Question about Sony Handycam CCD-TR87 Camcorder
Sony camcorder ccd-tr5- caution led blinking
Camcorder will constantly show a blinking cauten led. I cannot use the unit in VTR mode. it just comes out with this blinking caution led.
  • 1 more comment
  • chuckjdee Mar 11, 2008
    Have the same problem with my ccd-tr5; Can't eject or play the tape.
    Get a caution light.
    Guess because the cassett tape is jammed?
    Any ideas on how to remove it.
    That would probably fix the caution led
  • mjm044 May 02, 2008
    same problem
  • dueiy Nov 14, 2008
    I have a Ricoh R680 it''s exact as sony ccdtr line, it is blinking "caution" also
    I am troubleshooting it. I'll let you guys know how it goes.
    dueiy@yahoo.com
    Genius:
  • 1,036 Answers
After buying a similar unit (cheaply) , I have researched the problem, and found that a batch of faulty components are likely to blame.
In 1997 , a Tiwanese company stole a secret formula for Electrolytic capacitors. Unfortunately - it was a double bluff, and the formula they stole was incomplete. They began manufacture, and sold the components on to Sony, Chinnon, Apple and other manufacturers. The components typically have a usable life of between 2 and 6 years, then start leaking electrolyte (which smells of fish,) and corrodes the connections and the board. The only solution is to remove the boards and replace them or rework the boards replacing all electrolytic capacitors - which is labour intensive.
Unfortunately "fake" components are on the market, and can cause various problems from sporadic faults to a full blown fire risk.
If your camcorder smells bad inside - suspect the components are leaking. Most service engineers consign these units to the bin as repair is difficult. If your unit has just started to give an error or started smelling - then ask service engineers to replace the electrolytic capacitors. As these are surface mount components - they are VERY fiddly to do properly, so factor the cost of rework against a replacement unit.
Units affected are between 1999 and 2007
Posted on Feb 11, 2009
Hi - I have a panasonic ag-7330 SVHS deck. It lights up but does absolutely nothing. The Video Rec Servo light is blinking constantly. Any ideas?
It could have a timer record present that needs to be cleared. Otherwise it could be the mode switch playing up. But that too can be caused by physical damage inside the unit, thus setting the mechanism in the wrong position. In other words it thinks it is in record mode when it's not!
Aug 24, 2015 | Panasonic AG-7330 S-VHS VTR PAL w/...
Led is flashing and not showing anything.power supply voltage is not constant.
the display resolution must have changed after playing a game or using some software so that's why the LED is blinking.
Boot the PC in Safe mode & lower the resolution of your display
Apr 17, 2013 | Dell M770 17 in.CRT Conventional Monitor
I have sony 29'' crt tv . model no KV-DZM61 .when the tv statrs on it shows green led,and after few second the led glows red and it blinked for 2 times .then the tv goes in stand by mode
2 blinks means - over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
Jun 23, 2011 | Sony KV-XR29M61 TV
How can i record in vcr
On the power switch. Does it say camera/ player or Camera vtr. If it says player you can not record in vcr as you put it. In the earily days when camcorders were $800 and over ,they all Recorded from line in in the vtr mode. Not any more . See you you can switch to line in mode in the vtr postion however. Larry's Electronics 916-362-8708
Apr 23, 2010 | Sony Handycam DCR-TRV350 Digital Camcorder
Green battery light on the archos 5 but when i disconnect it from dock or usb no green lights abd completely dead - won't switch on either in dock or out???
Power green LED light should come on, CHG green LED light should also come on showing the battery is being charged. Leave your unit in Suspend mode while charging it, DO NOT turn it completely off as "Shutting Down.." because it will not charge your battery.
I just purchased an almost new Archos 5 on eBay recently, and the first day I had it, happened to me that I left the unit off and charging on the Mini Dock with external AC power supply, after 13-14 hours the CHG light still wasn't blinking. Then I though maybe I have to leave the unit in Suspend mode rather than completely off, which I did, and in a matter of 3 hours it fully charged the battery.
Again, do not shut down completely the unit, leave it on Suspended mode, or even on, and connected it to your mini dock, after a while the screen will go blank the unit will go into Suspended mode by itself, and after 3 hours on external power supply or 8 hours via USB on PC should be completely charged and your CHG light should be blinking, indicating the battery is charged.
I hope this helped.
Mar 10, 2010 | Archos Internet Media Tablet MP3 Player
Drum light flashing in spite of new drum unit and new toner cartridge
common problem.
  • The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
  • The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
  1. Open the front cover of the printer.
  1. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  1. Close the front cover.
Caution
    Reset the drum counter only when you replaced the drum unit with a new one.
Dec 30, 2009 | Brother HL-2040 Laser Printer
I have a digital video camera DCR-TVR140 and when I put the little casset on the screen(on center) appear a litttle arrow blinking and also a beep beep sound for maybe 5-10 seconds and still like that with...
Do you see any error number on LCD such as C32:11
If no.
1) It could be the Digital 8 tape is at the end set the unit on VTR mode then rewin the tape
2) The tab for record protection is on that mean the red tab at the right hand side full red indicated SAVE just turn to REC position in this case you can try on VTR mode it should work
Dec 01, 2008 | Video Cameras
It's turning on automatically!
I AM AN EXPERT ABOUT ALL THESE TRV66 FUNNY ELECTROS........ VOYARISM PREVENATIVE SHOCK WAVE 2008 EMAIL ME I WILL ANSWER YOUR ?'S
SCOTDAVIDACKELSBERG@EARTHLINK.NET
Dec 09, 2007 | Sony Handycam CCD-TRV66 Camcorder
Please guide me
it is a mechanical fault with the front damper of the zoom path check all mecxanical plastic related parts regards
Nov 03, 2006 | Panasonic AG-DVC62 Mini DV Digital...
Won't turn off
the On/Off/VTR Switch doesn't function anymore and the camera is a month old. Basically anytime the battery is in the camera or the camera is plugged in, it remains 'On'.
That means you can't charge batteries or use VTR mode, or turn the thing off. Way to go on this one Sony.
Oct 12, 2006 | Sony Handycam CCD-TRV87 Camcorder
Sony Handycam CCD-TR87  Camcorder Logo
748 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
