reverse the process to finish up. The whole process took about 10 minutes.
on Sep 18, 2015 | 2010 Ford Fusion Hybrid
Trying to remove rear door handle on chrysler lhs 99
Hello, to remove and replace the rear door try the following:
1. Disconnect the negative battery cable from the battery of your Chrysler LHS. You can accomplish this with an open end wrench, to prevent any injury or short in the electrical system as you are working on the door lock switch. Place the negative battery cable out of the way so it does not touch any metal parts.
2. Undo any screws that are holding the lower door panel to the door with a screwdriver. Unclip the plastic hold clips that are attached to the back of the panel by carefully pulling them away by hand.
3. Locate the electrical connector wires. These wires run behind the panel to the door arm rest and detach each wire connector by hand. Remember how the wires were attached so you can put them back the same way when it is time to reattach them.
4. Lower the door panel away from the door. Then, remove any screws holding the upper door panel in place. Remove the door handle pull cup that covers the door lock switch and door handle by carefully popping the cover off after you have removed the screws holding it in place.
5. Detach the upper door panel from the door. You can do this by pulling it away carefully from the plastic clips. Move the upper door panel out of the way and locate the door lock actuator switch. Remove the screws from the actuator switch that are holding it in place and disconnect the electrical wires attached to the back of the switch.
6. Replace the old door lock actuator switch with a new one. This replacement can occur by connecting the electrical wires to the back of the new switch and reattaching the switch to the door frame with screws. Put the upper door panel back in place, securing it to the door frame with plastic clips and screws.
7. Reattach the door handle pull cup to the upper door panel with screws. Then, put the lower door panel in place and reattach the electrical wires to the window switches underneath the armrest. Attach the lower door panel to the door frame with plastic clips and screws.
8. Attach the negative battery cable to the Chrysler LHS battery with the open end wrench.
Thanks
Jul 27, 2010 | 1999 Chrysler LHS
How do you remove interior door handle form 1993 Ford Tercer The window won't roll up and I can't get the handle off to get the panel off to get to the window tract
It's easy!
  1. Remove triangle-shaped plastic cover Fwd of door window - gently pry it off
  2. Remove screw from the plastic cover behind door open lever
  3. Remove door lock plunger. (unscrew)
  4. Remove screws down inside the door pull hand-hold area
  5. Look for other phillips screws - sometimes around the lower 1/2
  6. Pry hidden plastic hold down fasteners from around the edge - pull the panel away from the door and where you see it 'stuck' to the door, slide a pry tool, a stiff putty knife works well, up in that area and pop the fastener off.
  7. Lift door liner enough to get to the mirror power connector and unplug.
  8. For some model years, with door panel loose, you can access the bolts / screws that hold the interior trim piece in place and remove.
  9. Remove Mylar cover for access to 3 Mirror mount studs, speaker screws, door lock actuators, window motors, etc.
  10. Remove nuts, (hold the mirror up from outside) and remove mirror. (Feed electrical harness through door openings as required to facilitate removal.
  11. Reverse order for installation.
Jun 01, 2010 | 1993 Ford Taurus
Driver side door handle (outside) and gas pedal 2000 Camry
Bring the vehicle into the dealer if you have a sticky gas pedal. This is a TOYOTA PROBLEM.
Door handle:
It easy ! You need a philips2_bing.gif and flat screw driver,and a needle nose pliar.
Use flat screw driver and pry out the two or three dust covers for the arm rest screws then use philips and remove the screws. Next use the flat screw driver and pry out the black plastic mirror cover from the inside of the door. Pry out the switch with the flat screw driver and disconnect it. On the side of the door panel just above the striker/loch mechanism is this plastic push pull type of a hold in screw. Use flat screw driver to get it to move a little then pull it out with the needle nose. Depending on which door your doing if you have a map folder in the door there are two more screw to remove on the bottom of the door.
Now the inside door handle is tricky it comes out in TWO pieces. Use philips and get the only hold down screw you see out.( you may have to pry out a little screw cover first) Now the inside door handle cover is removed by placeing the flat screw driver on the rear of the outside of the cover top and on the outside rear bottom to release the tangs that are holding it onto the panel.Pry it out lightly you may have to place the screw driver over the top of the door release button and pry that way. Don't loose your cool its a pain but it will fall out. Once its removed unhook the panel.
Next lift the plastic cover and remove the door handle hooks and levers . Basically use common sense this is easy stuff. There may be two screws from inside of door panel that keep handle in place . Then work handle loose from outside and inside . reverse for installation.
Jan 27, 2010 | 2000 Toyota Camry
1998 chrysler concorde lxi rh side view mirror installation. how do I access the plug, which is inside the door panel so I can unplug the old mirror plug and install the new mirror plug. I took off the...
you must remove inside door panel all the screws going into door including screw for inside door handle. you will be able to reach it then. try not to break any brackets surrounding screws(you will have a loose door). took me 15-20 min.
Jan 17, 2010 | 1998 Chrysler Concorde
I need to replace broken driver side door handle.
In the auto glass trade there are very basic tools used. Most door panels are held on with a few hidden screws - behind latch handles under them, look any where that the door receiveds pulls or pushes. after all the screws are out 4-6 then the panel will either lift straight up to come off or pull straight out if it comes out then there will be some push plugs also holding that hold the panel in place and you could use a flat forked pry bar to pop them loose. Just take you time and you should be fine.
Feb 23, 2009 | 1999 Hyundai Accent
Loose oven door handle
I had the same problem. We took the door off completely & turned it upside down. There are screws on the bottom of the door, take them out, take off bottom trim piece that holds the outside glass panel in place, remove glass panel and you can access the door handle screws and clean the inside of the glass while you are at it.
Jan 05, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Door handle loose on 10656542400 kenmore
The solution on the Kenmore 56822 turned out to be very simple:
With the door closed, pull up on the door handle (requires some force). The door handle will slide up, and once it is up, it can be removed by carefully pulling it off of the door. Then the screws holding the mounting lug can be tightened. Place the handle back on the door, and slide it down, and voila, no more loose handle. I am going to put some LockTite on the screw on mine to ensure that it stays tight.
Nov 24, 2008 | Refrigerators
Front door panel removal
There is a triangular piece, at top corner, covering a screw behind the mirror. Remove that screw. Remove the piece that covers the handle and remove the screw holding the handle to the door. Look through, where door handle was and remove another screw just above where the handle was. This screw is holding the panel to the actual door. Pop the cover off for the automatic door locks and disconnect them. Lift the panel in an upward direction.
Nov 11, 2008 | 2000 Ford Expedition
Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher Logo
411 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
