Question about Canon PIXMA MP960 Printer
Error code 6A00 print head not moving. Sometimes
Error code 6A00 print head not moving. Sometimes I can move it and get it to work but not dependable.
  • 4,041 Answers
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Posted on Jan 25, 2010
Canon ip 4300 error code 6a00
The 6A00 is a Canon generic code for paper path jam. Somewhere in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if it is jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs Incidentally, the 6A00 error pertains to all Canon printers made in the last several years; it is not just used in one model. And it is always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has an electrical pump to milk the print heads and test for ink flow. Move back and forth several times (with the power off)
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Mar 18, 2011 | Office Equipment & Supplies
Error code 6A00
Feb 12, 2011 | Canon MP830 All-In-One Printer
ERROR CODE 6A00
A600 error
Jan 19, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Error Code 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 24, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Error code 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Apr 02, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Pixma 830 error code 6A00 on printer screen. Error 5C10 on computer screen when trying to print from computer. Tried moving ink tanks back and forth, shut off computer. Moved white thing to unsick ink...
Hi there
This answers with a titch more detail.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
The offending item needs to be removed or the purge unit needs replacement.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model.
And it’s always a paper path error or purge unit.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Also clean the purge unit out make sure all is clean.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Mar 08, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Cannon Mp600. I have an error code 6A00
Try
Solution 1:
Solution 2:
Solution 3:
Jan 12, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Error 6A00 appears. Will not print. Cannot find
Try it maybe
Solution 1:
Solution 2:
Solution 3:
Jan 08, 2010 | Canon PIXMA MP610 InkJet Printer
Error 6A00 appears. Wil not print. Cannot find
I found this elsewhere and it is from a Canon technician.
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
so what I would do is check for something blocking the paper path, plus turn off the printer, manually move the print head from one side to the other and back, and then turn the printer back on.
MX850 ERROR CODE 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Oct 05, 2009 | Canon PIXMA MX850 multifunction InkJet...
Canon PIXMA MP960 Printer Logo
259 people viewed this question
old marine
old marine
