Question about Maytag Dishwasher
My GE Eterna Series 3 Quiet power is not cleaning our dishes. Mostly the dishes on the top row has lots of stuff found in the glasses and mugs. YUCK!! I ran it for a minute and there is just water in the bottom of the machine- no soap. The bottom and top spayer were spinning but the middle one isnt moving. Any Ideas???
I just took mine apart (bottom turntable, screen, etc.) and I was disgusted by the grime and gum that was clogging everything. I think it was keeping all the water a gritty white, which constantly left residue. I am currently running a load... hope that the "clean" dishwasher actually washes my dishes now!
Posted on Apr 02, 2011
I am having the same issue - any help would be appreciated :)
Posted on Nov 30, 2010
  • chipper312 Apr 02, 2011
  • rcapp69 Apr 02, 2011
    Thx - will try that. I replaced the water spinner (arm) under the top rack and the one above the top rack thinking those were clogged or not working right . I ran the dishwasher with NO SOAP - and it wasnt as bad - but dishes still coming out nasty and filmy. So - am thinking i will take the bottom apart like you suggested and see what is going on down in the bottom of the dishwasher. Thx for the heads up.
My maytag W10199645 is leaving gritty residue on my mugs & glasses. how can i troubleshoot this?
Try using a dishwasher cleaner. You can get it at any supermarket that sells dishwasher soap.
Nov 06, 2014 | Maytag Dishwashers
Kenmore dishwasher ultrawash debris on glasses
Fill the soap cup with vinagar and run it while its empty.
Mar 09, 2012 | Kenmore Dishwashers
I have a GE Eterna Series Triton XL. It is not cleaning the dishes very well. The top dishes (glasses & mugs have debris in them. Silverware not very clean either. Can you help. I have checked the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 01, 2010 | GE Dishwashers
Food remnants left on top rack of glasses and ceramic mugs.
Before loading into the machine clean the particles that are sticking to the dishes.
Check the drain filter at the bottom rack and clean. It is user cleanable
Apr 06, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
This dishwasher leaves residue on dishes (granular mostly) and mostly on the upper tray, in mugs and glasses. We have no manual and wonder if something needs cleaning out. We are sure to start out with hot...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Feb 02, 2010 | GE 24 in. Profile PDW7880G Built-in...
Quiet Series 300 does not clean top row of dishes.
ck for low water in tank . caused by bad water valve .. clean any screens in bottom of tank and ck center and top wash for things in holes .. hope this helps .. mm
Dec 07, 2009 | Washing Machines
Maytag Quiet Series 200 dishwasher doesn't clean well at office!
This is a very good dishwasher,I get calls on it for not cleaning all the time,but it usually ends up being a user issue because the manual doesn't go in depth enough on usage,First of all you have to use rinse aid in this unit or glasses won't come out looking clean,second you have to be aware of how much detergent goes into it because it's really easy to use too much.A good way to see if your using too much is too start a cycle without adding detergent let it fill and start to wash for about a minute then open the door,if it is full of suds your using too much,you can flush it out by starting a cycle(No detergent)and hitting the cancel drain button after about a minute several times in a row.then cut back the detergent by about a third on the next several loads and try the test again.
 If the film is chalky meaning you can wipe your finger across it and it comes off,too much detergent is most likely the cause.
 Also make sure the unit is getting hot water from the start of the cycle a good way to make sure is to run the water in a near by sink till it gets hot before starting the dishwasher.
 If you have really hard water you may need to run either some CLR (1/2 cup no dishes in unit)through it or one of the dishwasher cleaners made to remove calcium,lime and rust found in the dish soap isle...Hope this helps
Sep 05, 2009 | Dishwashers
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
Maytag Quiet Series 300/Dishwasher leaving gritty stuff on dishes
My model is simillar Cheri's. Every couple years I have to remove the plastic spray bars. They are held on by a simple torque screw. Once removed you will see debris plugging many of the holes. I have found this on all 4 of my spray bars. This debris prevents the right amount of water in the wash and rinse cycles. The upper spray bars seem to be the worse. This explains the trouble most folks have with glasses in the upper rack. Also check the docking station. You will fiind it along the back wall of your unit. The plastic tubes on the backside of each rack will slide into a hole in the docking station. After a few years the rubber seal in the docking station will be worn away. Once this happens, it prevents the correct water pressure to the upper rack. The replacement part snaps into place and cost about $25.
Jan 19, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Maytag Dishwasher Logo
626 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
