Question about Toshiba Tecra M1 Notebook
Modem problem hi. I install my the driver for modem but it dosnt connect. error code: 633 .
Spent many hours of my life on this problem, so i took out the modem and replaced it, i noticed the connection was not good so i stuffed a small, but as thick as i could  get piece of cardboard  in under the cover over the modem on the mobo plug end. Then screwed it down again and it worked like a charm. Hope this helps. macbaz
Posted on Feb 16, 2008
Hi is not the drivers the problen is the settings in your bios you need go to the bios configuration and putting in default all and that set
Posted on Jan 17, 2008
    Problem Solver:
  • 23 Answers
Hi be sure that is the rite driver u using if yea try updating it, there could be some conflicting with yr devices check yr com port to make sure this is not so and check yr devices status in device manager that can also tell u what exactly is wrong, what i like to know is was the modem working before?
Posted on Jan 10, 2008
Hi i cant access to the internet . error 633 please help me
This error means The modem is not installed or configured for Dial-Up Networking. You need to check for modem driver in your device manager and if not present do install it
Apr 10, 2011 | Arris Chipset 56K V.92 PCI Internal...
Error 633 while using mobile internet on laptop
Error 633 is generated when the modem (or the phone you are trying to connect) is in use by other system. Check if the phone is already connected to other system or not. Or if there is any active session of internet going on in the mobile.
Hope this solves your problem.
Feb 28, 2011 | Cell Phones
I am using samsung gt-S5350 and tata docomo sim, I can access internet on my mobile but when i try to access internet through mobile on my lenevo laptop it gives "os error, remote device not...
Samsung PC Suite - Internet through mobile modem -Error 619 - Data Cable
Rectifying the error
1. Samsung USB modem driver (Download from Samsung ' Local Link)
2. Connect Your Samsung with a working Internet connection ( via )USB Cable
3. Samsung PC Studio or any other Samsung mobile drivers are not installed
Procedure
1. Connect your Samsung Star 3G to your PC and install the modem drivers that you have downloaded.
2. Goto Control Panel > Phone and Modem Options
3. Select the Modems tab. You will see Samsung mobile modem listed.
4. Select it and click on Properties.
5. Goto the Advanced tab and put the following in the box for Extra Initialization Commands:
+cgdcont=1,"IP","your_apn_name"
( or tye AT+CGDCONT=1, "IP', "apnname")
eg:- +cgdcont=1, "IP", "bsnlnet"
6. Hit OK and exit.
The next step is to create a dialler for your Samsung Star 3G mobile modem.
Error 619 solved
1. To create a dialler, Goto Control Panel>Network Connections
2. Hit Create a New Connection and proceed as follows (each sub-point is for each screen of the wizard):
2.1 Network Connection Type: Connect to the Internet
2.2 How do you want to connect to the Internet: Set up my connection manually
2.3 Select Connect using a dial-up modem
2.4 Select Modem-Samsung Mobile Modem
2.5 Type an ISP name according to your preference (could be anything)
2.6 Type*99# as the phone number ( or type *99*1*1# or *99***1# )
2.7 Leave Username, Password and Confirm Password fields blank
2.8 Hit Finish
That would complete the wizard and make a dial-up connection for you. Dial it and you will be connected to the Internet via your Samsung Star 3G phone modem without using Samsung PC Studio
Nov 01, 2010 | Samsung Modem Configuration Software...
I am using zte usb modem FFF1 for internet access via reliance netconnect.whenever I connect the device to laptop it is shown as storage device but as soon as i install the driver software a driver not...
The ZTE modem when initially connected to any system loads as a storage device which contains the software necessary to install the modem. Connect the ZTE and open it in Explorer. Double click the setup file (.exe) to start installation. Follow instructions and allow installation to complete. The modem is automatically installed during this setup. Once completed restart and then your ZTE functions as a modem.
May 19, 2010 | Computers & Internet
Shows error633
When you try to use your modem on a Windows computer, you may receive an error message similar to the following: Error 633 Modem is already in use, or is not configured for Remote Access dial out or The port is in use.
Try this one after the other
1. Verify no other applications that are using the modem. You can open Task Manager to check that by press CTRL+ALT+DEL. Another way to test it is reboot the computer.
2. This behavior may occur when another device with a driver, for example outdated Palm Pilot software, conflicts with the modem.
3. Telephone.ini or unimdm.tsp is missing or damaged.
4. Make sure the modem is setup correctly and may apply SP.
5. Removing and reinstalling it, or apply the new drive may fix the problem.
6. Make sure no two ISDN installed on the same machine and attempt to connect to the same server.
Apr 01, 2010 | Conexant All 56K Modems: Amigo V.92...
Error 633
right click on my computer and go to properties then hardware in that click on device manger and choose the modem option just expand the list it will show the modem which you installed just right click on it and got to properties and choose the diagnostics option and there is one tab down query modem it will communicate with modem if you find the character or response that means modem is correctly installed or if it is not that means you need to re install modem driver.
Sep 17, 2009 | Smartlink All 56K Modems: V.92 PCI Chipset...
Can't connect internet. message reads error 633,
Here is a tip to work normally your modem, transfer it to another PCI Slots in the Motherboard and install again with the driver freeware provided. See to it that no other programs run on the system that interrupt your modem installation and diagnose it.
Please rate me.
Thank you.
Sep 15, 2009 | HP BCM5705 Modem
Error no 633
You'll just need to update or reinstall the driver for the modem. Make sure to click on "Continue Anyway" when it prompts you about digital signing.
Nov 14, 2008 | Smartlink (I56KSPF00) Modem
Toshiba Tecra M1 Notebook Logo
75 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
