Question about Hitachi 46W500 46 in. TV/DVD Combo
46w500 hitachi tv-dvd
Disc jammed in player,will not eject or play.disc is spinning even with tv power turned off.
  • Anonymous Mar 23, 2014
    My combination tv/dvd crack,es in dvd mode even when no disc is loaded, the tv is not effected
    Problem Solver:
My Hitachi 46W500's DVD tray will not open. My son about 2 - 3 years ago said he had done something to he tray that may have caused this, is there any way to fix it at home ?
Posted on May 25, 2008
I have a Hitachi projection tv 46w500, the DVD got stuck inside, it is not comming out, where as the DVD is working fine able to play, farward and stopt the DVD but not allowing to eject. Even I tried to unplug and plug it again but no luck.
Posted on Apr 14, 2011
  • Barb Searle May 01, 2014
    Hi, sorry this reply is years later as was trawling thru' same prob, have found an answer of sorts if it's any help to others... The manual says (in very small print I might add) - to 'press the stop/eject button on your TV three times and the disc will eject' - and it works.. Don't think I would take the back off as some comments I've seen suggest (unless you are a TV engineer!) else long tweezers maybe with some soft masking tape on the ends so as not to damage your DVD (too much?) Hope this helps someone?
Mine did the same thing. When the disc is in the tv stays on. Unplug the tv from the wall it will reset and eject the disc.
Posted on Jan 20, 2008
I have a Polaroid TV/DVD combo. It took the DVD in, won't play it nor will it eject now. How do I get the DVD back?
Tries the tv unplug/replug the tv back for about an hour later for the tv power to reset itself.At this time u will able to eject the DVD disc out.Don't tries to used the tv intergrated DVD player anymore.The tv intergrated DVD player laser head and the spin motor for the dvd disc spinner it is defective now.Buy a portable cheap or a moderate unit of a outer DVD player and hook up to the tv AV input.Play it through the tv input video 1,2,3 u should have a DVD player capatablities again.
Nov 30, 2011 | Polaroid TDX-01930B 19 in. LCD HDTV
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
The tv model number is hitachi 46w500. the dvd picture is stuck on one screen and now the dvd won't eject.
Remove the power off and let the set rest for about few hours. Now try out to see if the DVD releases.
If the picture is still with the old memory of thelast scene then the processor has hung up.
You must have to release the DVD by opening panel if a reset of an overnight power on the set does not work.
Oct 30, 2010 | Hitachi 46W500 46 in. TV/DVD Combo
The DVD player is in constant eject mode - discs will not stay in to play. It has worked perfectly for years. Tonight I was watching a disc, finished, ejected it and put in another and the player just...
Two possible scenarios: First the optical pick up assembly that read the disc has malfunctioned or the eject button is faulty. Either way it is just cheaper to replace the DVD player with a standalone dvd player connected to one the tv input(s). Too expensive to repair just the dvd player if it is tv/dvd combo. The cost for labor and parts is more expensive these days to repair tvs or dvd player. For around $30 you can just replace...much more cost effective.
Aug 15, 2009 | Sylvania 6620LDF 20 in. EDTV-Ready LCD...
Is the hitachi 46W500 blue ray compatible
It doesn't have an HDMI port, only a DVI port. You'd have to get an HDMI-to-DVI cable to get a true "digital" signal on the screen, but you'd still have to do your audio with the RCA jacks because DVI is video only whereas HDMI is audio and video.
As far as Blu-ray compatible, yes and no. It's a high-def TV, so if you hook a Blu-Ray player up to it you'll be in good shape but the built-in DVD player will not read or play Blu-Ray movies.
Dec 31, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Dont know what to do
Probably not much help. but the 1st thing I would do is check to see if the disc is even turning...put it in with label straight up, then when it fails, eject...odds are severely against the disc being oriented the same way if it spins, so if it hasn't moved, the main drive motor is bound up or dead. Either way, return it.
Dec 29, 2007 | Coby DVD-233 DVD Player
Won't turn off
Go to the panel (on the tv set), hit magic focus on there....then hold power button for several seconds long. It should go off and fix your problem.
Jan 22, 2007 | Hitachi 46W500 46 in. TV/DVD Combo
DVD player won't eject
No but I'm having same problem and the dealer sugested just buying a new dvd player cause cost of repair or replacement is unbelivably high,approx 500 canadian for new dvd sleeve, the guy tells me they don't fix them they just put a whole new dvd player in from hthe manufacturer. Pretty disapointing considering how nice it is to have it built in.
Dec 24, 2006 | Hitachi 46W500 46 in. TV/DVD Combo
Hitachi 46W500 46 in. TV/DVD Combo Logo
638 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
