Question about GE WSXH208A Front Load Washer
I have a whirlpool front loader washer, and for no apparent reason there is a chunk of rubber missing, causing it to leak when in use. I was thinking instead of replacing the whole seal, if i can use a temporary rubber to seal it for now?
  • 61 Answers
You may be able to find a type of silicone or something like that to temp.fix it, but when it leeks a ruins your floors it would probably have been cheeper to replace the gasket. :)
Check out www.appliancepartssolutions.com if you decide to replace the part they are pretty cheep.
Posted on Nov 18, 2009
Whirlpool duet front loader washer has a water leak from under the machine. What could be causing this?
Pull off the lower front panel and watch while washing . You should be able to pinpoint it .
Mar 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer is leaking under front right corner at the end of rinse cycle--occurs following all wash cycles--does not do it on ''rinse only'' cycle.
Is this a FRONT LOADER? Or, is this a TOP LOADER?
If this is a FRONT LOADER, the following link explains what you have to do to determine the source of a leak:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
In most cases on a FRONT LOADER, leaks are caused by the rubber door bellow developing small rips or tears due to age and wear. If the bellow is leaking, it must be replaced. The following lik explains the steps necessary to do so:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If you have a leak on a TOP LOADER, the most common cause is a worn drain pump, leaking drain hoses or the hose to the air dome has come loose. You will need to remove the exterior case of the washer to be sure. DO NOT lay the washer on its back. The gearcase contains oil and it may leak through the breather hole.
The following link explains how to inspect a TOP LOADER for leaks:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
If the drain pump is leaking, it is not serviceable and must be replaced, the following link explains how to replace one:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Replacement parts (if required) may be purchased on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare.
Read through the instructions provided and let me know if you need further assistance. Please post back with a complete MODEL NUMBER so that I may be able to povide you with better assistance. I hope this help you.
Feb 04, 2010 | Whirlpool Washing Machines
Leaks from bottom but only when i put a small load in
If this is a Whirlpool FRONT LOADER you need to remove the lower toe panel directly below the door to inspect the cabinet interior for the source of your leak. The following link explains:
The most common source of leaks on a front loader is the rubber door bellow. The bellow can develop cracks, rips or tears with age and needs to replaced. The following link explains how:
If you have any questions about this repair, please let me know so that I may be able to provide you with better assistance. I hope this helps you.
Jan 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My inglis front loader washer is leaking at bottom of the door....inside rubber area near leak feels gummy....any advice??
Scrub the glass on your door and the rubber boot. This works in almost every case. The washer gets a build up of scum on these parts and doesn,t allow a tight seal. In rare instances you have to replace the rubber boot. Good Luck, Appliance Specialists.
Jan 04, 2010 | Whirlpool Inglis IP4400 Washer
AWM 8143 front loader- rubber door needs to be replaced
Yes,it is called a bellow.If the tear is small enough and just on the front rim of the seal try gluing it with super glue,it will get you by till you can get it replaced.
Sep 07, 2009 | Whirlpool AWM8143 Front Load Washer
GE FRONT LOADER WASHER LEAKING WATER
inspect the door boot the rubber thing between the tub and door also inspect the hoses inside the machine you will see the leak
Aug 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leaking front loader
If your washer has a rubber seal around the inside of the door and it has a little opening where the detergent comes into the washer put your hand inside the rubber piece and feel all the way around and see if you feel any holes or cracks in it and that is where it will leak from.
Dec 03, 2008 | Kenmore Elite 45986 Front Load Washer
Duet washer leaking
If the leak started occurring after the bellow was replaced, and it's on the left hand side of the door, I suspect the bellow is not seated around the fill tube all the way. I have experienced this problem before. Check the fill tube where it comes in by the door. The rubber should be seated back far enough to allow the tube to fill into the tub without obstruction. It could be that the fill tube is forcing water BEHIND the bellow and leaking into the washer and on to the floor. To answer your question, "YES", replacing the bellow could have caused your leak.
Sep 29, 2007 | Whirlpool Duet GHW9150P Front Load Washer
GE WSXH208A Front Load Washer Logo
82 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
